ictbydesign
Post by ictbydesign » Tue Feb 24, 2026 2:05 pm
Does anyone know if either of these drives can be flashed.
Both are LG BD rewriter.
Model = BH10LS38
Manufactured - July 2011
Model = BH10LS30
Manufactured - July 2010
ROM Ver:1.00 for both
Thanks in advance.
zittrig
Re: SDFtool Flasher
Post by zittrig » Tue Feb 24, 2026 2:08 pm
ictbydesign wrote: Tue Feb 24, 2026 2:05 pm Does anyone know if either of these drives can be flashed.
Model = BH10LS38
Model = BH10LS30
Thanks in advance.
No, to old. Both. Sorry.
mescalero
Re: SDFtool Flasher
Post by mescalero » Tue Feb 24, 2026 11:03 pm
I have been trying to flash the LG BP50NB40 by using the SDFtool flasher on a Mac, using Windows via VMWare Fusion. I first flashed to the 1.03 firmware for my drive, and then to the BU40N-1.00 firmware via the Recover option on the tool, but it is not working. I feel like there was some mention about problems using the tool on a virtual machine, but I previously had luck flashing a Pioneer drive on VMWare, using the BDRFlash tool (thanks to coopervid for the help with that one!).
nicholfd
Re: SDFtool Flasher
Post by nicholfd » Tue Feb 24, 2026 11:40 pm
mescalero wrote: Tue Feb 24, 2026 11:03 pm I have been trying to flash the LG BP50NB40 by using the SDFtool flasher on a Mac, using Windows via VMWare Fusion. I first flashed to the 1.03 firmware for my drive, and then to the BU40N-1.00 firmware via the Recover option on the tool, but it is not working. I feel like there was some mention about problems using the tool on a virtual machine, but I previously had luck flashing a Pioneer drive on VMWare, using the BDRFlash tool (thanks to coopervid for the help with that one!).
This is what MakeMKV is currently saying about the drive:
Not a VM problem. I've used VMware Fusion, Parallels & UTM on macOS to flash drives.
Carefully follow the animated GIF/video on the first page of this thread. You must select a firmware three times. Pay attention to the animated GIF & when/where a firmware is chosen, and what firmware is chosen.
mescalero
Re: SDFtool Flasher
Post by mescalero » Tue Feb 24, 2026 11:54 pm
Ah, got it! The part where you select the same firmware, but in Recover mode, is what threw me. Thanks a million.
Re: SDFtool Flasher
Post by Billycar11 » Wed Feb 25, 2026 1:42 am
mescalero wrote: Tue Feb 24, 2026 11:54 pm Ah, got it! The part where you select the same firmware, but in Recover mode, is what threw me. Thanks a million.
on mac unless your using a vm to flash
the method in the guide is much easier to crossflash where you use the hbd fw
nicholfd
Re: SDFtool Flasher
Post by nicholfd » Wed Feb 25, 2026 3:10 am
Yep - been there, done that & took me a couple of times, my first time.
Thanks,
Frank
DrOct
Re: SDFtool Flasher
Post by DrOct » Wed Feb 25, 2026 8:26 pm
Hi there! Thanks so much for this great tool. I just flashed a Verbatim drive with a BU40N in it to 1.03. Testing now and its working well ripping a disc as we speak.
I'm going to try on a Buffalo drive that appears to have a BU40N in it too soon.
I did notice this and other sentences in the first page: "If your external Buffalo / Archgon / LG BU40N has encrypted firmware, flash BU40N 1.03-MK first, then you can either leave it as is or flash BU40N 1.00 or Buffalo BU / BN firmware if you want to."
I'm curious what the reason for dropping to 1.00 is. Is there some advantage to it over 1.03? Apologies if I've missed the explanation for this. I didn't see it in the first post and this is a very long thread...
zittrig
Re: SDFtool Flasher
Post by zittrig » Wed Feb 25, 2026 9:45 pm
DrOct wrote: Wed Feb 25, 2026 8:26 pm ....
With the 1.00 you can use e.g. DVDFab also, which accept native 4K firmware only.
DrOct
Re: SDFtool Flasher
Post by DrOct » Wed Feb 25, 2026 10:22 pm
zittrig wrote: Wed Feb 25, 2026 9:45 pm With the 1.00 you can use e.g. DVDFab also, which accept native 4K firmware only.
Got it. So if I'm not planning to use DVDFab, no real reason to go further and switch to 1.00 then. Thanks!
babayaga
Re: SDFtool Flasher
Post by babayaga » Fri Mar 06, 2026 11:25 pm
Sorry, this has probably been answered before, but
these are my settings, I have tried SDFTool flasher, and i see MT1959 platform is with a red x (disabled i assume), and i get the same error message when i try to write a firmware to the drive ( ASUS-BW-16D1H-U-A204-WM01001-211901041044 ).
Is there anything to do, or is the drive not possible to use for this? thanks for all answers i can get :)
Current profile: DVD-ROM
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Serial number: SEDL056253WL
Firmware date: 2017-12-21
Highest AACS version: 64
Drive platform: RS8601
Firmware version: E114/ID71
Re: SDFtool Flasher
Post by Billycar11 » Sat Mar 07, 2026 1:09 am
babayaga wrote: Fri Mar 06, 2026 11:25 pm Sorry, this has probably been answered before, but
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E114
Sure email me that drive info section see below for email
For all others there is no need to post your makemkv drive info section publicly just email it to me directly
epicchancellor
Re: SDFtool Flasher
Post by epicchancellor » Tue Mar 10, 2026 1:37 am
Hi all,
After doing some investigation on Reddit in regards to flashing a 4K firmware onto my ASUS BW-16D1-XU drive, a user said I could use a firmware for what seems to be an LG drive (DE_LG_WH16NS60_1.02_MK) and it worked for that user. Trying to flash it onto my drive and it spits out an error, screenshots attached. I'm super new to this so any advice would be greatly appreciated!
Screenshot 2026-03-09 213218.png (3.54 KiB) Viewed 16227 times
Screenshot 2026-03-09 213031.png (15.73 KiB) Viewed 16227 times
Re: SDFtool Flasher
Post by MartyMcNuts » Wed Mar 11, 2026 3:52 am
epicchancellor wrote: Tue Mar 10, 2026 1:37 am Hi all,
Take the disc out of the drive!
dominikz
Re: SDFtool Flasher
Post by dominikz » Wed Mar 11, 2026 7:00 am
Hi all :) My first post, so don't hate me for posting here. I have Verbatim external drive, earlier one with micro-usb. MakeMKV spit out this data:
Informacje o napędzie
Aktualny profil: BD-ROM
Producent: PIONEER
Produkt: BD-RW BDR-UD03
Wersja: 1.10
Numer seryjny: RKDL182614WL
Data firmware: 2017-04-18
Flagi szyfrowania bus: 1B
Najwyższa wersja AACS: 82
Drive platform: RS8511
Firmware version: 1.10
And gemini says it is possible to flash it with "Pioneer Drive Flasher" and "BDR-UD04_1.14_MK.bin" firmware to work with UHD drives. But I only see SDFtool Flasher available. Could someone please help me? :)
