ASUS BW-16D1X-U
ange14397
ASUS BW-16D1X-U
#1 Post by ange14397 » Tue Feb 17, 2026 10:43 pm
can this drive be flashed?
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number:
Firmware date: 2017-12-21
Highest AACS version: 82
Drive platform: RS8601
Firmware version: E111/ID76
I have a LG drive in an external encloser that has been flashed and slim drive both can read UHD with about the same success but would like a 3rd option .
thanks
Re: ASUS BW-16D1X-U
#2 Post by Billycar11 » Wed Feb 18, 2026 1:41 am
ange14397 wrote: Tue Feb 17, 2026 10:43 pm can this drive be flashed?
OS device name: L:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: E111
Serial number:
thanks
Yes it can be flashed email me that drive info section see below for email
all others email me no need to post your info here just reach out to me directly
see below for email
OneDay
Re: ASUS BW-16D1X-U
#3 Post by OneDay » Thu Mar 05, 2026 7:25 am
May I ask the build date on the bottom of the case? looking for a Pioneer drive.
Thank You.
D3619
Re: ASUS BW-16D1X-U
#4 Post by D3619 » Thu Mar 05, 2026 4:23 pm
OneDay wrote: Thu Mar 05, 2026 7:25 am May I ask the build date on the bottom of the case? looking for a Pioneer drive.
Thank You.
I have two BW-16D1X-U with manufacturing date in november 2024 with a Pioneer BDR-212T in it, can be flashed to read 4K. Bought two months ago.
Just bought two more of them with manufacturing date in november 2025 and the following drive is in it:
Laufwerksinformation
OS-Gerätename: G:
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: A105
Serienummer:
Firmware-Datum: 2120-12-02 11:14
Markierungen der Bus-Verschlüsselung: 1F
According to other posts in this forum it seems to be a LG WH16NS60, capable of reading 4k after flash. Could be worse, but I hoped for two more Pioneers. Two more BW-16D1X-u arrive tomorrow, hopefully they will have Pioneers in it. If not I will decide if I flash or RMA them
OneDay
Re: ASUS BW-16D1X-U
#5 Post by OneDay » Thu Mar 05, 2026 7:22 pm
Thank you. Are you in the US? Hope you get 2 more Pioneer drives. Heard they are a much better?
Re: ASUS BW-16D1X-U
#6 Post by MartyMcNuts » Thu Mar 05, 2026 11:16 pm
D3619 wrote: Thu Mar 05, 2026 4:23 pm
Thank You.
OS-Gerätename: G:
Produzent: ASUS
Produkt: BW-16D1X-U
Revision: A105
Serienummer:
These are LG WH16NS40 drives and yes, can be made UHD compatible by flashing. The recommended firmware is WH16NS60 1.02-MK.
D3619
Re: ASUS BW-16D1X-U
#7 Post by D3619 » Fri Mar 06, 2026 11:44 am
OneDay wrote: Thu Mar 05, 2026 7:22 pm Thank you. Are you in the US? Hope you get 2 more Pioneer drives. Heard they are a much better?
I‘m in Europe.
The two other drives just arrived, both are from November 2025 too and have the same ASUS/LG drive in them.
Looks like the BW-16D1X-U with a Pioneer BDR-212T in it have a serialnumber beginning with SBD0A printed on the box while the newer ones have a serialnumber beginning with TBD0A.
OneDay
Re: ASUS BW-16D1X-U
#8 Post by OneDay » Fri Mar 06, 2026 7:13 pm
D3619 wrote: Fri Mar 06, 2026 11:44 am
I‘m in Europe.
Thank you for the information. Sorry you ended up with two more LG's. I'll keep my eye out on the serial number.
Re: ASUS BW-16D1X-U
#9 Post by Coopervid » Fri Mar 06, 2026 7:47 pm
I‘m in Europe.
There are external Verbatim / Pioneer drives on sale in the UHD drives forum if you are interested.
skyrider
Re: ASUS BW-16D1X-U
#10 Post by skyrider » Mon Mar 23, 2026 10:15 pm
I‘m in Europe.
I recently bought an ASUS BW‑16D1X‑U with a manufacturing date of January 2025, and the serial number started with T1D0A...
Inside it was a Pioneer drive, so searching by serial number didn't work.
Unless we assume that serial numbers starting with "S" correspond to late 2024 units, which would likely mean Pioneer. Meanwhile, serial numbers starting with "T1" (January 2025) also seem to be Pioneer, while those starting with "TB" (November 2025) appear to be LG. We don't know what's inside units with numbers from "T2" up to "TB", nor what time period those ranges cover. Unfortunately, the manufacturing date isn't printed on the box - it's only on the underside of the drive enclosure.
We need more samples to identify any reliable pattern in the serial numbers.
Looking for a Pioneer 4K UHD drive?
Click here
nicholfd
Re: ASUS BW-16D1X-U
#11 Post by nicholfd » Mon Mar 23, 2026 11:45 pm
skyrider wrote: Mon Mar 23, 2026 10:15 pm
I‘m in Europe.
SN's T#, # = month of Mfg in 2025. T1-T4 (Jan-Apr) are Pioneer, for all I purchased & sold. T5-TB (May-Nov) are LG. I have not found/seen any mfg since Nov, 2025.
I've seen 200+ with T# SNs. This is the pattern based on the SN & Mfg date on the chassis.
I suspect SNs starting with "S" were all Mfg in 2024.
Thanks,
Frank
skyrider
Re: ASUS BW-16D1X-U
#12 Post by skyrider » Tue Mar 24, 2026 12:46 am
Thank you, now it makes sense.
Click here
OneDay
Re: ASUS BW-16D1X-U
#13 Post by OneDay » Wed Mar 25, 2026 10:15 pm
I just compared the serial number on my box with the build date and they do match up.
On the box T9 and build date 2025-09 with a Asus BW-16D1HT drive.
I just bought one on ebay with the serial S3 and build date of 2024-03. When it gets here I'll update the post with the drive type.
Thank you
D3619
Re: ASUS BW-16D1X-U
#14 Post by D3619 » Thu Mar 26, 2026 8:30 am
OneDay wrote: Wed Mar 25, 2026 10:15 pm I just compared the serial number on my box with the build date and they do match up.
Thank you
Manufactured in 2024-03 has a good chance that it contains a Pioneer, probably a BDR-212T.
I bought yesterday a BW-16D1X-U manufactured in 2024-01 and it has a Pioneer in it, couldn’t check which one yet. Probably a BDR-212T.
Three of my other BW-16D1(X|H)-U are all from 2024-10 and 2024-11 and have a BDR-212T in it.
An other BW-16D1H-U I had was from 2023-07 and had an ASUS BW-16D1HT in it. My BW-16D1X-U from 2023-01 has an ASUS BW-16D1HT in it too. And I know that 2022-08 contains ASUS BW-16D1HT too.
So if anyone wants a Pioneer avoid BW-16D1(X|H)-U build between 2022-08 and 2023-07 as there is a high chance that they contain an ASUS/LG drive.
nicholfd
Re: ASUS BW-16D1X-U
#15 Post by nicholfd » Mon Mar 30, 2026 9:04 pm
nicholfd wrote: Mon Mar 23, 2026 11:45 pm
I‘m in Europe.
Thanks,
Frank
I have more ASUS BW‑16D1X‑U coming, and all the serial number begin with "W2..." (per the invoice sheet). I suspect they skipped letters "U" & "V" because they may appear similar, depending on the font, and went to "W" for 2026. I expect these drives to have a Mfg date of February, 2026.
Thanks,
Frank
