Public KeyDB Disc Submissions
shawngguitar
To whom it may concern,
I have a Five Nights at Freddy's 2 Steelbook UHD 4K dump to submit. The HD Blu Ray disk works it seems so the 4K disc is the only one in my set not working. Details below.
Disc type: UHD
Disc ID: Couldn't figure this part out on my end, so sorry. I'll include the Unit Key RO in my Disc dump link folder
Disc dump filename:MKB20_v82_Five_Nights_at_Freddy's_2_C682.tgz
Drive:BD-RE BP60NB10
Drive firmware:1.02
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?: Yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/drive/folders/ ... sp=sharing
Disc dump link: https://drive.google.com/drive/folders/ ... sp=sharing
Note that I am using the same link for both the MKB_RO and the Disc dump and Unit Key RO I've provided to make the process as simple as possible. Thanks in advance!
Disc type: UHD
Drive firmware:1.02
nyva95
Hello, thank you for your hard work
Would you help me with the following blurays?
Disc type: BD-ROM
Disc ID: 0xB8A74A041B654B4DED7DA91196F80973
Disc dump filename: MKB_v82_Hey!_Say!_JUMP ハニカミ_A474
Drive: BD-RE WH14NS40
Drive firmware: 1.05
LibreDrive status: Possible
Disc dump link:https://drive.google.com/file/d/1THV8qJ ... sp=sharing
Disc type: BD-ROM
Disc ID: 0xBC6F0C4FF7B3A439CD2B8015BFFC68AE
Disc dump filename: MKB_v82_Hey!_Say!_JUMP ハニカミ_4A9A[/b]
Drive:BD-RE WH14NS40
Disc dump link: https://drive.google.com/file/d/1w1NiEd ... sp=sharing
Disc type: BD-ROM
Disc ID: 0x4C0D8C72FB1FE8F29A8BBE0781EE7275
Disc dump filename: MKB_v82_KENTO_NAKAJIMA_IDOL1ST_BD_A_BFE0
LibreDrive status:Possible
Disc dump link: https://drive.google.com/file/d/1smyjnd ... sp=sharing
Disc type: BD-ROM
Disc ID: 0x3A31D1602406E281D48066B7995E7EBB
Disc dump filename: MKB_v82_KENTO_NAKAJIMA_IDOL1ST_BD_B_D346
Disc dump link: https://drive.google.com/file/d/1q6YK3T ... sp=sharing
Thank you <3
Disc type: BD-ROM
Disc type: BD-ROM
Disc type: BD-ROM
Disc type: BD-ROM
Thank you <3
keydb_helper
No worries Rays1, there is no expectation for anyone to read the entire thread before posting. AACS 2.1 hasn't even been discussed much in this thread, as there were only ever a handful of movies which utilised the protection and most have been re-issued with standard AACS 2.0.Rays1 wrote: Thu Feb 19, 2026 8:41 pm Got it! And thanks for the heads up. I looked in to aacs and figured out that i just have to switch the disk out and get a new one. I would of never known about aacs not being supported had you not told me. Reading through 124 pages is rather daunting, but I must admit after submitting my request I realized I didn't follow the format. Problem is a also don't know where all that information comes from to fill the proper request. However i did do the vuk update thing and that worked like a charm on the new predator I just got last night so I should be good to go. Gonna try another copy of zombieland from a different source. Thank you again for helping out. Definitely not trying to waste anyone's time here.
Hey Shawn, thanks for the submission but your disc variant was added to the public keydb on February 14. Follow the instructions here to configure MakeMKV to utilise the public keydb and you'll be good to go.shawngguitar wrote: Fri Feb 20, 2026 3:51 am Disc dump filename: MKB20_v82_Five_Nights_at_Freddy's_2_C682.tgz
All other submissions have been processed and added to the public keydb.
