SDF update November 2025
kaysee
Re: SDF update November 2025
#181 Post by kaysee » Fri Feb 13, 2026 12:28 pm
InigoMontoya wrote: Fri Feb 13, 2026 5:35 am So I'm thinking about buying a UHD blu ray burner from ebay (shipping from china)
Firmware is pre 12/2022, and its a UHD model. Here's the info. Its a Pioneer BDR-S11JX drive.
The seller in China actually sent you the MakeMKV information about the drive?
zittrig
#182 Post by zittrig » Fri Feb 13, 2026 12:54 pm
kaysee wrote: Fri Feb 13, 2026 12:28 pm
I can imagine that some sellers are aware of their wrong playing competitors and this could be a way to to differentiate theirself.
And with the ebay buyer protection could it be a good and safe deal.
nicholfd
#183 Post by nicholfd » Fri Feb 13, 2026 4:16 pm
InigoMontoya wrote: Fri Feb 13, 2026 5:35 am So I'm thinking about buying a UHD blu ray burner from ebay (shipping from china), but I want to be sure that it'll rip UHD disks. This whole thing is a little confusing and I just want to double check before I make the purchase. From what I can tell, this one should do the trick. Firmware is pre 12/2022, and its a UHD model. Here's the info. Its a Pioneer BDR-S11JX drive.
Manufacturer: PIONEER
Product: BD-RW BDR-S11
Revision: 1.53
Serial number:
Firmware date: 2020-08-03
Drive platform: RS8800
Firmware name: PIONEER BDR-211
Firmware version: 1.53/ID43
Any help would be greatly appreciated!
Be cautious of buying a drive from China, especially on eBay. Seller could have found that MakeMKV drive info text from many places online & just re-used or copied/pasted it.
Since Pioneer stopped making drives 1st of 2025, there are a lot of fake/re-labeled drives coming from China & available on eBay. Make sure you have "free" returns (they don't try to make you pay to return it to China) or have some type of buyer protection.
Thanks,
Frank
InigoMontoya
#184 Post by InigoMontoya » Sun Feb 15, 2026 10:14 pm
Yea. I was as shocked as you are.
nicholfd wrote: Fri Feb 13, 2026 4:16 pm
Thanks,
Frank
They sent an actual image of the drive information from their computer. But I mean that could obviously be fake as well. Thanks for the tip.
Billycar11 wrote: Fri Feb 13, 2026 6:58 am
that drive can be flashed to do UHD email me that drive info section
Ok great. Was hoping to avoid flashing since its marked as a UHD drive, but Id just be happy to get a drive that works. I'm still deciding whether or not I'm going to buy it as its a bit expensive, but I will definitely reach out to you if I end up purchasing it. Thank you so much!
danieboy
#185 Post by danieboy » Thu May 07, 2026 6:42 pm
HI,
Not sure if this is the correct place (probably not knowing me :D ) . I have been off the site for a while as my blu-ray as far as i know at the time was not able to play 4K or UHD discs.
Is this still the case for (as I seem to be reading it might now work) :-
However I have tried and the drive just spits it out, and i missing something.
OS device name: F:
Product: BD-RW BDR-XS07
Revision: 1.03
Serial number: CIDL007703WL
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 72
Drive platform: RS8E20
Firmware version: 1.03
#186 Post by Billycar11 » Thu May 07, 2026 10:36 pm
danieboy wrote: Thu May 07, 2026 6:42 pm HI,
OS device name: F:
Revision: 1.03
sure email me that info and all others email me no need to post your info here publicly just reach out to me directly
see below for email
I can give you early access to the 12/22+ fw flasher
vivianne
#187 Post by vivianne » Mon Jun 01, 2026 4:11 pm
CmdrKodi wrote: Tue Dec 02, 2025 12:46 am My BDR-212U has stopped working.
I know the firmware is too recent to allow UHDs, but it was working fine for bluray/dvd until 1.18.2. Now I can't get it to work at all. I've tried manually installing sdf.bin. I've tried completely removing my .MakeMKV directory and starting over. Nothing works. Drive reports its information (below), so I know it's still alive in some sense. But inserting a blu ray causes a the light to blink a few times and then the drive icon just spins forever.
Fedora Linux 36
MakeMKV 1.18.2 (also tried 1.18.1, known good release with blu ray that worked before).
