macOS deprecation
eppic
macOS deprecation
Post by eppic » Sun Feb 08, 2026 7:48 am
When installing MakeMKV via Homebrew on macOS, you're currently getting warned that MakeMKV has been "deprecated because it does not pass the macOS Gatekeeper check" and will be "disabled on 2026-09-01".
Are there any plans to fix this and have the code properly signed in time? This should be expected from a software that is technically not freeware.
Re: macOS deprecation
Post by dcoke22 » Wed Feb 18, 2026 3:19 pm
I don't think MakeMKV has ever been signed by the developer for macOS. I don't expect it will be, but I'm just speculating.
It has never occurred to me to try to install MakeMKV via Homebrew.
You can install unsigned software on your Mac: https://support.apple.com/en-us/102445
psycoperl
Post by psycoperl » Wed Feb 18, 2026 10:43 pm
Just wondering if MakeMKV is going to be impacted when Apple deprecates and basically removes Rosetta 2 in the next MacOS in September. Is the MacOS version a universal binary or written for the Apple Silicon?
Post by dcoke22 » Thu Feb 19, 2026 1:09 am
When I look in Activity Monitor the 'kind' for the MakeMKV process shows as Apple, so it is running natively on Apple Silicon.
psycoperl
Post by psycoperl » Thu Feb 19, 2026 2:32 am
That's a relief.
Now I just wonder about what to use instead of MKVToolsNix as they won't be migrating to Apple Silicon.
Konten
Post by Konten » Thu Feb 19, 2026 8:31 am
psycoperl wrote: Thu Feb 19, 2026 2:32 am That's a relief.
Eurgh!! I just found out about that too... Let us know if you find an alternative please...
Post by dcoke22 » Thu Feb 19, 2026 4:06 pm
Someone will surely provide binaries of the GUI version for Apple Silicon.
It looks like MacPorts is doing it now: https://ports.macports.org/port/mkvtoolnix/
I mostly use the command line version of the MKVToolNix tools. I install them via Homebrew and on my Apple Silicon Macs they run an up-to-date Apple Silicon native version of the tools.
HrUtrolig
Post by HrUtrolig » Mon Jun 22, 2026 5:40 am
It is Apple Silicon binary:
MakeMKV v1.18.4 [darwin(arm64-release)]
Latest available version:
1.18.3
Website URL:
http://www.makemkv.com/
AndrewJ
Post by AndrewJ » Fri Jun 26, 2026 7:51 pm
Konten wrote: Thu Feb 19, 2026 8:31 am
Some good news on that front.
2026-05-24: macOS binaries: Thanks to the huge amount of work by two community members, corticalcode & touchstone64 (Graham Thompson), we will once again provide macOS binaries (DMGs) for releases 98 and newer. Both have improved the macOS build system significantly, implemented building ARM binaries in addition to Intel binaries (this includes a Universal DMG) and fixing bugs they come across while doing so. I'm very grateful for their work, and the MKVToolNix community as a whole is better off.
