Zombieland UHD
Photozone
Zombieland UHD
Post by Photozone » Wed Feb 18, 2026 8:45 am
Hey everyone,
I have a Zombieland UHD that I'd like to back up.
I don't know why, but the *.tgz file is about 35MB and it's not getting any smaller, even after several attempts.
How would you recommend sending this file? I tried sending it via Google Drive, but I don't think anyone will open the link.
Any suggestions?
Re: Zombieland UHD
Post by MartyMcNuts » Wed Feb 18, 2026 9:26 am
Photozone wrote: Wed Feb 18, 2026 8:45 am Hey everyone,
Any suggestions?
If it is AACS 2.1 and the dump ends in CC8A or 1C8C it can't be backed up.
viewtopic.php?f=12&t=20549
There's other threads too.
Photozone
Re: Zombieland UHD
Post by Photozone » Wed Feb 18, 2026 9:33 am
Thanks for the reply.
The file name is MKB21_v70_Zombieland_0C05.tgz but with 35.653kb in size.
So it should be possible, I think?
Re: Zombieland UHD
Post by MartyMcNuts » Wed Feb 18, 2026 9:39 am
Photozone wrote: Wed Feb 18, 2026 9:33 am Hi,
In that linked thread, someone emailed the tgz dump back in 2022, so if the key is still unknown 4 years later, then I'd say the 0C05 variant is another one that can't be backed up.
finneus_
Re: Zombieland UHD
Post by finneus_ » Sat Aug 01, 2026 11:27 am
It seems i have the same 4k Version of Zombieland 0C05 i was hoping to be able to rip it someday but maybe im out of luck. Have be satisfied with the 1080p version for now.
g4mbl3
Re: Zombieland UHD
Post by g4mbl3 » Fri Aug 21, 2026 3:54 pm
So i got the 2-Movie Collection and Zombieland Double Tap was no problem but sadly i too have the 0C05 version of Zombieland.
Before i buy another Version of the Movie, has anyone found a version that worked? Preferably on the european market and ideally german market?
Tok72
Re: Zombieland UHD
Post by Tok72 » Mon Aug 24, 2026 7:09 pm
I had to buy a secondhand copy from Half Priced Books that thankfully had the old key. Unfortunately there’s no way of knowing which key your disc has until you try to rip it or possibly inspect the ring code. (No I don’t know if there’s a difference in the ring codes but I would suspect there is).
