Public KeyDB Disc Submissions
Disc type: UHD
Disc ID: c555715912619c9803036bbf97bc5a2d6bbd24d9
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_1_1B54.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Both MKB_RO.inf and the Disc dump are available in the shared folder at the link.
https://1drv.ms/f/c/e22048a991875da6/Ig ... 0?e=BpPwNb
Disc type: UHD
Disc ID: 251ef05ee0ced79b6d50b0d38861aca6fb8b950c
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_2_6290.tgz
Drive: BD-RE BU40N
https://1drv.ms/f/c/e22048a991875da6/Ig ... A?e=Zupejh
This was released today, so the public keydb doesn't have them.
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
Here's a dump for Zombieland UHD
Hope I've done this right and thank you in advance.
https://drive.google.com/file/d/1U7kiAp ... =drive_web
Disc type: UHD
Disc dump filename: MKB20_v82_Safe_House_-_UHD_DECF.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1AFq6XC ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1b3tNDS ... sp=sharing
keydb_helper
Thanks dougy, the DECF variant of Safe House has been added to the public keydb.
Re: Public KeyDB Disc Submissions - All The President's Men & The Dead Criterion - aacs2./cv.82
Apologies as I am new to the forum so if this has been covered I would greatly appreciate someone guiding me through this issue.
I have the Dead on criterion and All the President's Men 4k's that when attempting to open just says "cannot open disc" I am using libredrive mode
The problem seems to be linked to aacs2./cv.82 protection. I am up to date with 1.18.3.
Any help would be greatly appreciated.
JERisBRISK
Interesting. My drive (also a BU40N with 1.03) reported differently, e.g.:BulldogK9 wrote: Wed Feb 18, 2026 6:23 am Disc type: UHD
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
- disc1 was called ...PART_1_C2F6.tgz (via MakeMKV 1.18.3), with ID 0x32d6762cac4718765246be6319d23832361fb333 (per KeyDB Helper)
Is it common for releases to have different checksums and disc IDs? (I suppose they would across regional boundaries, but then discs often have different release dates in different regions...)
Yes, it is common that there are many different pressings that have different discID and a different 4 characters at the end of the dump file.JERisBRISK wrote: Wed Feb 18, 2026 10:51 pmInteresting. My drive (also a BU40N with 1.03) reported differently, e.g.:BulldogK9 wrote: Wed Feb 18, 2026 6:23 am Disc type: UHD
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
JERisBRISK
I suppose since they hash/checksum differently, the KeyDB needs submissions of each so that it can be kept up to date with all the various pressings?MartyMcNuts wrote: Wed Feb 18, 2026 10:58 pm Yes, it is common that there are many different pressings that have different discID and a different 4 characters at the end of the dump file.
I believe that existing keys can be used to derive my TRON Ares variant. However, I'm not able to process the disc and have not found instructions on how to do it. My windows box is not playing nice with my optical drives because reasons. My MacOS drive is doing well for many titles, but not that one. I just downloaded a new keydb and things are sitll failing.
foo@Foo-MacBook-Air MakeMKV % ls
_private_data.tar keydb.cfg.bak screen.conf
keydb_eng.zip MKB20_v77_POSSESSION_UHD_42CB.tgz settings.conf
keydb.cfg MKB20_v77_TRON-_ARES_8CF9.tgz update.conf
foo@Foo-MacBook-Air MakeMKV % unzip keydb_eng.zip
Archive: keydb_eng.zip
replace keydb.cfg? [y]es, [n]o, [A]ll, [N]one, [r]ename: N
foo@Foo-MacBook-Air MakeMKV % mv keydb.cfg keydb.cfg.bk2
inflating: keydb.cfg
foo@Foo-MacBook-Air MakeMKV % cp keydb.cfg KEYDB.cfg
cp: KEYDB.cfg and keydb.cfg are identical (not copied).
MakeMKV:
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Saved AACS dump file as /Users/phil/Library/MakeMKV/MKB20_v77_TRON-_ARES_8CF9.tgz
Please advise
MakeMKV:
Please advise
keydb_helper wrote: Tue Feb 17, 2026 2:52 pm Thanks to everyone who followed the template and provided new disc dump files. The following discs have been added to the public keydb (new media keys are indicated with an asterisk):As the public keydb continues to grow, there are an increasing number of UHD media keys which can be used to derive complete keydb records for similar disc variants. I strongly recommend Windows users take the time to try SamuriHL's KeyDBTool as it would've derived & submitted the variant-specific keys and avoided the need to post the following titles:Code: Select all
*MKB20_v60_GODS_OF_EGYPT_9D8A *MKB20_v77_Halloween_2_2605 *MKB20_v77_Halloween_3_9639 *MKB20_v77_Se7en_8EE7 *MKB20_v77_The_Rocky_Horror_Picture_Show_6ACC *MKB20_v82_Double_Impact_F1E0 *MKB20_v82_Nobody_2_ABD2AverageMean wrote: Mon Feb 16, 2026 5:29 pm Disc dump filename: MKB20_v77_STAR_TREK-_THE_MOTION_PICTURE_-_DIRECTOR'S_EDITION_57D7bladerunner911 wrote: Mon Feb 16, 2026 2:06 pm Disc dump filename: MKB20_v82_All_the_President's_Men_77E8FootFungus07 wrote: Mon Feb 16, 2026 11:58 pm Disc dump filename: MKB20_v82_Richard_Pryor_Here_and_Now_F9ED.tgz
Yes, correct. MakeMKV also requires these dumps for it's internal hashed keys database, so don't forget to email them to svq@makemkv.comJERisBRISK wrote: Wed Feb 18, 2026 11:35 pmI suppose since they hash/checksum differently, the KeyDB needs submissions of each so that it can be kept up to date with all the various pressings?MartyMcNuts wrote: Wed Feb 18, 2026 10:58 pm Yes, it is common that there are many different pressings that have different discID and a different 4 characters at the end of the dump file.
Re: Ben-Hur 4K Dump
Please help. See attached dump. BenHur 4k release
MakeMKV v1.18.2 win(x64-release) started
The new version 1.18.3 is available for download at http://www.makemkv.com/download/
Using LibreDrive mode (v06.3 id=7FC45AF98B4B)
Downloading latest HK to C:\Users\.MakeMKV ...
Saved AACS dump file as C:\Users\.MakeMKV/MKB20_v82_Ben-Hur_(1959)_Part_1_C2F6.tgz
Saved AACS dump file as C:\Users\Brian\.MakeMKV/MKB20_v82_Ben-Hur_(1959)_Part_2_6290.tgz
I guess reading the first post in this thread is no longer in fashion huh?
CampbellsChunky
Disc type: UHD
Disc dump filename: MKB20_v76_Akira_D8FB.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1c2Nlgm ... sp=sharing
Disc dump link: https://drive.google.com/file/d/14XrPen ... sp=sharing
Drive: BD-RE BU40N
Disc type: UHD
Disc dump filename: MKB20_v82_The_Doors_7D88.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
Limewire: https://limewire.com/d/t3WdO#MLEgRkZYl1
keydb_helper
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
I believe all other valid submissions have also been processed.
For future reference, the disc ID is the SHA-1 hash of the Unit_Key_RO.inf file from each disc. For your two discs the expected values were 0x3B1972EA7E5F4AD158DBB6FC52729A4BD2A35137 and 0x24F08F816CE30532833EE0D08B1066359EBA8101
*MKB20_v77_SISU_ROAD_TO_REVENGE_3FFA
*MKB20_v82_DANCER_IN_THE_DARK_71C4
*MKB20_v82_Poltergeist_II_-_Die_andere_Seite_57AE
*MKB20_v82_The_Doors_7D88
*MKB20_v82_Ugly_Stepsister_UHD
Hey Rays1, AACS 2.1 isn't a priority for the public keydb at this time. MakeMKV also doesn't utilise the public keydb for AACS 2.1 titles, so the benefit of any additions would be limited.Rays1 wrote: Wed Feb 18, 2026 10:33 am Here's a dump for Zombieland UHD
Hey Brian, I know you were trying to contribute but your post wasn't very helpful. Both of your discs were added to the public keydb on February 6. Please try to read the opening post of this thread as it contains links to some helpful instructions and the submission template.
Hey BulldogK9, thanks for the submission but as I told Brian the public keydb has included both of those discs since February 6. Please follow the steps linked in the first post of this thread to configure MakeMKV to utilise the public keydb.BulldogK9 wrote: Wed Feb 18, 2026 6:23 am Disc ID: c555715912619c9803036bbf97bc5a2d6bbd24d9
Hey CampbellsChunky, your disc variant has been added to the public keydb. Please do not extract the MKB_RO.inf file from your disc dump file and upload it separately - provide the full file from the disc instead.CampbellsChunky wrote: Thu Feb 19, 2026 1:58 am Disc dump filename: MKB20_v76_Akira_D8FB.tgz
MKB_RO.inf link: ...
Even if you choose to skip the first 123 pages, folks are pretty good about following the template now. I find the idea of posting in a thread after reading essentially none of the existing posts to be a bit odd...SamuriHL wrote: Thu Feb 19, 2026 1:28 am I guess reading the first post in this thread is no longer in fashion huh?
