Public KeyDB Disc Submissions
keydb_helper
Post by keydb_helper »
MSCloude115 wrote:
Wed Feb 18, 2026 4:10 am
Sorry about that, I went into Google Drive and changed the access settings to public so you should be good now!
No worries, thanks for the quick follow up. The 262C variant of Five Nights at Freddy's 2 has been added to the public keydb.
user76419 wrote:
Wed Feb 18, 2026 4:15 am
Disc dump filename: MKB20_v76_SCREAM_454D.tgz
user76419 wrote:
Wed Feb 18, 2026 4:16 am
Disc dump filename: MKB20_v77_SCREAM_3_8451.tgz
Hey user76419, thanks again for taking the time to incorporate the full MKB_RO.inf file into the disc dump. Both discs have been added to the public keydb.
AverageMean wrote:
Tue Feb 17, 2026 10:21 pm
Disc dump filename: MKB20_v77_STAR_TREK_V-_THE_FINAL_FRONTIER_EF79
Thanks AverageMeanMedianMode, your disc has been added to the public keydb.
These two discs have also been added to the public keydb:
MKB20_v77_Obi-Wan_Kenobi-_The_Complete_Series_Disc_2_B307
mkb20_v82_day_of_the_animals_0a2a
BulldogK9 wrote:
Wed Feb 18, 2026 1:49 am
Submitted dump files for
Ben Hur 4k Disc 1 and 2. (It's 4K, but still split over 2 discs!)
Hey BulldogK9, please don't post in this thread to say that you've sent disc dump files somewhere. This thread is for posting links to disc dump files. If you haven't already, I'd recommend following the instructions here to setup the public keydb as it is possible that your discs are already supported.
If either of your Ben-Hur discs aren't currently supported by the public keydb, feel free to follow the template in the opening post and submit the details here.
BulldogK9
Post by BulldogK9 »
Disc type: UHD
Disc ID: c555715912619c9803036bbf97bc5a2d6bbd24d9
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_1_1B54.tgz
Drive: BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
Both MKB_RO.inf and the Disc dump are available in the shared folder at the link.
https://1drv.ms/f/c/e22048a991875da6/Ig ... 0?e=BpPwNb
Disc type: UHD
Disc ID: 251ef05ee0ced79b6d50b0d38861aca6fb8b950c
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_2_6290.tgz
Drive: BD-RE BU40N
https://1drv.ms/f/c/e22048a991875da6/Ig ... A?e=Zupejh
This was released today, so the public keydb doesn't have them.
Rays1
Post by Rays1 »
Here's a dump for Zombieland UHD
Hope I've done this right and thank you in advance.
https://drive.google.com/file/d/1U7kiAp ... =drive_web
dougy
Post by dougy »
Disc type: UHD
Disc dump filename: MKB20_v82_Safe_House_-_UHD_DECF.tgz
Drive: ASUS BW-16D1HT
Drive firmware: 3.10
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1AFq6XC ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1b3tNDS ... sp=sharing
keydb_helper
dougy wrote:
Wed Feb 18, 2026 10:37 am
Thanks dougy, the DECF variant of Safe House has been added to the public keydb.
DPM78
Re: Public KeyDB Disc Submissions - All The President's Men & The Dead Criterion - aacs2./cv.82
Post by DPM78 »
Apologies as I am new to the forum so if this has been covered I would greatly appreciate someone guiding me through this issue.
I have the Dead on criterion and All the President's Men 4k's that when attempting to open just says "cannot open disc" I am using libredrive mode
The problem seems to be linked to aacs2./cv.82 protection. I am up to date with 1.18.3.
Any help would be greatly appreciated.
JERisBRISK
Post by JERisBRISK »
BulldogK9 wrote:
Wed Feb 18, 2026 6:23 am
Disc type: UHD
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
Interesting. My drive (also a BU40N with 1.03) reported differently, e.g.:
- disc1 was called ...PART_1_C2F6.tgz (via MakeMKV 1.18.3), with ID 0x32d6762cac4718765246be6319d23832361fb333 (per KeyDB Helper)
Is it common for releases to have different checksums and disc IDs? (I suppose they would across regional boundaries, but then discs often have different release dates in different regions...)
JERisBRISK wrote:
Wed Feb 18, 2026 10:51 pm
Disc type: UHD
Drive: BD-RE BU40N
Disc type: UHD
Drive: BD-RE BU40N
Yes, it is common that there are many different pressings that have different discID and a different 4 characters at the end of the dump file.
