Hi.
Has anyone bought drives from AliExpress that look like a Pioneer Drive? Are they genuine?
Example:
https://aliexpress.com/item/1005009227614908.html
Pioneer Drives from Aliexpress
Re: Pioneer Drives from Aliexpress
Many fakes, be very careful and expect to be scammed.boguslecina wrote: Sat Feb 14, 2026 5:52 pm Hi.
Example:
kaysee
Try asking if they will accept a batch of sealed, expired COVID19 test kits with new fake dates on them for a fake blu-ray drive.
boguslecina
WTF?kaysee wrote: Sun Feb 15, 2026 12:04 am Try asking if they will accept a batch of sealed, expired COVID19 test kits with new fake dates on them for a fake blu-ray drive.
boguslecina
I suspected possible fakes, so I preferred to ask.Coopervid wrote: Sat Feb 14, 2026 10:04 pmMany fakes, be very careful and expect to be scammed.boguslecina wrote: Sat Feb 14, 2026 5:52 pm Hi.
Example:
zittrig
I risked a Pioneer BDR-UD03 and a LG BU40N in a enclosure.
Both are on it way.
Let's see ....
Both are on it way.
Let's see ....
zittrig
The LG drive in the enclosure arrived.
First check: Contains a BU50N.
Great stuff for 59,99 Euro and shipping takes from February, 23rd to 28th. (shipped to work, so today was the first view)
Next step: awaiting the BDR-UD03 ....
zittrig
The BDR-UD03 arrived yesterday. Works perfectly as an UD04.
Migaman
What was the manufacture date on the drives and did they appear to be heavily used?
My main concern with buying these (apart from being fake) would be that they were already heavily used and are close to failing.
zittrig
Mfc was 2018 and it looks like new. But I would doubt that all UD03 from the same supplier will come from the same batch in these days.Migaman wrote: Thu Mar 05, 2026 8:53 amWhat was the manufacture date on the drives and did they appear to be heavily used?
My main concern with buying these (apart from being fake) would be that they were already heavily used and are close to failing. T
AzureVex
zittrig could you post links to the sellers you bought from?
zittrig
Try it:
BDR-UD03:
https://de.aliexpress.com/item/10050092 ... in_prod%3A
BU40N / BU50N in enclosure:
Can't find the link. Perhaps the seller stopped the offer, sorry.
There are other offer with similar specs, but other sellers.
BDR-UD03:
johannu
How to check if a purchased BDR-UD03 from Aliexpress is fake or not?
zittrig
Ask the seller what you want known e.g..
Then trust or trust not. Try or try not.
