UHD rips failing
wasteram
UHD rips failing
Post by wasteram »
Using MakeMKV 1.18.3 Beta, seems I am unable to rip any UHD discs. I've tried three so far, including one I ripped previously with the same hardware. Bluray rips OK.
Product: BD-RE BU40N
Revision: 1.03
Serial number: ************
Highest AACS version: 82
Firmware version: 1.03
Disc Information
Label: CLOSE_ENCOUNTERS_OF_3RD_KIND
Timestamp: 2017-08-09 23:39:51
Protection: AACS2.0/C v61
Data capacity: 93.21 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Bus encryption flags: 80
...this disc was ripped before.
Log output:
MakeMKV v1.18.3 win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..002000800 to device 'SPTI:\Device\CdRom2'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occurred while issuing SCSI command AD010..080002400 to device 'SPTI:\Device\CdRom2'
Saved AACS dump file as C:/Users/j/.MakeMKV/MKB20_v61_Close_Encounters_of_the_Third_Kind_40th_Anniversary_Edition_5FB5.tgz
I have a KEYDB.cfg downloaded today. If drive is in LibreDrive mode the AACS host certificate should not be revokable, correct?
I can send the dump files if that is helpful, but at least one of the problem discs is already in the KEYDB.cfg.
Suggestions?
Re: UHD rips failing
wasteram wrote: Mon Mar 02, 2026 1:05 am Using MakeMKV 1.18.3 Beta, seems I am unable to rip any UHD discs. I've tried three so far, including one I ripped previously with the same hardware. Bluray rips OK.
Revision: 1.03
Disc Information
Number of layers: 3
Log output:
Suggestions?
Sometimes it says libredrive is enabled even though it actually isn't or didn't start libredrive mode correctly. Try powering off the drive and/or PC for a minute or two before turning it back on.
When libredrive is functioning correctly, any certificate revocation is ignored. It can still be revoked but MakeMKV doesn't care.
wasteram
Post by wasteram »
Tried that; no change.
Is there another test I can do to confirm/deny LibreDrive is active?
Any value in re-flashing the drive?
wasteram wrote: Wed Mar 18, 2026 3:43 pm Tried that; no change.
looks like a power issue again or a bad case
try a higher power usb port or a powered usb hub
wasteram
Post by wasteram »
Nailed it! Switched the drive to direct via SATA, powered off the PC power supply. Works perfectly.
Off to find buy one of the recommended USB-SATA enclosures...