JERisBRISK
MartyMcNuts wrote:
Wed Feb 18, 2026 10:58 pm
I suppose since they hash/checksum differently, the KeyDB needs submissions of each so that it can be kept up to date with all the various pressings?
liels
Post by liels »
I believe that existing keys can be used to derive my TRON Ares variant. However, I'm not able to process the disc and have not found instructions on how to do it. My windows box is not playing nice with my optical drives because reasons. My MacOS drive is doing well for many titles, but not that one. I just downloaded a new keydb and things are sitll failing.
foo@Foo-MacBook-Air MakeMKV % ls
_private_data.tar keydb.cfg.bak screen.conf
keydb_eng.zip MKB20_v77_POSSESSION_UHD_42CB.tgz settings.conf
keydb.cfg MKB20_v77_TRON-_ARES_8CF9.tgz update.conf
foo@Foo-MacBook-Air MakeMKV % unzip keydb_eng.zip
Archive: keydb_eng.zip
replace keydb.cfg? [y]es, [n]o, [A]ll, [N]one, [r]ename: N
foo@Foo-MacBook-Air MakeMKV % mv keydb.cfg keydb.cfg.bk2
inflating: keydb.cfg
foo@Foo-MacBook-Air MakeMKV % cp keydb.cfg KEYDB.cfg
cp: KEYDB.cfg and keydb.cfg are identical (not copied).
MakeMKV:
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Saved AACS dump file as /Users/phil/Library/MakeMKV/MKB20_v77_TRON-_ARES_8CF9.tgz
Please advise
keydb_helper wrote:
Tue Feb 17, 2026 2:52 pm
Thanks to everyone who followed the template and provided new disc dump files. The following discs have been added to the public keydb (new media keys are indicated with an asterisk):
*MKB20_v60_GODS_OF_EGYPT_9D8A
*MKB20_v77_Halloween_2_2605
*MKB20_v77_Halloween_3_9639
*MKB20_v77_Se7en_8EE7
*MKB20_v77_The_Rocky_Horror_Picture_Show_6ACC
*MKB20_v82_Double_Impact_F1E0
*MKB20_v82_Nobody_2_ABD2
As the public keydb continues to grow, there are an increasing number of UHD media keys which can be used to derive complete keydb records for similar disc variants. I strongly recommend Windows users take the time to try SamuriHL's KeyDBTool as it would've derived & submitted the variant-specific keys and avoided the need to post the following titles:
AverageMean wrote:
Mon Feb 16, 2026 5:29 pm
Disc dump filename: MKB20_v77_STAR_TREK-_THE_MOTION_PICTURE_-_DIRECTOR'S_EDITION_57D7
PConnors wrote:
Mon Feb 16, 2026 2:08 pm
Disc dump filename: MKB20_v77_The_Dead_Zone_6C69.tgz
liels wrote:
Tue Feb 17, 2026 12:04 am
Disc dump filename: MKB20_v77_TRON-_ARES_8CF9.tgz
bladerunner911 wrote:
Mon Feb 16, 2026 2:06 pm
Disc dump filename: MKB20_v82_All_the_President's_Men_77E8
polygonbronson wrote:
Tue Feb 17, 2026 2:23 am
MKB20_v82_F1_FBFB.tgz
FootFungus07 wrote:
Mon Feb 16, 2026 11:58 pm
Disc dump filename: MKB20_v82_Richard_Pryor_Here_and_Now_F9ED.tgz
JERisBRISK wrote:
Wed Feb 18, 2026 11:35 pm
Yes, correct. MakeMKV also requires these dumps for it's internal hashed keys database, so don't forget to email them to svq@makemkv.com
briang
Re: Ben-Hur 4K Dump
Post by briang »
Please help. See attached dump. BenHur 4k release
MakeMKV v1.18.2 win(x64-release) started
The new version 1.18.3 is available for download at http://www.makemkv.com/download/
Using LibreDrive mode (v06.3 id=7FC45AF98B4B)
Downloading latest HK to C:\Users\.MakeMKV ...
Saved AACS dump file as C:\Users\.MakeMKV/MKB20_v82_Ben-Hur_(1959)_Part_1_C2F6.tgz
Saved AACS dump file as C:\Users\Brian\.MakeMKV/MKB20_v82_Ben-Hur_(1959)_Part_2_6290.tgz
Post by SamuriHL »
I guess reading the first post in this thread is no longer in fashion huh?
CampbellsChunky
Post by CampbellsChunky »
Disc type: UHD
Disc dump filename: MKB20_v76_Akira_D8FB.tgz
Drive: BD-RE BU40N
MKB_RO.inf link: https://drive.google.com/file/d/1c2Nlgm ... sp=sharing
Disc dump link: https://drive.google.com/file/d/14XrPen ... sp=sharing
Tok72
Post by Tok72 »
Disc type: UHD
Disc dump filename: MKB20_v82_The_Doors_7D88.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
Limewire: https://limewire.com/d/t3WdO#MLEgRkZYl1
