LG Original Firmware Flashers (to return to original firmware)
Re: LG Original Firmware Flashers (to return to original firmware)
#16 Post by MartyMcNuts » Tue Feb 17, 2026 9:47 pm
Konten wrote:
Tue Feb 17, 2026 4:09 pm
Thanks so much for these, Marty!! It's really appreciated!! :D
Will the BP50NB40 1.03 firmware work for a BP55EB40 SVC: EB52 as well?
These original flashers only work for that particular model, so no.
hansolo
#17 Post by hansolo » Wed Feb 18, 2026 6:48 am
Just curious, probably won't ever need these original flashers. My BH16NS55 is crossflashed to WH16NS60. If I ever was to downgrade to original FW, which original flasher should I use. 55 or 60? I assume 55 or is workflow first crossflash back to 55 and then apply original 55 flasher?
LG BH16NS55 (crossflashed w/ WH16NS60 1.02MK) in external enclosure
LG BU40N (1.03MK) in external enclosure
LG BU40N (original 1.00)
Verbatim #43888 (Pioneer BDR-UD04 FW1.14)
Pioneer BDR-208D (crossflashed w/ BDR-S11JX/BDR-211)
zittrig
#18 Post by zittrig » Wed Feb 18, 2026 7:25 am
There's a LG universal flashing tool which recognize the right model or firmware by itself.
#19 Post by MartyMcNuts » Wed Feb 18, 2026 7:35 am
Well you didn't say which original firmware. If you want to go back to original NS55 firmware, you would first have to flash a NS55 MK version that is lower than the original NS55 flasher firmware version, then use the NS55 original flasher.
hansolo
#20 Post by hansolo » Wed Feb 18, 2026 9:48 am
Yes thanks. I meant back to original NS55, which the drive label states it is :mrgreen: .
Would this tool know what is the truly original if the drive was crossflashed.
zittrig
#21 Post by zittrig » Wed Feb 18, 2026 10:03 am
I can't say it just now. Check it out, it will talk to you before you can start the flashing process.
It could be that it recognize the WH16NS60-Firmware and will take this as base for the flashing.
If you're unsure with useing the tool I can test it later after work with a BH16NS55 @ WH16NS60 1.02MK and report back here.
Or Marty can say it here right now with a lot more of expierience.
#22 Post by MartyMcNuts » Wed Feb 18, 2026 10:45 am
No, it would go by what the firmware is on the drive. If NS60 firmware, it would think the drive is a NS60.
Konten
#23 Post by Konten » Thu Feb 19, 2026 8:21 am
Thanks, Marty!! If you ever happen to come into possession of the original BP55 firmware, please do post it… :D
#24 Post by MartyMcNuts » Sun Feb 22, 2026 10:13 pm
Hi everyone,
If anyone is looking for the original BU40N 1.05 firmware, here is the official LG Updater exe.
https://www.mediafire.com/file_premium/ ... r.zip/file
Only use this to restore your BU40N back to the original 1.05 firmware. This firmware is not UHD enabled!
OneDay
#25 Post by OneDay » Mon Feb 23, 2026 5:01 am
Hi
Just was wondering if anyone had the original WH16NS60 firmware 1.01? Thanks
