Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper » Wed Feb 18, 2026 1:06 pm
dougy wrote: Wed Feb 18, 2026 10:37 am Disc dump filename: MKB20_v82_Safe_House_-_UHD_DECF.tgz
Thanks dougy, the DECF variant of Safe House has been added to the public keydb.
Public KeyDB Disc Submissions KeyDB Download
KeyDB Priority List
DPM78
Re: Public KeyDB Disc Submissions - All The President's Men & The Dead Criterion - aacs2./cv.82
Post by DPM78 » Wed Feb 18, 2026 6:11 pm
Apologies as I am new to the forum so if this has been covered I would greatly appreciate someone guiding me through this issue.
I have the Dead on criterion and All the President's Men 4k's that when attempting to open just says "cannot open disc" I am using libredrive mode
The problem seems to be linked to aacs2./cv.82 protection. I am up to date with 1.18.3.
Any help would be greatly appreciated.
JERisBRISK
Post by JERisBRISK » Wed Feb 18, 2026 10:51 pm
BulldogK9 wrote: Wed Feb 18, 2026 6:23 am Disc type: UHD
Disc ID: c555715912619c9803036bbf97bc5a2d6bbd24d9
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_1_1B54.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Both MKB_RO.inf and the Disc dump are available in the shared folder at the link.
https://1drv.ms/f/c/e22048a991875da6/Ig ... 0?e=BpPwNb
Disc type: UHD
Disc ID: 251ef05ee0ced79b6d50b0d38861aca6fb8b950c
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_2_6290.tgz
Drive: BD-RE BU40N
https://1drv.ms/f/c/e22048a991875da6/Ig ... A?e=Zupejh
This was released today, so the public keydb doesn't have them.
Interesting. My drive (also a BU40N with 1.03) reported differently, e.g.:
- disc1 was called ...PART_1_C2F6.tgz (via MakeMKV 1.18.3), with ID 0x32d6762cac4718765246be6319d23832361fb333 (per KeyDB Helper)
Is it common for releases to have different checksums and disc IDs? (I suppose they would across regional boundaries, but then discs often have different release dates in different regions...)
Post by MartyMcNuts » Wed Feb 18, 2026 10:58 pm
JERisBRISK wrote: Wed Feb 18, 2026 10:51 pm
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
Yes, it is common that there are many different pressings that have different discID and a different 4 characters at the end of the dump file.
JERisBRISK
Post by JERisBRISK » Wed Feb 18, 2026 11:35 pm
MartyMcNuts wrote: Wed Feb 18, 2026 10:58 pm Yes, it is common that there are many different pressings that have different discID and a different 4 characters at the end of the dump file.
I suppose since they hash/checksum differently, the KeyDB needs submissions of each so that it can be kept up to date with all the various pressings?
liels
Post by liels » Wed Feb 18, 2026 11:54 pm
I believe that existing keys can be used to derive my TRON Ares variant. However, I'm not able to process the disc and have not found instructions on how to do it. My windows box is not playing nice with my optical drives because reasons. My MacOS drive is doing well for many titles, but not that one. I just downloaded a new keydb and things are sitll failing.
foo@Foo-MacBook-Air MakeMKV % ls
_private_data.tar keydb.cfg.bak screen.conf
keydb_eng.zip MKB20_v77_POSSESSION_UHD_42CB.tgz settings.conf
keydb.cfg MKB20_v77_TRON-_ARES_8CF9.tgz update.conf
foo@Foo-MacBook-Air MakeMKV % unzip keydb_eng.zip
Archive: keydb_eng.zip
replace keydb.cfg? [y]es, [n]o, [A]ll, [N]one, [r]ename: N
foo@Foo-MacBook-Air MakeMKV % mv keydb.cfg keydb.cfg.bk2
inflating: keydb.cfg
foo@Foo-MacBook-Air MakeMKV % cp keydb.cfg KEYDB.cfg
cp: KEYDB.cfg and keydb.cfg are identical (not copied).
