I've been unsuccessful in flashing my HL-DT-ST / BD-RE BU40N from this forum and GitHub. I might return it and buy a pre-flashed one here if one becomes available, but not sure when that will be.
In the meantime, I'll try to get the OmniDrive MT1959 firmware bundle. If someone could DM me a VGPC Discord invite, it would be much appreciated!
Hit a wall with Slimline Flasher. OmniDrive bundle?
Fastnbulbous1969
Re: Hit a wall with Slimline Flasher. OmniDrive bundle?
Did you read the first post in the Ultimate UHD Drives Flashing Guide thread?
It has links to the necessary firmware for a BU40N and to the SDFtool Flasher which makes it pretty easy to do on Windows.
Fastnbulbous1969
I did, thanks, but I found that the SDFtool will not detect my slimline drive, as it's only for full-size desktop drives.
that is not the caseFastnbulbous1969 wrote: Mon Feb 23, 2026 1:57 pm I did, thanks, but I found that the SDFtool will not detect my slimline drive, as it's only for full-size desktop drives.
post your makemkv drive info section it is likely your drive setup how is it connected usb to sata what adapter is it one in the guide?
Fastnbulbous1969
Thanks for your patience, I'm rusty at dealing with tweaking drive firmware.
Current profile: BD-R SRM
Product: BD-RE BU40N
Revision: 1.05
Serial number: MO8PAKC0341
Revision: 1.05
Fastnbulbous1969
I can't edit my response as it's not showing up yet, but it's only connection is USB-C.
You can flash it. Read the UHD guide. If on Linux / Mac you must use enc in your command line.Fastnbulbous1969 wrote: Tue Feb 24, 2026 4:25 pm I can't edit my response as it's not showing up yet, but it's only connection is USB-C.
viewtopic.php?f=16&t=19634
Fastnbulbous1969
I'm re-reading that thread, and in the "The all you need firmware pack," I only see the stock firmware I already had for LG slim BU40N, not the patched BU40N 1.03 MK that I thought I need in order to bypass the lock for downgrade protection/encrypted firmware/anti-rollback checks.
Read again. You are wrong.Fastnbulbous1969 wrote: Tue Feb 24, 2026 9:26 pm I'm re-reading that thread, and in the "The all you need firmware pack," I only see the stock firmware I already had for LG slim BU40N, not the patched BU40N 1.03 MK that I thought I need in order to bypass the lock for downgrade protection/encrypted firmware/anti-rollback checks.
Fastnbulbous1969
Okay, again:
"If your external Buffalo / Archgon / LG BU40N has encrypted firmware, flash BU40N 1.03-MK first, then you can either leave it as is or flash BU40N 1.00 or Buffalo BU / BN firmware if you want to."
I don't see the BU40N 1.03-MK in the all you need firmware pack, only the stock firmware: HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
Read again. No stock firmware.Fastnbulbous1969 wrote: Tue Feb 24, 2026 9:59 pm Okay, again:
These are one and the same. If it has "NM" in it then it is the MK firmware and it is easier to say MK than NM00000-21.....Fastnbulbous1969 wrote: Tue Feb 24, 2026 9:59 pm Okay, again:
