Sentai Filmworks Discs No longer Opening
BlueManGroup
Post by BlueManGroup » Thu Mar 08, 2012 3:03 am
I've tried and failed to open Ef- A Tale of Melodies and DreamEater Merry from Sentai Filmworks, both Region A US releases. Running a registered version of MakeMKV 1.7.2 on Mac OS X 10.7.3. These titles are both pre-release, but final product. Just to be clear, it's not that it won't rip, it won't even open the disc to allow me to rip it, it just hangs when I hit the Open icon after a few seconds of decrypting.
celavey
Re: Sentai Filmworks Discs No longer Opening
Post by celavey » Thu Mar 08, 2012 6:03 am
Hi there. I didn't know that I am not the only one who have this type of problem. Were you able to fix it on your end?
BlueManGroup
Post by BlueManGroup » Thu Mar 08, 2012 12:42 pm
celavey wrote:Hi there. I didn't know that I am not the only one who have this type of problem. Were you able to fix it on your end?
Nope. :(
Post by Woodstock » Fri Mar 09, 2012 3:52 pm
Would you happen to have the older Sentai BD title "Samurai Girls" from August 2011 to test? It works fine on MakeMKV 1.70 and later (just tested it on 1.72) for Windows.
It would be interesting to see if this is a difference between Windows and Mac, or if it is something new Sentai is doing.
Post by mike admin » Mon Mar 12, 2012 8:51 am
BlueManGroup wrote:I've tried and failed to open Ef- A Tale of Melodies and DreamEater Merry from Sentai Filmworks, both Region A US releases. Running a registered version of MakeMKV 1.7.2 on Mac OS X 10.7.3. These titles are both pre-release, but final product. Just to be clear, it's not that it won't rip, it won't even open the disc to allow me to rip it, it just hangs when I hit the Open icon after a few seconds of decrypting.
Are you opening a disc? Do you use "Open disc" command (the big button, or from menu) or "Open file"?
BlueManGroup
Post by BlueManGroup » Mon Mar 12, 2012 10:44 pm
"Open Disc" from the button, not "Open File" from the menu. It just hangs while trying to decrypt.
bonkabonka
Post by bonkabonka » Wed Mar 14, 2012 2:25 am
For what it's worth, I let it churn away on ef - a tale of melodies for about an hour after which it reported that it couldn't handle a newer version of AACS. I submitted the code from disk 1 and am waiting for MakeMKV to give up on disk 2 so I can report that one also.
BlueManGroup
Post by BlueManGroup » Wed Mar 14, 2012 6:36 pm
bonkabonka wrote:For what it's worth, I let it churn away on ef - a tale of melodies for about an hour after which it reported that it couldn't handle a newer version of AACS. I submitted the code from disk 1 and am waiting for MakeMKV to give up on disk 2 so I can report that one also.
That's odd, because I'd left mine going for about an hour and a half and absolutely nothing occurred.I had to force quit out of the program to get it to stop.
bonkabonka
Post by bonkabonka » Wed Mar 14, 2012 8:08 pm
I happen to be using Linux and while the program didn't seem to be doing anything, the timers did continue to tick up. Disk 2 took about 50 minutes before MakeMKV gave up and bailed.
BlueManGroup
Post by BlueManGroup » Wed Mar 14, 2012 11:09 pm
Well, yeah, the elapsed time kept increasing, but nothing else happened. That was after an hour and a half.
BlueManGroup
Post by BlueManGroup » Wed Mar 21, 2012 11:19 am
I Just received Infinite Stratos: The Complete Collection. It's a pre-release, street date April 10. It has the same issue as the previous Sentai Filmworks discs.
Mnemos
Post by Mnemos » Mon Mar 26, 2012 12:27 am
makemkv 1.7.2 can decrypt these Sentai Filmworks release just fine:
Samurai Girls (2011-08-23) has AACS v24
Ef a Tale of Memories (2012-01-31) has AACS v28
Broken Blade (2012-02-21) has AACS v28
But it fails with these:
Ef a Tale of Melodies (2012-03-20) has AACS v31
Dream Eater Merry (2012-03-27) has AACS v31
Infinite Stratos (2012-04-10) has AACS v31
The changelog for makemkv 1.7.2 says that it added support for AACS v30, so I would assume that the problem is that it doesn't support AACS v31 yet, and Sentai Filmworks upgraded to it with their most recent releases.
Post by mike admin » Wed Mar 28, 2012 7:16 am
For each disc, make an ENCRYPTED full disc backup with MakeMKV. From the backup send two files - MKB_RO.inf and discatt.dat to support@makemkv.com . In return you'll get instructions how to open this disc with current version of MakeMKV.
