selecting languages
twa000
selecting languages
Post by twa000 »
OK realise I must be doing something stupid but cannot get multiple languages to work.
I have set on expert mode and edited the user profile file, see below and saved it to the Makemkv data file in my user folder - but Makemkv only selects my favourite language (English) - any ideas???
<?xml version="1.0" encoding="utf-8"?>
<profile>
<name lang="eng">My Profile</name>
<!-- Common MKV flags -->
<mkvSettings ignoreForcedSubtitlesFlag="true" />
<!-- Output formats currently supported by MakeMKV -->
<outputSettings name="discard" outputFormat="discard">
<description lang="eng">Discard track</description>
</outputSettings>
<outputSettings name="copy" outputFormat="directCopy">
<description lang="eng">Copy track as is</description>
</outputSettings>
<outputSettings name="lpcm" outputFormat="LPCM-raw">
<description lang="eng">Save as raw LPCM</description>
<channelOrder>L,R</channelOrder>
<byteOrder>big</byteOrder>
</outputSettings>
<outputSettings name="wavex" outputFormat="LPCM-wavex">
<description lang="eng">Save as LPCM in WAV container</description>
</outputSettings>
<!-- Default rule - copy as is -->
<trackSettings input="default">
<output outputSettingsName="copy"
defaultSelection="-all,+eng,+ger,+nolang,-havemulti,-havecore,+forced">
</output>
</trackSettings>
<!-- Save LPCM mono or stereo as raw LPCM -->
<trackSettings input="LPCM-stereo">
<output outputSettingsName="lpcm"
</output>
</trackSettings>
<!-- Put multi-channel LPCM into WAVEX container-->
<trackSettings input="LPCM-multi">
<output outputSettingsName="wavex"
</output>
</trackSettings>
</profile>
twa000
Re: selecting languages
Post by twa000 »
flogger123 wrote:Hi twa000, did you manage to get a workaround on this?
As of today - Yes!
With 1.7.3 I can update directly the defaults in makemkv preferences/advanced tab, and it all works :)
- no need to have a user profile
