Is my Verbatim 43888 flashable
tasdisr
#1 Post by tasdisr » Thu Feb 12, 2026 4:44 pm
I have a Verbatim 43888 with the following drive info. Was not sure because of the manufacturer.
OS device name: D
Product: BD-RE BU40N
Revision: 1.05
S/N :M09PAK92454
Bus Encryption flags: 17
LibreDrive Informayion
Re: Is my Verbatim 43888 flashable
#2 Post by Coopervid » Thu Feb 12, 2026 4:51 pm
OS device name: D
Revision: 1.05
S/N :M09PAK92454
viewtopic.php?f=16&t=22896&hilit=sdftool
Here you go.
tasdisr
#3 Post by tasdisr » Thu Feb 12, 2026 6:24 pm
Thank You!
avinit
#4 Post by avinit » Thu Mar 05, 2026 9:02 am
Hi - sorry to hijack.
I have the exact same drive:
Revision: 1.05
Serial number: MOEPAIH1509
Highest AACS version: 61
Can I Confirm the link to the update tool works? Just because BU40N revision 1.05 wasnt specifically listed.
#5 Post by Billycar11 » Thu Mar 05, 2026 2:24 pm
Revision: 1.05
See guide below or email me or Marty for an automated flasher
avinit
#6 Post by avinit » Fri Mar 06, 2026 1:24 am
Thanks - worked it out. Used 1.03 MK and worked.
Cheers for the help.
Constantm
#7 Post by Constantm » Fri Mar 06, 2026 8:26 am
I have the same drive and the flashing with the spf tool and version 1.03 worked flawlessly. Thanks for al the work and support!
