Public KeyDB Disc Submissions
Odd and supremely unhelpful. It doesn't get them the help they desire and just wastes time.
Got it! And thanks for the heads up. I looked in to aacs and figured out that i just have to switch the disk out and get a new one. I would of never known about aacs not being supported had you not told me. Reading through 124 pages is rather daunting, but I must admit after submitting my request I realized I didn't follow the format. Problem is a also don't know where all that information comes from to fill the proper request. However i did do the vuk update thing and that worked like a charm on the new predator I just got last night so I should be good to go. Gonna try another copy of zombieland from a different source. Thank you again for helping out. Definitely not trying to waste anyone's time here.keydb_helper wrote: Thu Feb 19, 2026 11:19 am Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):I believe all other valid submissions have also been processed.Code: Select all
*MKB20_v77_SISU_ROAD_TO_REVENGE_3FFA *MKB20_v82_DANCER_IN_THE_DARK_71C4 *MKB20_v82_Poltergeist_II_-_Die_andere_Seite_57AE *MKB20_v82_The_Doors_7D88 *MKB20_v82_Ugly_Stepsister_UHD
Hey Rays1, AACS 2.1 isn't a priority for the public keydb at this time. MakeMKV also doesn't utilise the public keydb for AACS 2.1 titles, so the benefit of any additions would be limited.Rays1 wrote: Wed Feb 18, 2026 10:33 am Here's a dump for Zombieland UHD
Hope I've done this right and thank you in advance.
Hey Brian, I know you were trying to contribute but your post wasn't very helpful. Both of your discs were added to the public keydb on February 6. Please try to read the opening post of this thread as it contains links to some helpful instructions and the submission template.
Hey BulldogK9, thanks for the submission but as I told Brian the public keydb has included both of those discs since February 6. Please follow the steps linked in the first post of this thread to configure MakeMKV to utilise the public keydb.BulldogK9 wrote: Wed Feb 18, 2026 6:23 am Disc ID: c555715912619c9803036bbf97bc5a2d6bbd24d9
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_1_1B54.tgz
Disc ID: 251ef05ee0ced79b6d50b0d38861aca6fb8b950c
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_2_6290.tgz
This was released today, so the public keydb doesn't have them.
For future reference, the disc ID is the SHA-1 hash of the Unit_Key_RO.inf file from each disc. For your two discs the expected values were 0x3B1972EA7E5F4AD158DBB6FC52729A4BD2A35137 and 0x24F08F816CE30532833EE0D08B1066359EBA8101
Hey CampbellsChunky, your disc variant has been added to the public keydb. Please do not extract the MKB_RO.inf file from your disc dump file and upload it separately - provide the full file from the disc instead.CampbellsChunky wrote: Thu Feb 19, 2026 1:58 am Disc dump filename: MKB20_v76_Akira_D8FB.tgz
MKB_RO.inf link: ...
Even if you choose to skip the first 123 pages, folks are pretty good about following the template now. I find the idea of posting in a thread after reading essentially none of the existing posts to be a bit odd...SamuriHL wrote: Thu Feb 19, 2026 1:28 am I guess reading the first post in this thread is no longer in fashion huh?
UhhNewUser
TOP_GUN
Disc type: BD-ROM UHD
Disc ID: 2AA34B6F5B75ADFB22CE0F8885A966B895A7F1F5
Disc dump filename: MKB20_v72_Top_Gun_D5AB.tgz
Drive: BD-RE WH16NS40
Drive firmware: 1.02
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Copied from disc into disk dump
Disc dump link: https://www.dropbox.com/scl/fi/zbl3fyie ... evbip&dl=0
TOP_GUN_MAVERICK
Disc ID: A3385703677D62623E50503DB79F714A5A9F2E37
Disc dump filename: MKB20_v76_Top_Gun-_Maverick_D817.tgz
Disc dump link: https://www.dropbox.com/scl/fi/1dnycpgg ... 1ty5y&dl=0
TOP_GUN_MAVERICK
shawngguitar
To whom it may concern,
I have a Five Nights at Freddy's 2 Steelbook UHD 4K dump to submit. The HD Blu Ray disk works it seems so the 4K disc is the only one in my set not working. Details below.
