Downgrade of my BD-RE WH14NS40 MT1939 Possible?!?
Knightynight
Post by Knightynight »
Greetings folks! :D
I may have posted my inquiry in the wrong place. My hope is that I may be able to downgrade the firmware of my BD-RE WH14NS40 but it has the MT1939 Drive Platform. So that means that 4K/UHD may not be possible?
Not sure what the options are. Please advise?
KN
OS device name: H:
Product: BD-RE WH14NS40
Revision: 1.03
Serial number: K8AC4EN3855
Firmware date: 2114-03-26 11:05
Drive platform: MT1939
Firmware version: 1.03
BD raw metadata read: Partial
Re: Downgrade of my BD-RE WH14NS40 MT1939 Possible?!?
Knightynight wrote:
Tue Feb 24, 2026 7:19 am
Greetings folks! :D
KN
OS device name: H:
Revision: 1.03
No. Your drive is too old (2014 model) and has the older, incompatible MT1939 drive platform. Do not try to flash it or it will become a brick. It already has libredrive enabled which is good for standard blu-ray and this is as good as this drive will ever get.
Knightynight
Hey, thanks for the quick reply MMNS :D ! Yeah, after a did a quick, in depth search, I discovered just what you stated. I also looked up the ship variants. Not worth the soldering efforts to swap them out. A can o worms fer sure :shock: ! Thanks again.
