Hi, can anyone please help. Is this drive able to be patched to read 4K?
If so could you please advise what flash utility to use and which firmware?
Thank you!
Andy
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
Asus BW-16D1X-U
Re: Asus BW-16D1X-U
See guide below or email me or Marty for an automated flasher
Re: Asus BW-16D1X-U
Thank you! As it turns out I took a chance and used the SDFTool Flasher v1.36 and Firmware WH16NS60-1.02
Worked like a charm.
oap1ikwydlsh2o
Re: Asus BW-16D1X-U
hi , which software di u use please
Re: Asus BW-16D1X-U
I used SDFTool 1.36
Used Firmware BW-16D1HT 3.10
Worked perfectly since it is a Asus drive.
oap1ikwydlsh2o
Re: Asus BW-16D1X-U
thank you , worked forst time .
Re: Asus BW-16D1X-U
To avoid the Sleep Bug or have less problems with 3-Layer discs feel free to flash to LG WH16NS60 1.02MK.OneDay wrote: Mon Mar 02, 2026 8:12 am I used SDFTool 1.36
Re: Asus BW-16D1X-U
Glade it worked
Also as zittrig said flash the LG WH16NS60 1.02MK
The drives in the BW-16D1X-U are rebranded LG WH16NS40 from what I have researched.
