No, the drive is fine. Try providing some info about what actually happens when ripping. Are yo getting read errors? Something else? Copy and paste the MakeMKV log window text.threeballspin wrote: Thu Jan 08, 2026 7:51 pmSorry. Bit of a noob. I tried to rip a disk but it didn't work. So I thought I needed to do something to the drive.MartyMcNuts wrote: Wed Jan 07, 2026 11:52 pm Why are you posting this? Your drive is already UHD capable. Nothing to do. Just insert a UHD disc and start ripping.
Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
Re: Pioneer BD-RW BDR-XD07 - Troubleshooting 4kUHD discs not reading
offgridmedia
Hi, can I get some help making this 4k capable?
OS device name: F:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number:
Firmware date: 2019-09-05
Bus encryption flags: 13
Drive platform: RS8D30
Firmware version: 1.02
OS device name: F:
Revision: 1.02
Serial number:
PM sent.offgridmedia wrote: Fri Feb 13, 2026 5:14 pm Hi, can I get some help making this 4k capable?
OS device name: F:
Revision: 1.02
Serial number:
offgridmedia
Thank you!
Coopervid wrote: Fri Feb 13, 2026 5:36 pmPM sent.offgridmedia wrote: Fri Feb 13, 2026 5:14 pm Hi, can I get some help making this 4k capable?
OS device name: F:
Revision: 1.02
Serial number:
jcormac
Howdy all - I'm in the same boat as others I believe.
Revision: 1.02
Serial number: SJDL005725UC
Highest AACS version: 82
Would be interested in using MKV to read UHD discs.
Revision: 1.02
sure email me that makemkv drive info section see below for emailjcormac wrote: Wed Feb 18, 2026 4:14 am Howdy all - I'm in the same boat as others I believe.
Revision: 1.02
all others no need to post your pioneer info just email me directly
TheSupercomputer
Hello to all,
I'm new to all of this but I just found this thread and hope someone can help me.
I have the same Problem as the original Post, discs starts to spin up and stops after a short amount of time, that repeats a few times and than "No Disc inserted" appears.
Is there a way to get UHD discs to work without installing Windows first?
I have an old enough firmware on the drive but I only use Linux, all what I found was for windows only.Drive Information
OS device name: /dev/sr0
Revision: 1.02
Serial number: TCDL001966WL
Highest AACS version: 68
Pioneer flasher is windows only butTheSupercomputer wrote: Wed Jul 22, 2026 9:47 am Hello to all,
Revision: 1.02
You can use a VM
