This disc uses newer version of AACS protection. Please let us know about it by visiting
Saved AACS dump file as MKB_v82_Song_Sung_Blue_BF4E.tgz
Dump Submitted for Song Sung Blue
Re: Dump Submitted for Song Sung Blue
I encountered the same error. Should I submit a dump file as well?
The name of my dump file is exactly the same.
Thanks for checking.
Assuming wyliec2 emailed the dump to svq@makemkv.com, then the necessary key will eventually be available. It is acceptable, however, to submit your dump as well just in case.
