Hi, can you help add to public keydb please? Also technically I used a BW-16D1X-U, but it has been flashed by Billy to be able to read 4K UHD. Attached is the displayed Drive Info and LibreDrive Info in MakeMKV.
Disc type: UHD
Disc ID: 0x2D35331BA56F061391E0F4E28A4E84F4FC6A5163
Disc dump filename: MKB20_v77_GIRLS_UND_PANZER_DER_FILM_4K_E02E
Drive: BD-RW BDR-S12JX
Drive firmware: PIONEER BDR-212T
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1UHYE90 ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1Xpdydv ... sp=sharing
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-S12JX
Revision: 1.01
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 77
Drive platform: RS8F01
Firmware version: 1.01/ID72
Dump: Girls und Panzer 4k UHD (2025)
keydb_helper
Re: Dump: Girls und Panzer 4k UHD (2025)
Hey gecko71539, your disc has been added to the public keydb.gecko71539 wrote: Sun Mar 01, 2026 4:46 am Hi, can you help add to public keydb please? Also technically I used a BW-16D1X-U, but it has been flashed by Billy to be able to read 4K UHD. Attached is the displayed Drive Info and LibreDrive Info in MakeMKV.
Disc type: UHD
In the future, please post disc submissions to the public keydb thread. Creating a new thread for each unsupported disc isn't ideal as it increases the likelihood of your disc dump being accidentally overlooked.
Public KeyDB Disc Submissions
May I get the build date on the bottom the case and your location? trying to find one with a Pioneer drive. Hoping US version has a pioneer drive.
Thank you
Thank you
