undefined symbol OSSL_BN_nnmod
kerryland
Post by kerryland »
Hi Folks,
When I try to rip "Contagion" or "In Time" (New Zealand flavours) makemkv fails with:
symbol lookup error: /usr/bin/makemkvcon: undefined symbol: OSSL_BN_nnmod
I am running version 1.7.2.
It reports that it is using a disk-specific SVQ from 00000027.svq.
I have looked high and low, but cannot find a log file anywhere.
There is a dump_In_Time_B9236874349FF010.tgz file, but it is zero bytes large.
Mine is a registered copy of MakeMKV, if that means anything.
Anything I can do to help?
Re: undefined symbol OSSL_BN_nnmod
Post by mike admin »
What OS are you using? If my guess is correct and you're on Linux, then it means that you somehow ended up with an outdated libmakemkv.so
kerryland
Post by kerryland »
Yes I'm on Linux. How do I fix this?
kerryland wrote:Yes I'm on Linux. How do I fix this?
Reinstall the latest version. To be sure, delete all occurrences of libmakemkv.so on your system.
kerryland
Post by kerryland »
Thanks for your help -- all sorted now!