MakeMKV:
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Saved AACS dump file as /Users/phil/Library/MakeMKV/MKB20_v77_TRON-_ARES_8CF9.tgz
Please advise
keydb_helper wrote: Tue Feb 17, 2026 2:52 pm Thanks to everyone who followed the template and provided new disc dump files. The following discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v60_GODS_OF_EGYPT_9D8A
*MKB20_v77_Halloween_2_2605
*MKB20_v77_Halloween_3_9639
*MKB20_v77_Se7en_8EE7
*MKB20_v77_The_Rocky_Horror_Picture_Show_6ACC
*MKB20_v82_Double_Impact_F1E0
*MKB20_v82_Nobody_2_ABD2
As the public keydb continues to grow, there are an increasing number of UHD media keys which can be used to derive complete keydb records for similar disc variants. I strongly recommend Windows users take the time to try SamuriHL's KeyDBTool as it would've derived & submitted the variant-specific keys and avoided the need to post the following titles:
AverageMean wrote: Mon Feb 16, 2026 5:29 pm Disc dump filename: MKB20_v77_STAR_TREK-_THE_MOTION_PICTURE_-_DIRECTOR'S_EDITION_57D7
PConnors wrote: Mon Feb 16, 2026 2:08 pm Disc dump filename: MKB20_v77_The_Dead_Zone_6C69.tgz
liels wrote: Tue Feb 17, 2026 12:04 am Disc dump filename: MKB20_v77_TRON-_ARES_8CF9.tgz
bladerunner911 wrote: Mon Feb 16, 2026 2:06 pm Disc dump filename: MKB20_v82_All_the_President's_Men_77E8
polygonbronson wrote: Tue Feb 17, 2026 2:23 am MKB20_v82_F1_FBFB.tgz
FootFungus07 wrote: Mon Feb 16, 2026 11:58 pm Disc dump filename: MKB20_v82_Richard_Pryor_Here_and_Now_F9ED.tgz
Post by MartyMcNuts » Thu Feb 19, 2026 12:52 am
JERisBRISK wrote: Wed Feb 18, 2026 11:35 pm
Yes, correct. MakeMKV also requires these dumps for it's internal hashed keys database, so don't forget to email them to svq@makemkv.com
briang
Re: Ben-Hur 4K Dump
Post by briang » Thu Feb 19, 2026 12:59 am
Please help. See attached dump. BenHur 4k release
MakeMKV v1.18.2 win(x64-release) started
The new version 1.18.3 is available for download at http://www.makemkv.com/download/
Using LibreDrive mode (v06.3 id=7FC45AF98B4B)
Downloading latest HK to C:\Users\.MakeMKV ...
Saved AACS dump file as C:\Users\.MakeMKV/MKB20_v82_Ben-Hur_(1959)_Part_1_C2F6.tgz
Saved AACS dump file as C:\Users\Brian\.MakeMKV/MKB20_v82_Ben-Hur_(1959)_Part_2_6290.tgz
Post by SamuriHL » Thu Feb 19, 2026 1:28 am
I guess reading the first post in this thread is no longer in fashion huh?
CampbellsChunky
Post by CampbellsChunky » Thu Feb 19, 2026 1:58 am
Disc type: UHD
Disc dump filename: MKB20_v76_Akira_D8FB.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1c2Nlgm ... sp=sharing
Disc dump link: https://drive.google.com/file/d/14XrPen ... sp=sharing
Tok72
Post by Tok72 » Thu Feb 19, 2026 9:02 am
Disc type: UHD
Disc dump filename: MKB20_v82_The_Doors_7D88.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
Limewire: https://limewire.com/d/t3WdO#MLEgRkZYl1
keydb_helper
Post by keydb_helper » Thu Feb 19, 2026 11:19 am
Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v77_SISU_ROAD_TO_REVENGE_3FFA
*MKB20_v82_DANCER_IN_THE_DARK_71C4
*MKB20_v82_Poltergeist_II_-_Die_andere_Seite_57AE
*MKB20_v82_The_Doors_7D88
*MKB20_v82_Ugly_Stepsister_UHD
I believe all other valid submissions have also been processed.
