comadose
Post by comadose » Sat Feb 14, 2026 9:18 am
sgtstrife wrote: Fri Feb 13, 2026 11:49 pm I had a SH216 set up thanks to this forum a few years ago. It died from too much ripping, ha. I bought a BDR-212V and just now got around to getting it set up. However, I've lost most of my knowledge over that time. I tried poking around on this forum but it seems like most problems are getting fixed via PM's. Can someone help me get this set up?
OS device name: E:
Current profile: DVD-ROM
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: XXXXXXXXXXXXX
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 72
Firmware version: ID06
For Pioneer drives try cdrinfo.pl, if you ask nicely they will send you some free firmware that you can flash easily enough.
CrashRoseRed
Post by CrashRoseRed » Sun Feb 15, 2026 12:11 am
Hello
I am lookning for a 4h blueray ripping drive
dose any one know if something like
ASUS BW-16D1H-U PRO
ASUS BW-16D1X-U
wud work for ripning 4k bluerays
if not can anyone recement a drive that can do it that i wud be anabel to buy because i cant relly get my hands on any new drivers any more and the only seller that ship internationally it out of stuck
Post by Billycar11 » Sun Feb 15, 2026 12:39 am
CrashRoseRed wrote: Sun Feb 15, 2026 12:11 am Hello
ASUS BW-16D1H-U PRO
ASUS BW-16D1X-U
they are the same get whatever is cheaper
zittrig
Post by zittrig » Sun Feb 15, 2026 6:47 am
ASUS BW-16D1H-U PRO
ASUS BW-16D1X-U
The H-U includes a stand for the enclosure, the X-U doesn't.
zittrig
Post by zittrig » Sun Feb 15, 2026 6:50 am
comadose wrote: Sat Feb 14, 2026 9:18 am
OS device name: E:
Revision: 1.02
Then please go back to cdrinfo.pl and leave us alone with your "smart" advices .....
Mr_Orange
Post by Mr_Orange » Sun Feb 15, 2026 9:41 am
zittrig wrote: Sun Feb 15, 2026 6:50 am
OS device name: E:
Revision: 1.02
He's just giving people another option. Given the cost of the drives now, not having to pay another USD40 on top would appeal.
comadose
Post by comadose » Sun Feb 15, 2026 10:05 am
I can get the drives quite cheap too, around 15-20 Euro sometimes. I didn't realize they were in demand, but next time I'll stock up and sell them on cheaply. I just want people to be able to rip and preserve this media.
I ended up with 3 drives myself. Bought the second one because I forgot to bring the first one on a trip, it was about 10 Euro a couple of years ago. Bought the third one in December because it was USB C and meant one fewer cables to carry with me, for about 15 Euro. Flashed them for free.
They often appear in thrift/second hand stores.
KCHawkeye02
Post by KCHawkeye02 » Sun Feb 15, 2026 7:36 pm
MartyMcNuts wrote: Tue Jan 13, 2026 5:59 am
lokat wrote: Tue Jan 13, 2026 3:45 am Hello, also new here.
Can't say that flashing is a straightforward process ...
I just got a WP50NB40 ( only drive I could find at my local microcenter )
and after running makeMKV I got the following
Product: BD-RE WP50NB40
Revision: 1.03
Firmware date: 2121-07-08 16:09
I got the All You Need Firmware Pack (MartyMcNuts) pack
and I'm bit confused with the next step
My understanding is that I need to go to
DE_LG_WP50NB40-NB50_1.03_MK.bin
and then to
DE_LG_BP60NB10_1.02-MK.bin
is that the correct assumption ? I did not fully grasp the concept of SVC ( and if it's relevant here )
Any guidance would be much appreciated
Thanks in advance :)
Yes, the SVC code is relevant. If SVC NB52 (look at the sticker underneath the drive), follow the steps in the first post (or the gif), substituting BP50NB40 for WP50NB40. I have pasted them below for you.
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
After a successful flash to the MK firmware of the drive do the crossflash:
2. Select the RECOVERY option and in the pop up window (as per the window title text), select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed and click OPEN.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 (this is what I recommend) firmware in the normal firmware selection drop box (as per the window title text) then click OPEN.
4. Click START
Perfect.
tthousand
Post by tthousand » Mon Feb 16, 2026 7:42 pm
Hi All,
... Better late than never. Thought I would finally get around to backing up my UHDs, and I am very upset to hear I waited too long, and now the pioneer drives are becoming hard to find.
If I was able to acquire a PIONEER BLU-RAY BURNER BDR-XD05B, would I be able to flash it and rip my collection? [I do not have it yet, but it is safe to assume it is unused. Also has a MFR date of Nov 2018]
Post by Coopervid » Mon Feb 16, 2026 8:10 pm
tthousand wrote: Mon Feb 16, 2026 7:42 pm Hi All,
You need to post your Makemkv info.
tthousand
Post by tthousand » Mon Feb 16, 2026 8:27 pm
Coopervid wrote: Mon Feb 16, 2026 8:10 pm
I do not have it yet. I was hoping to get an answer before I acquire it.
The only thing I know is the manufacturer date is November 2018, and it appears to be unused.
tthousand
Post by tthousand » Mon Feb 16, 2026 9:25 pm
I have two more questions...
One, I just flashed my BP50NB40 to HL-DT-ST-BD-RE_BP60NB10-1.02-NM00800-212005070935.bin. Is that the one I should be using? Or is there another, better firmware I should be using?
Two, my brother has a BP50NB40 that was manufactured on October 22, 2024. Would he be able to flash this drive, or no?
Post by Billycar11 » Tue Feb 17, 2026 12:18 am
tthousand wrote: Mon Feb 16, 2026 9:25 pm I have two more questions...
That one is fine
tthousand
Post by tthousand » Tue Feb 17, 2026 3:39 pm
With the drive below, would I just follow the same method listed in the guide, or is there a different guide to use? Or is there a different path I should use than the one below?
WP/BP50NB40 to > BP50NB40-NB50-1.03MK then to > BP60NB10 1.02MK or 1.00MK
OS device name: G:
Product: BD-RE BP50NB40
Revision: 1.03
Serial number: SIM21218G5049
Firmware date: 2121-07-08 16:03
Highest AACS version: 81
Harware support: Yes
Firmware support: No
Firmware version: 1.03
mazgaoten
Post by mazgaoten » Tue Feb 17, 2026 3:48 pm
Do we have any known working Slimline enclosures that aren't listed in the first post? Not finding those in stock.
