The Love Boat
Zebra3
The Love Boat
Post by Zebra3 » Wed Feb 25, 2026 7:45 pm
I searched this out first but didn't find anything, so either I'm the only one ripping The Love Boat episodes on DVD, or no one else here seems to have this issue.
I've ripped a ton of my movies and tv shows for my personal Jellyfin server successfully, but when I attempt to rip DVD episodes from this show, the software only reads one episode on a disc, whereas there are 2 or 4 on a disc. I've tried numerous times, cleaning the disc, flipping it, playing them on my player to make sure they're on it (they are), to no avail. It doesn't read all the episode files on the disc. I thought maybe the disc is damaged but it does this for several discs, spanning different season sets, and I even purchased another new set to test and the same thing happens. Seems to only happen with The Love Boat! I'm using v1.18.2.
Any ideas from the expert wizards here?
Re: The Love Boat
Post by Woodstock » Wed Feb 25, 2026 8:33 pm
Hit this 7 times over the last couple of weeks with 1.18.2 and .3. Actually, with the "17 series" as well.
Went back to version 1.16.2 (had it handy) and the disks rip all episodes. I suspect it's a difference in the default settings as things moved forward. You can try the older versions by downloading them at https://makemkv.com/download/old/ to see if you've got the same issue I had.
Zebra3
Re: The Love Boat
Post by Zebra3 » Wed Feb 25, 2026 8:58 pm
Wow, thanks! I'll give it a shot and report back.
16.2 worked! Thank you so much. I never thought the fix would be a much older version. Thanks again!