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
Toad King
Disc type: UHD
Disc ID:
3ce9fe649b5eaa3139adb343493ee433ade13704
cb5d038b270eb7bb476bc20553f84241bd664a6b
Disc dump filename:
MKB20_v82_Prison_On_Fire_8AA0
MKB20_v82_Prison_On_Fire_II_C746
Drive: BDR-S13JX
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not needed
Disc dump link:
https://drive.google.com/file/d/1bKovLB ... pw2mj/view
https://drive.google.com/file/d/1VRdo9w ... LGc8w/view
Disc ID:
Disc dump filename:
Drive: BDR-S13JX
Disc dump link:
keydb_helper
Thanks to everyone who followed the submission template and provided new disc dump files. The following discs have been added to the public keydb (new media keys indicated with an asterisk):
MKB20_v77_BDROM
*MKB20_v82_HAMNET_C56C
*MKB20_v82_KUNG_FU_PANDA_3_FD22
*MKB20_v82_NowYouSeeMe_3_B02E
*MKB20_v82_Prison_On_Fire_8AA0
*MKB20_v82_Prison_On_Fire_II_C746
*MKB20_v82_The_Stunt_Man_UHD
*MKB20_v82_VIRIDIANA_F980
MKVDUDE
Another 4 please!
Disc type: UHD
Disc dump filenames:
MKB20_v82_SALEM'S_LOT_-_4K_UHD_0DF2.tgz
MKB20_v82_SALEM'S_LOT_-_Theatrical_Cut_-_4K_UHD_2D94.tgz
MKB20_v82_SPACEBALLS_-_UHD_16F0.tgz
MKB20_v82_THE_BIRTHDAY_-_UHD_52E8.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-I1UFgKZUwo
Many thanks!
Disc type: UHD
Drive: BD-RE BU40N
Many thanks!
Franchiver
For the latest French UHD release (by BQHL) of John Carpenter's Halloween:
Disc type: UHD
Disc ID: Apologies, I'm not sure where to look for this information
Disc dump filename: MKB20_v82_Halloween_4022
Drive: Asus BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://cloud.elbelion.com/s/mt6WAkZxja7caCt
Disc dump link: https://cloud.elbelion.com/s/2jBbqo4ZBio9FA8
Disc type: UHD
Tobisatsu
The info below is for the Shout Factory release of Nightcrawler on 4K Steelbook:
Disc type: UHD Nightcrawler
Disc ID: 68F4C6B538F29AEC05F4D01ECF9EAFDD66CCCF87 (Also including Unit_Key_RO file just in case I did it wrong: https://drive.google.com/file/d/1HSY9EY ... drive_link)
Disc dump filename: MKB20_v82_Nightcrawler_3426
Drive: ASUS BW-16D1HT
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1cXn4I- ... drive_link
Disc Dump Link: https://drive.google.com/file/d/1sHiSAH ... drive_link
Let me know if any further info is needed, and thanks in advance!
tarzxf
Howard the Duck 4K
Disc type: UHD
Disc ID: 43973f77769ffac653465f3ad50752d036469c68
Disc dump filename: MKB20_v76_Howard_the_Duck_0D43.tgz
Drive: LG BP60NB10
Drive firmware: 1.02
Did you sync the public keydb within the last 15 minutes? Yep
Have you verified that all submission links are accessible in incognito/private browsing? Yep!
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1HzLVGM ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1klHBpM ... sp=sharing
Disc type: UHD
Drive: LG BP60NB10
keydb_helper
*MKB20_v82_Halloween_4022
*MKB20_v82_SALEM'S_LOT_-_4K_UHD_0DF2
*MKB20_v82_SALEM'S_LOT_-_Theatrical_Cut_-_4K_UHD_2D94
*MKB20_v82_SPACEBALLS_-_UHD_16F0
*MKB20_v82_THE_BIRTHDAY_-_UHD_52E8
*MKB20_v82_THE_DEAD_315E
Hey tarzxf, thanks for the submission but your particular disc variant was added to the public keydb on February 3. Please check the latest keydb before posting to this thread.tarzxf wrote: Sun Feb 22, 2026 5:09 am Howard the Duck 4K
Hey Tobisatsu, thank you for the submission. You correctly calculated the disc ID but your disc was already added to the public keydb on February 7. Follow the steps linked in the first post and you'll be able to backup your disc.Tobisatsu wrote: Sun Feb 22, 2026 3:10 am The info below is for the Shout Factory release of Nightcrawler on 4K Steelbook:
Disc ID: 68F4C6B538F29AEC05F4D01ECF9EAFDD66CCCF87 (Also including Unit_Key_RO file just in case I did it wrong: ...)