Product: BD-RW BDR-212U
Revision: 1.04
Serial number:
Firmware date: 2022-12-20
Drive platform: Pioneer RS8F01
Firmware version: ID83
I can't get it to dump the firmware, or I'd send it in. Just guessing, but is this drive model close enough to one that works to cause the wrong firmware to be loaded? I guess I could be unlucky enough that I've had a hardware failure that coincides with upgrading makemkv, but I'm doubtful.
I have an older drive that continues to work fine:
Revision: 1.01
Serial number:
Firmware date: 2020-07-21
Drive platform: RS8F01
Firmware version: 1.01/ID58
Any guesses?
I can confirm I have the exact same issue with a BDR-212U unit, all the symptoms are the exact same. On latest MakeMKV.
OS device name: /dev/sr1
Revision: 1.04
Serial number:
Highest AACS version: 81
#188 Post by Billycar11 » Mon Jun 01, 2026 9:51 pm
vivianne wrote: Mon Jun 01, 2026 4:11 pm
Fedora Linux 36
Revision: 1.04
Serial number:
Revision: 1.01
Serial number:
Any guesses?
Revision: 1.04
Serial number:
you could update to 1.05 and see if it works
https://pioneer.jp/device_e/product-e/i ... 12UBK,2023
tomty89
#189 Post by tomty89 » Tue Jun 02, 2026 10:26 am
vivianne wrote: Mon Jun 01, 2026 4:11 pm Drive platform: Pioneer RS8F01
Btw, is this one of those BDR-212UHBK from/for the Japan market instead of BDR-212UBK?
EDIT: Ahh looks like my guess is correct: https://www.cdrinfo.pl/artykuly/artykul ... 12English/
P.S. Btw the firmware (updater that includes the kernel) can be downloaded at https://www.st-trade.co.jp/support/download/. No idea if that's what it takes for mike to add the support though.
duopduop
#190 Post by duopduop » Sun Sep 06, 2026 12:14 pm
Hello, could you please help me?
I have a Pioneer optical drive – the drive included in the Sharp Blu-ray recorder – which was custom-made by Pioneer for Sharp.
Operating System Device Name: K:
Current configuration file: BD-R SRM
Product: BD-RW BDR-L13SH
Revised Version: 1.18
Serial Number: 139*************
Firmware date: 2021-01-22
Status: Feasible, but not yet enabled
Drive Platform: Pioneer RS8C00
Firmware Version: ID92
CD Information
Tag: THE_WANDERING_EARTH_II_2023_CHN_UHD_DISC_1
Timestamp: 2024-11-16 17:41:21
Data capacity: 69.30 GB
When playing discs with high bitrates, the playback speed is limited to approximately 2X.
The power-off and reboot operations have all been performed.
Request assistance to enable LibreDrive status.thanks very much!
Sayaka
#191 Post by Sayaka » Sun Sep 06, 2026 3:03 pm
@Billycar11 and @Coopervid, please feel free to correct me if I am mistaken, but I *seriously* doubt this drive is LibreDrive-flashable.
#192 Post by Billycar11 » Mon Sep 07, 2026 1:07 am
currently it cant do it
it likely is possible with help from mike
Sayaka
#193 Post by Sayaka » Mon Sep 07, 2026 1:43 am
Thank you for clarifying, Billy.
#194 Post by Coopervid » Tue Sep 08, 2026 10:37 pm
duopduop wrote: Sun Sep 06, 2026 12:14 pm Hello, could you please help me?
CD Information
We would need to know if there is an equivilant hardware version of a Pioneer drive. 8C00 suggests that it might be a 212 that has 8F00 but that's a wild guess.
duopduop
#195 Post by duopduop » Sat Sep 12, 2026 12:16 pm
Coopervid wrote: Tue Sep 08, 2026 10:37 pm
CD Information
Thank you for your interest!
I found this information in this post: Re: LibreDrive for Pioneer drives
by Hucz89 » Mon Aug 10, 2026 3:49 amDrive Information
Product: BD-RW BDR-212BK
Revision: 1.04
Firmware version: ID81
here is "RS8F00" – you also replied to him "PM sent". I hope this helps!
In my previous response, I attached the file `_private_data.tar` and `dump_FW_8152DE9C96E59E781B87.tgz` – these two files are only 2 KB and 1 KB in size; it's unclear whether they still have any value.I have sent these two files to "support@makemkv.com"; my email address is duopduop@outlook.com
