Dear fellow enthusiasts,
First of all, many thanks to this amazing community for your outstanding work and tireless dedication.
I am currently experiencing a “HashCheck Error” with the backup of two UHD titles:
FURIOSA_A_MAD_MAX_SAGA
TRON_ARES
The drive is an LG BH16NS55.AHLU10B flashed with WH16NS60-1.02.
Does anyone have a tip? Other UHD titles are working fine.
I would appreciate any support.
Best regards,
Bergriese
Laufwerksinformation
OS-Gerätename: E:
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE WH16NS60
Revision: 1.02
Serienummer: KLUP1GK3029
Firmware-Datum: 2118-10-29 19:36
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 82
Firmware version: 1.02
Disk-Informationen
Label: FURIOSA_A_MAD_MAX_SAGA
Zeitstempel: 2024-07-03 09:30:26
Schutz: AACS2.0/C v77
Datenkapazität: 88.72 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 3
Markierungen der Bus-Verschlüsselung: 80
HashCheck Error on some UHD backups
Re: HashCheck Error on some UHD backups
Clean the discs. Hash check failures means the data wasn't read correctly off the disc.
Thank for the fast response.
That was the first thing I tried based on the initial forum search results. I also have a second identical Tron Ares UHD available, and it had the same problem. I also tested a second identical drive.
Don't know what to tell you. Hash Check errors are because the data wasn't read correctly from the disc. So it's either a disc issue or a drive issue.
its just the joys of an lg
i found you need to also power them off when they do this they can get into a weird mode where they will do it on everything until turned off.
you should also clean the disc
i recommend a damp lint free cloth and dry immediately with another to avoid water spots
Thank you.
Knowing that the LG drive remains in a faulty state after a HashCheck error until it is powered off completely helped.