Disc type: UHD
Disc ID: Couldn't figure this part out on my end, so sorry. I'll include the Unit Key RO in my Disc dump link folder
Disc dump filename:MKB20_v82_Five_Nights_at_Freddy's_2_C682.tgz
Drive:BD-RE BP60NB10
Drive firmware:1.02
LibreDrive status:Enabled
Did you sync the public keydb within the last 15 minutes?: Yes
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/drive/folders/ ... sp=sharing
Disc dump link: https://drive.google.com/drive/folders/ ... sp=sharing
Note that I am using the same link for both the MKB_RO and the Disc dump and Unit Key RO I've provided to make the process as simple as possible. Thanks in advance!
Disc type: UHD
Drive firmware:1.02
Hello, thank you for your hard work
Would you help me with the following blurays?
Disc type: BD-ROM
Disc ID: 0xB8A74A041B654B4DED7DA91196F80973
Disc dump filename: MKB_v82_Hey!_Say!_JUMP ハニカミ_A474
Drive: BD-RE WH14NS40
Drive firmware: 1.05
LibreDrive status: Possible
Disc dump link:https://drive.google.com/file/d/1THV8qJ ... sp=sharing
Disc type: BD-ROM
Disc ID: 0xBC6F0C4FF7B3A439CD2B8015BFFC68AE
Disc dump filename: MKB_v82_Hey!_Say!_JUMP ハニカミ_4A9A[/b]
Drive:BD-RE WH14NS40
Disc dump link: https://drive.google.com/file/d/1w1NiEd ... sp=sharing
Disc type: BD-ROM
Disc ID: 0x4C0D8C72FB1FE8F29A8BBE0781EE7275
Disc dump filename: MKB_v82_KENTO_NAKAJIMA_IDOL1ST_BD_A_BFE0
LibreDrive status:Possible
Disc dump link: https://drive.google.com/file/d/1smyjnd ... sp=sharing
Disc type: BD-ROM
Disc ID: 0x3A31D1602406E281D48066B7995E7EBB
Disc dump filename: MKB_v82_KENTO_NAKAJIMA_IDOL1ST_BD_B_D346
Disc dump link: https://drive.google.com/file/d/1q6YK3T ... sp=sharing
Thank you <3
Disc type: BD-ROM
Disc type: BD-ROM
Disc type: BD-ROM
Disc type: BD-ROM
Thank you <3
keydb_helper
No worries Rays1, there is no expectation for anyone to read the entire thread before posting. AACS 2.1 hasn't even been discussed much in this thread, as there were only ever a handful of movies which utilised the protection and most have been re-issued with standard AACS 2.0.Rays1 wrote: Thu Feb 19, 2026 8:41 pm Got it! And thanks for the heads up. I looked in to aacs and figured out that i just have to switch the disk out and get a new one. I would of never known about aacs not being supported had you not told me. Reading through 124 pages is rather daunting, but I must admit after submitting my request I realized I didn't follow the format. Problem is a also don't know where all that information comes from to fill the proper request. However i did do the vuk update thing and that worked like a charm on the new predator I just got last night so I should be good to go. Gonna try another copy of zombieland from a different source. Thank you again for helping out. Definitely not trying to waste anyone's time here.
Hey Shawn, thanks for the submission but your disc variant was added to the public keydb on February 14. Follow the instructions here to configure MakeMKV to utilise the public keydb and you'll be good to go.shawngguitar wrote: Fri Feb 20, 2026 3:51 am Disc dump filename: MKB20_v82_Five_Nights_at_Freddy's_2_C682.tgz
All other submissions have been processed and added to the public keydb.
Disc type: UHD
Disc ID:
3ce9fe649b5eaa3139adb343493ee433ade13704
cb5d038b270eb7bb476bc20553f84241bd664a6b
Disc dump filename:
MKB20_v82_Prison_On_Fire_8AA0
MKB20_v82_Prison_On_Fire_II_C746
Drive: BDR-S13JX
Drive firmware: 1.03
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Not needed
Disc dump link:
https://drive.google.com/file/d/1bKovLB ... pw2mj/view
https://drive.google.com/file/d/1VRdo9w ... LGc8w/view
Disc ID:
Disc dump filename:
Drive: BDR-S13JX
Disc dump link:
keydb_helper
Thanks to everyone who followed the submission template and provided new disc dump files. The following discs have been added to the public keydb (new media keys indicated with an asterisk):
MKB20_v77_BDROM
*MKB20_v82_HAMNET_C56C
*MKB20_v82_KUNG_FU_PANDA_3_FD22
*MKB20_v82_NowYouSeeMe_3_B02E
*MKB20_v82_Prison_On_Fire_8AA0
*MKB20_v82_Prison_On_Fire_II_C746
*MKB20_v82_The_Stunt_Man_UHD
*MKB20_v82_VIRIDIANA_F980
Another 4 please!
