Alvin and the Chipmunks - Chipwrecked
pro510
Failed in similar way to "The Sitter". Will send in dump.
hsu4186
Re: Alvin and the Chipmunks - Chipwrecked
I get the same strange error. Not sure where the dump file is, but I'll send it too when I find it.
- Contact:
This disc still uses old BD+, please send dumps and SVQ will be added in a day.
hsu4186
Sure thing. I sent the file to the email response I received. Thanks.
hsu4186
I was able to convert to mkv. Thanks!
pau8rady
Having the same problem with this Blu-ray (and with Tintin too)
Attached is the log file
- MakeMKV_log.txt
- (11.82 KiB) Downloaded 643 times
washburnk
I am getting the following error on this disk. This is in Brasil.
The source file '/BDMV/STREAM/00800.m2ts' is corrupt or invalid at offset 170354688, attempting to work around
Dump is Attached.
Dump is Attached.
antoine2
Latest dsall.svq not working for my disk. Dump file sent to support@makemkv.com but had to re-archive into 3 files for emailing. Is this ok? Any other way to send dump file without splitting it?
