nicholfd
#1861
Post
by nicholfd » Thu Feb 12, 2026 4:06 am
litlucky wrote: Thu Feb 12, 2026 3:43 am
nicholfd wrote: Thu Feb 12, 2026 3:23 am
litlucky wrote: Thu Feb 12, 2026 3:01 am
Am I good to start ripping uhd?
Manufacturer: PIONEER
Product: BD-RW BDR-XD06U
Revision: 1.11
Serial number:
Firmware date: 2017-06-22
Highest AACS version: 77
Drive platform: RS8B30
Firmware name: PIONEER BDR-XS06
Firmware version: 1.11/ID69
Wouldn't it be better to try, than asking?
I did and it failed. I got Billycar’s flash for the drive, i did it but then it didn’t rip the uhd movie.
It's a good idea to always include relevant info (flashed it. tried UHD. failed.) in the original post...
"It failed" - error message or log? What happened? Post that relevant info also.
litlucky
#1862
Post
by litlucky » Thu Feb 12, 2026 4:42 am
nicholfd wrote: Thu Feb 12, 2026 4:06 am
Can I just email you with those pictures and information? My screenshots/images aren’t uploading to the reply.
Sr. Chalice
#1863
Post
by Sr. Chalice » Thu Feb 12, 2026 7:05 am
Can't seem to get this one to work. Anyone out there have luck with this drive and unlocking it for UHD operating. The help would be much appreciated.
OS device name: L:
Product: BD-RW BDR-212M
Revision: 1.01
Serial number:
Firmware date: 2020-07-21
Highest AACS version: 58
Drive platform: RS8F00
Firmware version: 1.01/ID56
#1864
Post
by Billycar11 » Thu Feb 12, 2026 7:51 am
Sr. Chalice wrote: Thu Feb 12, 2026 7:05 am
OS device name: L:
Revision: 1.01
Serial number:
yeah email me for the flasher to make it do UHD
easteregg7492
#1865
Post
by easteregg7492 » Thu Feb 12, 2026 10:29 am
I just realized I had a Pioneer BDR-XD05S in storage. I believe based on my research here that it is UHD capable, but might require a firmware patch. This is my drive info pulled from the latest version of MakeMKV:
OS device name: F:
Product: BD-RW BDR-XD05
Revision: 3.01
Serial number: QBDL101909UC
Firmware date: 2014-12-26
Highest AACS version: 81
Drive platform: RS8231
Firmware name: PIONEER BDR-XD05
Firmware version: 3.01/ID34
#1866
Post
by Billycar11 » Thu Feb 12, 2026 10:43 am
easteregg7492 wrote: Thu Feb 12, 2026 10:29 am
OS device name: F:
Revision: 3.01
already emailed you
and sent flasher
anyone else feel free to email me for the flasher see below no need to post your drive info here just email it to me
#1867
Post
by Billycar11 » Fri Feb 13, 2026 1:30 am
litlucky wrote: Thu Feb 12, 2026 4:42 am
i already told you what was wrong your drive was not getting enough power and was rebooting no reason to say my stuff does not work
nerdy1
#1868
Post
by nerdy1 » Fri Feb 13, 2026 3:19 pm
I have the Pioneer BDR-XD07. I am posting the MakeMKV info for it. I would like to flash it.
OS device name: H:
Current profile: CD-ROM
Product: BD-RW BDR-XD07
Revision: 1.02
Serial number: THDL015091UC
Firmware date: 2019-09-05
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8D30
Firmware version: 1.02
Disc Information
Data capacity: 0.33 Gb
#1869
Post
by Billycar11 » Fri Feb 13, 2026 3:36 pm
nerdy1 wrote: Fri Feb 13, 2026 3:19 pm
OS device name: H:
Revision: 1.02
Disc Information
Sure just email me that drive info section see below for email
nerdy1
#1870
Post
by nerdy1 » Fri Feb 13, 2026 3:43 pm
Billycar11 wrote: Fri Feb 13, 2026 3:36 pm
OS device name: H:
Revision: 1.02
Disc Information
Email sent. Thanks!
nicholfd
#1871
Post
by nicholfd » Fri Feb 13, 2026 4:05 pm
Billycar11 wrote: Fri Feb 13, 2026 1:30 am
They e-mailed me directly with a screenshot & the output from an attempted rip. Here's my reply:
Your drive can definitely read 4K/UHD discs or you would not have been able to get to the screen to choose titles & start the rip - the flash worked.
You need to do some reading/research on MakeMKV & how to use it - you do not want 13 titles from a movie disc of any type. You only rip the main title, which is the movie. *Maybe* there are some “out-takes” or whatever that you want, but I doubt there are 12 of those on that John Wick disc.
Your results are due to one of two things, 1st most likely:
1. Your drive disconnected during the rip (faulty/flakey USB cable) or you don’t have enough power to the drive for 4K/UHD discs (which causes the drive to power-cycle/disconnect temporarily). For slim-line drives they either require 2 x USB connections for enough power (“Y” USB cable), or an external AC adapter if the unit supports that. If you have 2 x USB connections or are using a USB adapter, try a different USB port on the computer. Some desktop PCs have crappy USB chipsets on some ports as a cost saving measure.
2. You have a defective or dirty discs. I have seen brand new discs purchase from Amazon that were either defective or fake. I have also had new discs that looked perfectly clean from a fresh unwrapped case, that needed to be cleaned. I suspect some of the plastics used in packaging “gas off”, producing a vapor & it leaves a difficult to see coating on the disc. Take a whiff of a new, freshly un-shrink wrapped DVD/Blu-Ray/4K/UHD.
When you figure out which is the cause, please post on the forums so others can learn from your experience & know that you got a good flash kit/upgrade from Billycar11.
Thanks,
Frank
TraubeMinze735
Post
by TraubeMinze735 » Sat Feb 14, 2026 9:04 am
Hello everyone,
could someone share the flash commands and what firmware to use for the BDR-S08XLT?
Thanks in advance!
#1873
Post
by MartyMcNuts » Sat Feb 14, 2026 9:37 am
TraubeMinze735 wrote: Sat Feb 14, 2026 9:04 am
Hello everyone,
Thanks in advance!
There are no flash commands for Pioneer drives. Contact Billycar11.
For UHD enabled drives (AU/NZ/SG + Others) & DIY Single Drive Flasher (WW):
https://uhdenableddrives.com
WhisperInTheSnow
#1874
Post
by WhisperInTheSnow » Sat Feb 14, 2026 11:29 am
Heya! I just got a new drive and was wondetig if its possible to enable UHD on it.
Manufacturer: ASUS
Product: SBC-06D2X-U
Revision: 1.10
Serial number: SHDL137927WL
Firmware date: 2017-04-18
Drive platform: RS8591
Firmware version: 1.10/ID22
#1875
Post
by Billycar11 » Sat Feb 14, 2026 12:48 pm
WhisperInTheSnow wrote: Sat Feb 14, 2026 11:29 am
Manufacturer: ASUS
Revision: 1.10
sure email me that drive info see below for email