Disc type: UHD
Disc dump filenames:
MKB20_v82_SALEM'S_LOT_-_4K_UHD_0DF2.tgz
MKB20_v82_SALEM'S_LOT_-_Theatrical_Cut_-_4K_UHD_2D94.tgz
MKB20_v82_SPACEBALLS_-_UHD_16F0.tgz
MKB20_v82_THE_BIRTHDAY_-_UHD_52E8.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: N/A
Disc dumps link: https://we.tl/t-I1UFgKZUwo
Many thanks!
Disc type: UHD
Drive: BD-RE BU40N
Many thanks!
Franchiver
For the latest French UHD release (by BQHL) of John Carpenter's Halloween:
Disc type: UHD
Disc ID: Apologies, I'm not sure where to look for this information
Disc dump filename: MKB20_v82_Halloween_4022
Drive: Asus BW-16D1HT
Drive firmware: 3.10
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://cloud.elbelion.com/s/mt6WAkZxja7caCt
Disc dump link: https://cloud.elbelion.com/s/2jBbqo4ZBio9FA8
Disc type: UHD
The info below is for the Shout Factory release of Nightcrawler on 4K Steelbook:
Disc type: UHD Nightcrawler
Disc ID: 68F4C6B538F29AEC05F4D01ECF9EAFDD66CCCF87 (Also including Unit_Key_RO file just in case I did it wrong: https://drive.google.com/file/d/1HSY9EY ... drive_link)
Disc dump filename: MKB20_v82_Nightcrawler_3426
Drive: ASUS BW-16D1HT
Did you sync the public keydb within the last 15 minutes? YES
Have you verified that all submission links are accessible in incognito/private browsing? YES
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1cXn4I- ... drive_link
Disc Dump Link: https://drive.google.com/file/d/1sHiSAH ... drive_link
Let me know if any further info is needed, and thanks in advance!
Howard the Duck 4K
Disc type: UHD
Disc ID: 43973f77769ffac653465f3ad50752d036469c68
Disc dump filename: MKB20_v76_Howard_the_Duck_0D43.tgz
Drive: LG BP60NB10
Did you sync the public keydb within the last 15 minutes? Yep
Have you verified that all submission links are accessible in incognito/private browsing? Yep!
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://drive.google.com/file/d/1HzLVGM ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1klHBpM ... sp=sharing
Disc type: UHD
Drive: LG BP60NB10
keydb_helper
*MKB20_v82_Halloween_4022
*MKB20_v82_SALEM'S_LOT_-_4K_UHD_0DF2
*MKB20_v82_SALEM'S_LOT_-_Theatrical_Cut_-_4K_UHD_2D94
*MKB20_v82_SPACEBALLS_-_UHD_16F0
*MKB20_v82_THE_BIRTHDAY_-_UHD_52E8
*MKB20_v82_THE_DEAD_315E
Hey tarzxf, thanks for the submission but your particular disc variant was added to the public keydb on February 3. Please check the latest keydb before posting to this thread.tarzxf wrote: Sun Feb 22, 2026 5:09 am Howard the Duck 4K
Hey Tobisatsu, thank you for the submission. You correctly calculated the disc ID but your disc was already added to the public keydb on February 7. Follow the steps linked in the first post and you'll be able to backup your disc.Tobisatsu wrote: Sun Feb 22, 2026 3:10 am The info below is for the Shout Factory release of Nightcrawler on 4K Steelbook:
Disc ID: 68F4C6B538F29AEC05F4D01ECF9EAFDD66CCCF87 (Also including Unit_Key_RO file just in case I did it wrong: ...)
Disc type: UHD
Disc dump filename: MKB20_v82_THE_CONJURING_LAST_RITES_E5DD.tgz
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1UCTn1m ... sp=sharing
Disc dump link: https://drive.google.com/file/d/13NtbDJ ... sp=sharing
And it helps if the data directory is NOT set to the output path; my mistake.
Does explain why the .tgz file was appearing there and not the in Library path on the Mac as expected.
Thank you for the continued work and effort!
