Backup failed - region?
DavidGA
Post by DavidGA »
Do DVD drives being set to the wrong region still prevent MakeMKV from decrypting the disc?
I have a small pile of LG GH24NSB0 and GH24NSC0 drives, and I thought I would use them to make a ripping machine, since I have a lot of DVDs.
But the "Backup" function fails. It reads for a while, looks like it's working, but then complains about the region and "Backup failed".
Backing up disc into folder "/run/user/1000/doc/7c8bdda1/MakeMKV/backup/BBCDVD2438#E3A0.iso"
Calculated BUP offset for VTS #1 does not match one in IFO header.
Calculated BUP offset for VTS #2 does not match one in IFO header.
Calculated BUP offset for VTS #3 does not match one in IFO header.
Region setting of drive HL-DT-ST:DVDRAM GH24NSB0 does not match the region of currently inserted disc, trying to work around...
Backup failed
Here's the debug/robot version:
MSG:1005,0,1,"MakeMKV v1.18.3 linux(x64-release) started","%1 started","MakeMKV v1.18.3 linux(x64-release)"
MSG:1004,131072,1,"Debug logging enabled, log will be saved as file:///home/lion/MakeMKV_log.txt","Debug logging enabled, log will be saved as %1","file:///home/lion/MakeMKV_log.txt"
MSG:1003,32,3,"DEBUG: Code 0 at `BLLaJX7%0; ?J)zOB:`KC:29393631","DEBUG: Code %1 at %2:%3","0","`BLLaJX7%0; ?J)zOB:`KC","29393631"
DRV:0,0,999,0,"DVD+R-DL HL-DT-ST DVDRAM GH24NSC0 LK00 K61E7GG5334","","/dev/sr1"
DRV:1,0,999,0,"DVD+R-DL HL-DT-ST DVDRAM GH24NSC0 LK00 KSOE7II1601","","/dev/sr2"
DRV:2,2,999,1,"DVD+R-DL HL-DT-ST DVDRAM GH24NSB0 LN00 KG4E2591408","BBCDVD2438#E3A0","/dev/sr3"
DRV:3,0,999,0,"DVD+R-DL HL-DT-ST DVDRAM GH24NSB0 LN00 KRRE2591424","","/dev/sr0"
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:5072,131072,1,"Backing up disc into folder \"file:///run/user/1000/doc/7c8bdda1/MakeMKV/52.iso\"","Backing up disc into folder \"%1\"","file:///run/user/1000/doc/7c8bdda1/MakeMKV/52.iso"
MSG:3002,0,2,"Calculated BUP offset for VTS #1 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","1"
MSG:3002,0,2,"Calculated BUP offset for VTS #2 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","2"
MSG:3002,0,2,"Calculated BUP offset for VTS #3 does not match one in IFO header.","Calculated %1 offset for VTS #%2 does not match one in IFO header.","BUP","3"
MSG:3032,0,2,"Region setting of drive HL-DT-ST:DVDRAM GH24NSB0 does not match the region of currently inserted disc, trying to work around...","Region setting of drive %1:%2 does not match the region of currently inserted disc, trying to work around...","HL-DT-ST","DVDRAM GH24NSB0"
MSG:1003,32,3,"DEBUG: Code 1 at \\PHu*'8B;K*!1:29395770","DEBUG: Code %1 at %2:%3","1","\\PHu*'8B;K*!1","29395770"
MSG:1003,32,3,"DEBUG: Code 0 at X*aVSLix=*B'4d%7ZRfq:121266097","DEBUG: Code %1 at %2:%3","0","X*aVSLix=*B'4d%7ZRfq","121266097"
MSG:5069,128,0,"Backup failed","Backup failed"
MSG:5080,516,0,"Backup failed.","Backup failed."
Is this a region problem? If so, is there replacement firmware for the GH24NSB0 / GH24NSC0 drives? Or do I have some other problem?
Re: Backup failed - region?
It depends on the drive.
Most BD drives will allow MakeMKV to ignore the region code; I've ripped DVD disks from Europe and Japan just as easily as US disks.
Some DVD-only drives are not as flexible. They will simply refuse to rip an out-of-region disk without being re-enabled for the new region, taking away one of your allowed region changes.
Sometimes they'll adapt if you run them on Windows or Mac, but not often.
DavidGA
Post by DavidGA »
I hooked up a WH16NS60 blu-ray drive which has LibreDrive firmware installed, and to my surprise, it did the same thing when ripping a DVD. It complained about region, and then failed.
Surely LibreDrive drives shouldn't do that? MakeMKV even says "DVD all regions: Yes" in the drive info. What gives?
DavidGA
Post by DavidGA »
So, I guess the problem is not the region after all, it's just a bad disc.
Other discs give the region message, but still rip OK.
Is there a way to get a more verbose description of why a rip fails? "Rip failed" immediately after a region error really does imply that it's a region problem, but in this case it wasn't.
