Recommended Drives for (Blu-ray) Recovery
kaysee
Re: Recommended Drives for (Blu-ray) Recovery
Post by kaysee »
I use ddrescue with USB adapters (only), and it is fine. Two of my adapters are Unitek, and they are good for full capabilities -- reporting drive information and for flashing. I also have a Benfei, and it behaves the same, though without the requirement for the USB connection to the host or hub being powered. The above MakeMKV information is incomplete, so either the drive or the adapter connection is not reporting everything. Have you established the specific model of the internal drive unit?
CartridgeUnit
Post by CartridgeUnit »
kaysee wrote:I use ddrescue with USB adapters (only), and it is fine. Two of my adapters are Unitek, and they are good for full capabilities -- reporting drive information and for flashing. I also have a Benfei, and it behaves the same, though without the requirement for the USB connection to the host or hub being powered. The above MakeMKV information is incomplete, so either the drive or the adapter connection is not reporting everything. Have you established the specific model of the internal drive unit?
Technically, no. I probably need to remove the metal case? I think it might have been re-cased in China. Unless there is info on the back near the SATA ports, similar to that thread I mentioned earlier? (I'm not at home right now. I'll be able to look at it later tonight tho.)
Sent from my LE2115 using Tapatalk
CartridgeUnit
Here's photos of the top...
Last edited by CartridgeUnit on Sun Feb 15, 2026 4:02 am, edited 2 times in total.
CartridgeUnit
...and back.
CartridgeUnit
Okay. I had to eventually connect the drive to a PC directly via it's SATA. Bypassing the Unitek adapter. Turns out the chip in the adapter was preventing me from reading all the drive data. Here is the output from connecting the drive via SATA:
OS device name: E:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: KLTP55G5647
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
tommik128
Post by tommik128 »
That is the new version of BW-16D1HT. It is LibreDrive capable btw. They are discontinued now I am pretty sure. Last pieces manufactured around June/July(?) 2025.
CartridgeUnit
tommik128 wrote:That is the new version of BW-16D1HT. It is LibreDrive capable btw. They are discontinued now I am pretty sure. Last pieces manufactured around June/July(?) 2025.
Oh nice! That's good to know. Yeah, I bought an eSATAp setup as a more permanent solution for my PC and we'll see how that works. But yeah, it definitely looks like the chip on the Unitek adapter was the problem for DDrescue. It can still be used to RIP discs though.
