EthanBB
Post by EthanBB »
MartyMcNuts wrote: Fri Jan 23, 2026 8:37 pm
You mean encrypted firmware. Green tick means encrypted.
You can flash it to BU40N 1.03-MK.
Thank you very much!
BU40N 1.03-MK from "mk-firmware-pack-20200720.zip" worked like a dream.
minoskorva
Post by minoskorva »
Is there a way to flash the ASUS SBW-06D5H-U?
this is my output
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: A102
Serial number:
Firmware date: 2124-08-05 14:55
Bus encryption flags: 1F
THANKS!!!
minoskorva wrote: Sun Feb 08, 2026 10:20 am Is there a way to flash the ASUS SBW-06D5H-U?
this is my output
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number:
THANKS!!!
Yes, this is a LG drive. If it's a slim model, use BU40N 1.03-MK with SDFtool Flasher.
nicwilson
Post by nicwilson »
Just wanted to thank everyone here for the information and flash information. I successfully flashed my Asus SBW-06D5H-U with the LG BU40N 1.03 firmware. At first, I got an error with SDFTool Flasher which gave no furher information, But when I ran the Flash with makemkvcon64.exe it gave a helpful error that the tray was not closed. Once the tray was closed then the flash worked perfectly. Thank you to all invloved.
cheers
Nic :D
BrunoGC13
Post by BrunoGC13 »
Hello, I have the exact same drive but where can I find the needed files? Like the .bin and SDF.bin (I'm very new to makemkv and this topic)
BrunoGC13 wrote: Fri Feb 20, 2026 9:46 am Hello, I have the exact same drive but where can I find the needed files? Like the .bin and SDF.bin (I'm very new to makemkv and this topic)
If you're looking for BU40N firmware and the SDFtool flasher, links to that stuff can be found in the Ultimate UHD Drives Flashing Guide
boguslecina
Post by boguslecina »
Check what hardware platform you have. MT1959 is Hitachi-LG, and you have the SDFtool Flasher application there:
viewtopic.php?f=16&t=19634
If you have RS8511, you need to write to Coopervid or Billy11 about the flasher.
maccready
Post by maccready »
Hi all
I just bought the same asus-drive, and I also wonder if my drive is flashable:
OS device name: /dev/sr1
Manufacturer: ASUS
Revision: A102
Serial number: MO6O92I5822
Many thanks!
maccready
Post by maccready »
I noticed that my drive output was identical to minoskorva's(?) above, so I followed MartyMcNuts instructions and it worked flawless.
Thanks a lot for all your work Marty!!
fhades
Post by fhades »
Hi, I'm gonna add myself to the queue for a pm :)
OS device name: H:
Manufacturer: ASUS
Revision: E101
Serial number:
Firmware date: 2018-08-22
Drive platform: RS8511
Firmware version: E101/ID26
Looking forward to make some good use of it after mostly laying around for the last 5 years :)
fhades wrote: Mon Apr 13, 2026 9:38 pm Hi, I'm gonna add myself to the queue for a pm :)
OS device name: H:
Manufacturer: ASUS
Revision: E101
Serial number:
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
erluan
Post by erluan »
Hello, Guys!
Hope you're doing pretty well;
Guys, I have ASUS SBW-06D5H-U since 2020 and it works flawlessly with my 1080 Bluray collection but, now, I bought some UHD Blurays and I got blocked by these limitations;
How can I flash the firmware to unlock the UHD blurays reading;
I'm gonna add myself to the queue for a pm;
Thank you in advance;
erluan wrote: Mon Jun 08, 2026 12:14 pm Hello, Guys!
see below for email
cyberschlumpf
Post by cyberschlumpf »
MartyMcNuts wrote: Mon Feb 09, 2026 2:58 am
this is my output
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number:
THANKS!!!
Hello, I have the same drive/firmware/firmware date, exactly the same output. It's an external USB3.1 model (slim).
I am a new user and a little bit confused: Is this BU40N 1.03-MK only for reading UHDs?
I want to have a libredrive to surpass the riplock of 2.0x speed limit mainly and to bypass region lock, etc.
Do I still need to flash the above mentioned firmware or is there a simpler way?
Is the flashing "fail safe" or could it brick my drive?
cyberschlumpf
I used the mentioned tools on this forum with the 1.03 MK firmware for the BU40N and it worked without issues. My drive is now identified as a HL-.... drive and no longer as the ASUS model it is according to the box. So far no problems.
