HashCheck Error on some UHD backups
Bergriese
Post by Bergriese »
Dear fellow enthusiasts,
First of all, many thanks to this amazing community for your outstanding work and tireless dedication.
I am currently experiencing a “HashCheck Error” with the backup of two UHD titles:
FURIOSA_A_MAD_MAX_SAGA
TRON_ARES
The drive is an LG BH16NS55.AHLU10B flashed with WH16NS60-1.02.
Does anyone have a tip? Other UHD titles are working fine.
I would appreciate any support.
Best regards,
Bergriese
Laufwerksinformation
OS-Gerätename: E:
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE WH16NS60
Revision: 1.02
Serienummer: KLUP1GK3029
Firmware-Datum: 2118-10-29 19:36
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 82
Firmware version: 1.02
Disk-Informationen
Label: FURIOSA_A_MAD_MAX_SAGA
Zeitstempel: 2024-07-03 09:30:26
Schutz: AACS2.0/C v77
Datenkapazität: 88.72 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 3
Markierungen der Bus-Verschlüsselung: 80
Re: HashCheck Error on some UHD backups
Post by SamuriHL »
Clean the discs. Hash check failures means the data wasn't read correctly off the disc.
Bergriese
Post by Bergriese »
Thank for the fast response.
That was the first thing I tried based on the initial forum search results. I also have a second identical Tron Ares UHD available, and it had the same problem. I also tested a second identical drive.
Post by SamuriHL »
Don't know what to tell you. Hash Check errors are because the data wasn't read correctly from the disc. So it's either a disc issue or a drive issue.
its just the joys of an lg
i found you need to also power them off when they do this they can get into a weird mode where they will do it on everything until turned off.
you should also clean the disc
i recommend a damp lint free cloth and dry immediately with another to avoid water spots
Bergriese
Post by Bergriese »
Thank you.
Knowing that the LG drive remains in a faulty state after a HashCheck error until it is powered off completely helped.
