Public KeyDB Disc Submissions
Grahamdoh
Post by Grahamdoh »
New UK Eureka Blu-ray's
Jakob the Liar
Zen and Sword: The Miyamoto Mushashi Saga Discs 1-3
https://drive.google.com/drive/folders/ ... drive_link
Mikeismad
Post by Mikeismad »
SamuriHL wrote: Tue Feb 17, 2026 5:56 pm
Mikeismad wrote: Tue Feb 17, 2026 4:26 pm Ok thanks for the feedback. I placed the file in the correct directory and now and it is seeing it, but I'm still getting the same error. Then when I reviewed the Disc ID entry it says "NOTVALIDATED". Could this be the issue?
That has nothing to do with it. But I'm telling you right now, "I placed the file in the correct directory and now and it is seeing it" <-- No. You wouldn't know if it's "seeing it" or not. The only way to know that is if it opens a disc that was previously giving you the key issue that then opens once the keydb.cfg is updated. So your premise is incorrect about MakeMKV "seeing it". It's not.
Ok so when I tried to run this from the MakeMKV console, I thought this meant that since the Host Keys automatic download failed that it was looking al the KEYDB.cfg file instead. If this is not the case, I'm going to try to get this work on my Windows machine instead.
/tmp # ls -l /root/.config/aacs/KEYDB.cfg
-rwxr--r-- 1 root root 62330000 Feb 17 10:06
/tmp # /opt/makemkv/bin/makemkvcon -r info disc:0
MSG:1005,0,1,"MakeMKV v1.18.3 linux(x64-release) started","%1 started","MakeMKV v1.18.3 linux(x64-release)" DRV:0,2,999,12,"BD-RE ASUS BW-16D1HT 3.10 KLFN7EB0918","PEE WEES BIG ADVENTURE","/dev/sr0"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
MSG:1011,0,1,"Using LibreDrive mode (v06.3 id=0FA242DD4D0B)","%1","Using LibreDrive mode (v06.3 id=0FA242DD4D0B)" MSG:3007,0,0,"Using direct disc access mode","Using direct disc access mode"
MSG:5050,0,2,"Evaluation version, 30 day(s) out of 30 remaining","Evaluation version, %1 day(s) out of %2 remaining","30","30"
MSG:5085,0,0,"Loaded content hash table, will verify integrity of M2TS files.","Loaded content hash table, will verify integrity of M2TS files."
MSG:3338,0,2,"Downloading latest HK to /root/.MakeMKV ...","Downloading latest %1 to %2 ...","HK","/root/.MakeMKV" MSG:3339,0,1,"Automatic HK downloading is disabled or failed.","Automatic %1 downloading is disabled or failed.","HK" MSG:3332,16908288,2,"Saved AACS dump file as file:///root/.MakeMKV/MKB20_v82_PEE-WEE'S_BIG_ADVENTURE_4301.tgz","Saved %1 dump file as %2","AACS","file:///root/.MakeMKV/MKB20_v82_PEE-WEE'S_BIG_ADVENTURE_4301.tgz" MSG:3303,16777216,0,"The volume key is unknown for this disc - video can't be decrypted","The volume key is unknown for this disc - video can't be decrypted"
MSG:5010,0,0,"Failed to open disc","Failed to open disc" TCOUNT:0
keydb_helper
Post by keydb_helper »
Mikeismad wrote: Tue Feb 17, 2026 8:49 pm
The KEYDB.cfg file needs to go in the same directory as your generated disc dump files. In your case, this means you'll need to copy /root/.config/aacs/KEYDB.cfg to /root/.MakeMKV/KEYDB.cfg
bladerunner911 wrote: Tue Feb 17, 2026 4:20 pm Thanks keydb_helper for the note about SamuriHL's KeyDBTool, I did actually use this first, but didn't realise it could be used in the way you suggested - still pretty new at this ;-) sorry for wasting time and bandwidth!
My 'All The President's Men' UHD disk is now being read in makemkv correctly, so all good.
Thanks to everyone for making these tools and being so helpful! 8)
No worries! I'm glad to hear you are now able to process your disc and you have an additional option for future titles.
AverageMean wrote: Tue Feb 17, 2026 5:45 pm Is there a Mac friendly version of this tool?
Hey AverageMean, unfortunately I don't think there is a native Mac option for FindVUK. I believe Linux users have been able to get it working to some extent via Wine, but I don't recall reading a similar report for macOS. Please feel free to continue posting disc dump files as often as you can.
Mikeismad
Post by Mikeismad »
keydb_helper wrote: Tue Feb 17, 2026 9:18 pm
Thanks, I finally got it working!
Post by SamuriHL »
Mikeismad wrote: Tue Feb 17, 2026 8:49 pm Ok so when I tried to run this from the MakeMKV console, I thought this meant that since the Host Keys automatic download failed that it was looking al the KEYDB.cfg file instead. If this is not the case, I'm going to try to get this work on my Windows machine instead.