dougy
Disc type: UHD
Disc dump filename: MKB20_v82_THE_CONJURING_LAST_RITES_E5DD.tgz
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1UCTn1m ... sp=sharing
Disc dump link: https://drive.google.com/file/d/13NtbDJ ... sp=sharing
tarzxf
And it helps if the data directory is NOT set to the output path; my mistake.
Does explain why the .tgz file was appearing there and not the in Library path on the Mac as expected.
Thank you for the continued work and effort!
CrashOveride
Disc type: UHD
Disc ID: 06f86853e4d11caab38417abaefd3a63af7e5305
Disc dump filename: MKB20_v82_Galaxy_Express_999_636B
Drive: BW-16D1X-U (Flashed with WH16NS60 firmware)
Did you sync the public keydb within the last 15 minutes? (Yes)
Have you verified that all submission links are accessible in incognito/private browsing? (Yes)
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://mega.nz/file/GCgHyLrQ#Wcd2srw9F ... gK2rEiz0OQ
Disc dump link: https://mega.nz/file/iSQm0KoI#DP6rtmkn1 ... rPAMMLSwUA
Thank you for your effort in maintaining the DB!
Franchiver
Thank you for the addition.keydb_helper wrote: Sun Feb 22, 2026 11:41 am Thanks to everyone who followed the submission template and provided new disc dump files. The following discs have been added to the public keydb (new media keys indicated with an asterisk):Code: Select all
*MKB20_v82_Halloween_4022 *MKB20_v82_SALEM'S_LOT_-_4K_UHD_0DF2 *MKB20_v82_SALEM'S_LOT_-_Theatrical_Cut_-_4K_UHD_2D94 *MKB20_v82_SPACEBALLS_-_UHD_16F0 *MKB20_v82_THE_BIRTHDAY_-_UHD_52E8 *MKB20_v82_THE_DEAD_315E
99gagamel
Disc Type: UHD
Disc ID: 0xC58CC1300B14294185F507D340DE278EE1BE59A8
Disc Dump Filename: MKB20_v61_RED_13F0,tgz
Drive: BH16NS55
Drive Firmware: 1.05
LibreDrive status: Activated
Have you synchronized the public key database in the last 15 minutes? Yes
Have you verified that all submission links are accessible in incognito/private mode? Yes
Link to the file MKB_RO.inf: https://drive.google.com/file/d/1OdhUB0 ... sp=sharing
Link to the disk dump: https://drive.google.com/file/d/1tBw5_S ... sp=sharing
Getting disc info...
Validation Data: 6625E2B719EDE68D675FC6FACEEA795B [FOUND]
Media Key: [NOT FOUND]
Media Key not found!
[(Disc Info)]
[DiscID]: 0xC58CC1300B14294185F507D340DE278EE1BE59A8
[Volume]: RED
[Date]: 2018-04-16
[VID]: 0x6007F1252C537644B4C590C1B387E1CD
[MKB]: 61
[EncKey]: 1-0xB07F3E332852BE91494ABD5FF1BA11DD
[KEYDB_STATUS]: (NOTVALIDATED)
[STATUS]: incomplete
[DiscType]: UHD
Drive: BH16NS55
[(Disc Info)]
[Volume]: RED
[Date]: 2018-04-16
[MKB]: 61
[DiscType]: UHD