Rays1 wrote: Wed Feb 18, 2026 10:33 am Here's a dump for Zombieland UHD
Hope I've done this right and thank you in advance.
Hey Rays1, AACS 2.1 isn't a priority for the public keydb at this time. MakeMKV also doesn't utilise the public keydb for AACS 2.1 titles, so the benefit of any additions would be limited.
briang wrote: Thu Feb 19, 2026 12:59 am Please help. See attached dump. BenHur 4k release
Hey Brian, I know you were trying to contribute but your post wasn't very helpful. Both of your discs were added to the public keydb on February 6. Please try to read the opening post of this thread as it contains links to some helpful instructions and the submission template.
BulldogK9 wrote: Wed Feb 18, 2026 6:23 am Disc ID: c555715912619c9803036bbf97bc5a2d6bbd24d9
Hey BulldogK9, thanks for the submission but as I told Brian the public keydb has included both of those discs since February 6. Please follow the steps linked in the first post of this thread to configure MakeMKV to utilise the public keydb.
For future reference, the disc ID is the SHA-1 hash of the Unit_Key_RO.inf file from each disc. For your two discs the expected values were 0x3B1972EA7E5F4AD158DBB6FC52729A4BD2A35137 and 0x24F08F816CE30532833EE0D08B1066359EBA8101
CampbellsChunky wrote: Thu Feb 19, 2026 1:58 am Disc dump filename: MKB20_v76_Akira_D8FB.tgz
MKB_RO.inf link: ...
Hey CampbellsChunky, your disc variant has been added to the public keydb. Please do not extract the MKB_RO.inf file from your disc dump file and upload it separately - provide the full file from the disc instead.
SamuriHL wrote: Thu Feb 19, 2026 1:28 am I guess reading the first post in this thread is no longer in fashion huh?
Even if you choose to skip the first 123 pages, folks are pretty good about following the template now. I find the idea of posting in a thread after reading essentially none of the existing posts to be a bit odd...
KeyDB Priority List
Post by SamuriHL » Thu Feb 19, 2026 11:44 am
Odd and supremely unhelpful. It doesn't get them the help they desire and just wastes time.
Rays1
Post by Rays1 » Thu Feb 19, 2026 8:41 pm
keydb_helper wrote: Thu Feb 19, 2026 11:19 am Thanks to everyone who followed the template and provided new disc dump files. The following UHD discs have been added to the public keydb (new media keys are indicated with an asterisk):
Got it! And thanks for the heads up. I looked in to aacs and figured out that i just have to switch the disk out and get a new one. I would of never known about aacs not being supported had you not told me. Reading through 124 pages is rather daunting, but I must admit after submitting my request I realized I didn't follow the format. Problem is a also don't know where all that information comes from to fill the proper request. However i did do the vuk update thing and that worked like a charm on the new predator I just got last night so I should be good to go. Gonna try another copy of zombieland from a different source. Thank you again for helping out. Definitely not trying to waste anyone's time here.
UhhNewUser
Post by UhhNewUser » Fri Feb 20, 2026 3:24 am
TOP_GUN
Disc type: BD-ROM UHD
Disc ID: 2AA34B6F5B75ADFB22CE0F8885A966B895A7F1F5
Disc dump filename: MKB20_v72_Top_Gun_D5AB.tgz
Drive: BD-RE WH16NS40
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): Copied from disc into disk dump
Disc dump link: https://www.dropbox.com/scl/fi/zbl3fyie ... evbip&dl=0
TOP_GUN_MAVERICK
Disc ID: A3385703677D62623E50503DB79F714A5A9F2E37
Disc dump filename: MKB20_v76_Top_Gun-_Maverick_D817.tgz
Disc dump link: https://www.dropbox.com/scl/fi/1dnycpgg ... 1ty5y&dl=0
