Predator Badlands Bluray requires MakeMKV 1.18.3
5tephenDD
Post by 5tephenDD »
I had an older version of 1.18 for Windows on my PC, but it could not decipher the bluray disc. I updated to 1.18.3 and MakeMKV can now back it up.
Earl_H
Re: Predator Badlands Bluray requires MakeMKV 1.18.3
Post by Earl_H »
Did you do anything special? I updated to 1.18.3 and I'm getting, "The volume key is unknown for this disk - video cant be decrypted Failed to Open Disk". TIA for any info that can help.
I don't have this disc, but since it is a new release it might need a hashed key for MakeMKV to be able to rip it.
Can you post the full lof of MakeMKV trying to rip the disc?
Did it say it made a dump file? If so, what is the full name of the file?
Did it say anything about trying to download HKs?
Earl_H
Post by Earl_H »
I attached the dumpfile to this response. Im pretty new at this. Please lmk if there is anything more that can be provided to support finding a resolution. TIA!
Earl_H wrote: Thu Feb 19, 2026 5:02 pm I attached the dumpfile to this response. Im pretty new at this. Please lmk if there is anything more that can be provided to support finding a resolution. TIA!
Attaching files to the forum usually doesn't work. Email dump files to svq@makemkv.com.
Earl_H
Post by Earl_H »
dcoke22 wrote: Thu Feb 19, 2026 10:45 pm
Thank you. I did so yesterday after continuing to do more "research" on the forum.
wrbreland
Post by wrbreland »
For anyone that has copied this title to .MKV, do you know which subtitle to select so only the Predators spoken voice is displayed in English. I copied with the first English (with forced) selected but this one displays descriptive words and when English is being spoken. Played the disc on the Oppo UDP-203 and found one English subtitle that only displayed when the Predators spoke.
Harry 4k
Post by Harry 4k »
Scroll down to another 2 English subs tick them as well,rip it, you will get 3 files,the one you want to keep is to2 , scroll through the subs and select English 1923.
