2011 Captain America
ncarusojr
Post by ncarusojr »
I'm tring to make a copy of 2011 Captain America. It has been recording for 2 Hrs and has 4 Hrs to go. It has never taken this long to record a BD. I checked the disc before I put it in and it is clean. I recorded a BD yesterday and there was no problem with my drive. Any ideas on why it would take so long. The drive is reading at 0.2x.
crowfax
Re: 2011 Captain America
Post by crowfax »
Not all damage can be seen. Try cleaning the disc with a soft cloth, if that doesn't fix it then return it for a new one.
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
ncarusojr
Post by ncarusojr »
Re cleaned the disc and it is still recording very slowly. It plays perfectly.
crowfax
Post by crowfax »
Playing and ripping are not the same thing.
Your drive is having a hard time reading the disc.
Your drive might be failing, or the disc is poorly manufactured / damaged / dirty.
ncarusojr
Post by ncarusojr »
Went and exchanged the disc for a new one and it was the same result. It did rip but took a grand total of 8 hrs 5 mins.
ncarusojr
Post by ncarusojr »
crowfax
Post by crowfax »
Your drive may be dying, or the shop you purchased from has received a bad batch of discs. I had to return sherlock Holmes 4 times before I got a "good" disc.
setarip_old
Post by setarip_old »
@ncarusojr
Hi!
Try using the same procedure with the same drive and same disc (that had NO problem) - and see if it now exhibits the same problematic behavior as your "Captain America" disc does/did...
ncarusojr
Post by ncarusojr »
Tried Moneyball this morning and it ripped as expected. No issues and in about 40 minuets. It's not the drive. Captain America just gave me the problem and on two brand new disc's. Weird!
