Asus BW-16D1X-U
Andy_01
Asus BW-16D1X-U
Hi, can anyone please help. Is this drive able to be patched to read 4K?
If so could you please advise what flash utility to use and which firmware?
Thank you!
Andy
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
Firmware date: 2119-01-04 10:47
Bus encryption flags: 1F
Harware support: Yes
Firmware support: No
Firmware version: 0.A104W
Thank you!
Andy
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A104
Serial number:
Re: Asus BW-16D1X-U
See guide below or email me or Marty for an automated flasher
Andy_01
Re: Asus BW-16D1X-U
Thank you! As it turns out I took a chance and used the SDFTool Flasher v1.36 and Firmware WH16NS60-1.02
Worked like a charm.
oap1ikwydlsh2o
Re: Asus BW-16D1X-U
hi , which software di u use please
OneDay
Re: Asus BW-16D1X-U
I used SDFTool 1.36
Used Firmware BW-16D1HT 3.10
Worked perfectly since it is a Asus drive.
oap1ikwydlsh2o
Re: Asus BW-16D1X-U
thank you , worked forst time .
zittrig
Re: Asus BW-16D1X-U
To avoid the Sleep Bug or have less problems with 3-Layer discs feel free to flash to LG WH16NS60 1.02MK.OneDay wrote: Mon Mar 02, 2026 8:12 am I used SDFTool 1.36
OneDay
Re: Asus BW-16D1X-U
Glade it worked
Also as zittrig said flash the LG WH16NS60 1.02MK
The drives in the BW-16D1X-U are rebranded LG WH16NS40 from what I have researched.
bob1273
Re: Asus BW-16D1X-U
Hey there,
so if I have a new ASUS BW-16D1X-U, which Firmware should I flash to - the LG WH16NS60 1.02MK ?
Thanks in advance
Thanks in advance
Re: Asus BW-16D1X-U
depends if its mt1959 see guide or email me or marty for an auto flasherbob1273 wrote: Tue Sep 15, 2026 11:12 am Hey there,
Thanks in advance
if its pioneer email me for the automated flasher see profile for email
Re: Asus BW-16D1X-U
Post your Makemkv info as plain text.bob1273 wrote: Tue Sep 15, 2026 11:12 am Hey there,
Thanks in advance
bob1273
Re: Asus BW-16D1X-U
Well, I ordered it, but there are some availability problems und I did not get it yet. As soon as I receive the drive I will post the information, thanks.
funkywaddle
Re: Asus BW-16D1X-U
I'm having some issues trying to flash my drive.
I am running on Ubuntu 25.10.
I downloaded the sdf.bin file, and downloaded the "The all you need firmware pack".
I first extracted the `ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin` file, and copied both it and the sdf.bin file to /tmp, but as you can see from the image below, that didn't work. Then I extracted the `HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin` file and put that into /tmp.
The command I ran:
But to no avail. You can see from the image that it's not doing anything. I even waited for 20 minutes just in case it was a slow process. But no indication it's doing anything. No progress indicator, no output, no errors, nothing.
Any ideas, thoughts, help, guidance, etc would be greatly appreciated.
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1X-U
Revision: A105
Serial number: KLZP4ID3934
Firmware date: 2120-12-02 11:14
Drive platform: MT1959I am running on Ubuntu 25.10.
The command I ran:
./makemkvcon f -d 'dev_21:3' -f /tmp/sdf.bin rawflash main -i /tmp/HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Re: Asus BW-16D1X-U
encfunkywaddle wrote: Fri Sep 25, 2026 12:36 am I'm having some issues trying to flash my drive.
Drive Information OS device name: /dev/sr0 Manufacturer: ASUS Product: BW-16D1X-U Revision: A105 Serial number: KLZP4ID3934 Firmware date: 2120-12-02 11:14 Bus encryption flags: 1F LibreDrive Information Status: Possible, not yet enabled Drive platform: MT1959
The command I ran:But to no avail. You can see from the image that it's not doing anything. I even waited for 20 minutes just in case it was a slow process. But no indication it's doing anything. No progress indicator, no output, no errors, nothing.Code: Select all
funkywaddle
Re: Asus BW-16D1X-U
ThanksBillycar11 wrote: Fri Sep 25, 2026 2:59 amencfunkywaddle wrote: Fri Sep 25, 2026 12:36 am I'm having some issues trying to flash my drive.
enc, not main?
I did finally get it to work. I had to downgrade to 1.17.7. It seemed to work alright. I'm currently making a mkv from a bluray disc. We'll see if it works.
Should I have done enc instead of main? Do I need to do it again?
