how to play mkv rip on ipad 3?
elephantburger
Post by elephantburger » Wed Mar 21, 2012 12:37 am
I have ipad 3 which has HD resolution. how can i play my MKV files on it?
crowfax
Re: how to play mkv rip on ipad 3?
Post by crowfax » Wed Mar 21, 2012 2:18 am
I'd use something like DVD Catalyst to convert the MKV file from MakeMKV into a format that the iPad3 will play. You'll save space on your device than putting the raw files on it as well. The only downside is it takes a while to turn the MKV file into an MP4 for the iPad3.
lpcmissues
Post by lpcmissues » Wed Mar 21, 2012 3:18 am
I use Goodplayer. Plays all my movies upto 720p smoothly.
twa000
Post by twa000 » Sat Mar 24, 2012 10:04 am
I use XBMC, great and free ..... but you do need to jailbreak first :)
Icanseestars
Post by Icanseestars » Sat Mar 24, 2012 12:38 pm
You cant.
MakeMKV is lossless which means HD MPEG-2, VC-1 or H.264 blu-ray specification video. The iPad only has hardware decoding support for H.264 video nothing else and it will not enable that hardware decoding for H.264 video if it's not in a M4V container. It will fall back to CPU decoding for all media that is not H.264/M4V now while the CPU on the iPad3 is improved there's no way it will play the output from MakeMKV.
Use Handbrake to convert the videos into H.264/M4V and then they will play on the iPad3.
Post by mike admin » Sun Mar 25, 2012 8:21 am
If you have an MKV with H.264 video (majority are) then you only need to transcode the MKV file to mp4 which is very fast, opposing to full re-encode that is very slow.
translux
Post by translux » Sun Mar 25, 2012 6:27 pm
Use AirVideo client/server app.
It converts on the fly and stream to the ipad from inside and outside the LAN.
Works great!
http://itunes.apple.com/us/app/air-vide ... 50020?mt=8
elephantburger
Post by elephantburger » Mon Mar 26, 2012 3:05 am
translux wrote:Use AirVideo client/server app.
Works great!
hi, so will it still look like HD video? will the file be counting toward my internet bandwidth? (20-30GB)
translux
Post by translux » Mon Mar 26, 2012 3:10 am
Works great!
You can set the quality of video and I assume your talking about your LTE bandwidth with from ATT or Verizon?
Yes if you stream outside of your house over LTE it will consume bandwidth if you are on wi-fi no.
BTW I can't believe what they charge for bandwidth-$10 a gig is draconian.
laidbackross
Post by laidbackross » Wed Mar 28, 2012 10:00 pm
New user with iPad 3rd gen, i used MakeMKV to rip a Blu-Ray, tried the mkv file in the "AVPlayerHD" app, sound was fine but video unwatchable, really low laggy framerate.
After searching on google I found a freeware conversion program to turn it into a M4V/MP4 called (unsurprisngly) MkvToMp4:
http://forum.videohelp.com/threads/3406 ... Mkv-to-Mp4
It took just over 2 hours to convert at full 1080P resolution with an i5 laptop.
I then transferred into iTunes and have tested in the native iOS "Videos" app and it works absolutely flawlessly.
This may not be the fastest way to achieve what I think your after but the results are amazing.
The audio was AAC and I have asked the developer whether he would consider the option to encode the audio in ALAC for the full lossless audio.
For reference it went from a 14.3 gb MKV file to a 8.3gb M4V file.
Other programs which seemed to be recommended was rebox.NET and GOTSent although I have no experience of using them, would probably be worth browsing http://www.videohelp.com/ to get exactly what you are after.
Smithcraft
Post by Smithcraft » Thu Mar 29, 2012 8:17 am
Thanks, AVPlayerHD was the app I was thinking of.
SC
DanaK4LK
Post by DanaK4LK » Wed Apr 04, 2012 12:45 am
elephantburger wrote:I have ipad 3 which has HD resolution. how can i play my MKV files on it?
You can use the free HandBrake. It will convert the video to MPEG4 which is playable and manageable by iTunes. Use the High Profile setting for best quality. It takes 4 hours to convert and average movie on my 2011 MacBook Pro.
