New unit for 4k
cigueta
New unit for 4k
Post by cigueta »
Hello, my internal UHD disc copying drive is broken. I need to buy a new one, but I don't know which drive is best. I need you to tell me exactly which drive to buy so we can correctly decrypt the keys.
Re: New unit for 4k
Knowing what country you're in would be helpful. What can be bought varies.
cigueta
Re: New unit for 4k
Post by cigueta »
I'm from Spain and I've acquired this new drive. I'm sending you screenshots of the model that appears in MakeMKV and the firmware version I have (version 3.00). Just tell me if this drive is one of the best and if it works perfectly, if it needs to be downgraded or left as is, and if so, which version. Also, will it export the file correctly to send information for new UHDs, and is that okay?
I've included screenshots below for download.
https://gofile.io/d/DA7Zji
cigueta
Re: New unit for 4k
Post by cigueta »
My new unit is the ASUS BW-16D1HT, as shown in the screenshot below. Could someone tell me if it's necessary to downgrade or if it would be better to optimize the firmware?
Re: New unit for 4k
cigueta wrote: Sun Mar 08, 2026 9:52 am My new unit is the ASUS BW-16D1HT, as shown in the screenshot below. Could someone tell me if it's necessary to downgrade or if it would be better to optimize the firmware?
You cannot attach images here. Copy & paste the Drive info and Libredrive info sections text from MakeMKV.
cigueta
Re: New unit for 4k
Post by cigueta »
Información de unidad de disco
Nombre del SO del dispositivo: F:
Fabricante: ASUS
Producto: BW-16D1HT
Revisión: 3.00
Número de serie: SIK9HH28E220
Fecha del firmware: 2115-11-03 11:10
Marcas de cifrado bus: 1F
Highest AACS version: 82
Firmware version: 3.00
No hay disco insertado
Is it okay as is for my Asus to work properly and send the correct data to create the new key, or do we need to flash it?
Re: New unit for 4k
cigueta wrote: Sat Mar 21, 2026 1:33 pm Información de unidad de disco
Fabricante: ASUS
Producto: BW-16D1HT
Revisión: 3.00
should work as is