Additionally to what you were told above which is absolutely correct, the automatic download is for the MakeMKV hashed keys which is how MakeMKV acquires its own keys. The KeyDB is a completely separate entity that has nothing to do with the automated HK downloads. Meaning, even if the HK downloads were successful, if the key is not known to MakeMKV yet, the KeyDB would still be used. And finally, I would fix the automatic download issue. It's likely DNS related or it's turned off in your MakeMKV settings. That way you can source keys from both MakeMKV HK and the KeyDB at the same time, giving you the best chance to decrypt all your titles going forward.
Mikeismad
Post by Mikeismad »
SamuriHL wrote: Tue Feb 17, 2026 9:38 pm
Thanks, I appreciate the explanation. I'm going to look into the automatic download issue now.
AverageMean
Post by AverageMean »
Disc type: UHD
Disc ID: 20d90f77f0145920018058a71aa682acca80b9c9
Disc dump filename: MKB20_v77_STAR_TREK_V-_THE_FINAL_FRONTIER_EF79
Drive: BD-RE HL-DT-ST BD-RE BU40N
Drive firmware: 1.03
LibreDrive status: Enabled
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://www.dropbox.com/scl/fi/r4xzzvgz ... x45a4&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/3se19aa7 ... xvm9v&dl=0
BulldogK9
Post by BulldogK9 »
Submitted dump files for
Ben Hur 4k Disc 1 and 2. (It's 4K, but still split over 2 discs!)
UhhNewUser
Post by UhhNewUser »
OBI_WAN_KENOBI_COMPLETE_DISC_2
Disc type: BD-ROM UHD
Disc ID: b39a0c5822c15f42b8312a41a36cd5631bb588e9
Disc dump filename: MKB20_v77_Obi-Wan_Kenobi-_The_Complete_Series_Disc_2_B307.tgz
Drive: BD-RE WH16NS40
Drive firmware: 2115-12-11 14:59
MKB_RO.inf link: https://www.dropbox.com/scl/fi/a1hfysop ... bpvpw&dl=0
Disc dump link: https://www.dropbox.com/scl/fi/kws7iq50 ... 4mg18&dl=0
MSCloude115
Post by MSCloude115 »
Here's the dump for Five Nights at Freddy's 2 UHD.
MKB20_v82_Five_Nights_at_Freddy's_2_262C.tgz
https://drive.google.com/file/d/1i7NsUe ... share_link
keydb_helper
MSCloude115 wrote: Wed Feb 18, 2026 3:09 am Here's the dump for Five Nights at Freddy's 2 UHD.
Thanks MSCloude115, but your link is not publicly accessible so it cannot be downloaded or processed. Please generate a new link when you get a chance and verify that it is accessible in private browsing/incognito mode before posting it here.
MSCloude115
keydb_helper wrote: Wed Feb 18, 2026 3:42 am
Sorry about that, I went into Google Drive and changed the access settings to public so you should be good now!
https://drive.google.com/file/d/1i7NsUe ... sp=sharing
user76419
Post by user76419 »
Disc type: UHD
Disc ID: 06318e09a2aaeb7973a5bd86c15ccb97c7d18e18
Disc dump filename: MKB20_v76_SCREAM_454D.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): N/A (included in disk dump)
Disc dump link: https://www.mediafire.com/file/niwgcyyj ... D.tgz/file
Thank you!
user76419
Post by user76419 »
Disc type: UHD
Disc ID: 56c5270271312360330a5f4e29109921c91b76c8
Disc dump filename: MKB20_v77_SCREAM_3_8451.tgz
Disc dump link: https://www.mediafire.com/file/9240kt5l ... 1.tgz/file
Thank you!
keydb_helper
MSCloude115 wrote: Wed Feb 18, 2026 4:10 am Sorry about that, I went into Google Drive and changed the access settings to public so you should be good now!
No worries, thanks for the quick follow up. The 262C variant of Five Nights at Freddy's 2 has been added to the public keydb.
user76419 wrote: Wed Feb 18, 2026 4:15 am Disc dump filename: MKB20_v76_SCREAM_454D.tgz
user76419 wrote: Wed Feb 18, 2026 4:16 am Disc dump filename: MKB20_v77_SCREAM_3_8451.tgz
Hey user76419, thanks again for taking the time to incorporate the full MKB_RO.inf file into the disc dump. Both discs have been added to the public keydb.
AverageMean wrote: Tue Feb 17, 2026 10:21 pm Disc dump filename: MKB20_v77_STAR_TREK_V-_THE_FINAL_FRONTIER_EF79
Thanks AverageMeanMedianMode, your disc has been added to the public keydb.
These two discs have also been added to the public keydb:
mkb20_v82_day_of_the_animals_0a2a
BulldogK9 wrote: Wed Feb 18, 2026 1:49 am Submitted dump files for
Hey BulldogK9, please don't post in this thread to say that you've sent disc dump files somewhere. This thread is for posting links to disc dump files. If you haven't already, I'd recommend following the instructions here to setup the public keydb as it is possible that your discs are already supported.
If either of your Ben-Hur discs aren't currently supported by the public keydb, feel free to follow the template in the opening post and submit the details here.
