I have a Verbatim 43888 with the following drive info. Was not sure because of the manufacturer.
OS device name: D
Product: BD-RE BU40N
Revision: 1.05
S/N :M09PAK92454
Bus Encryption flags: 17
LibreDrive Informayion
Is my Verbatim 43888 flashable
Re: Is my Verbatim 43888 flashable
viewtopic.php?f=16&t=22896&hilit=sdftooltasdisr wrote: Thu Feb 12, 2026 4:44 pm I have a Verbatim 43888 with the following drive info. Was not sure because of the manufacturer.
OS device name: D
Revision: 1.05
S/N :M09PAK92454
Here you go.
avinit
Hi - sorry to hijack.
I have the exact same drive:
Revision: 1.05
Serial number: MOEPAIH1509
Highest AACS version: 61
Can I Confirm the link to the update tool works? Just because BU40N revision 1.05 wasnt specifically listed.
Revision: 1.05
See guide below or email me or Marty for an automated flasheravinit wrote: Thu Mar 05, 2026 9:02 am Hi - sorry to hijack.
Revision: 1.05
avinit
Thanks - worked it out. Used 1.03 MK and worked.
Cheers for the help.
Constantm
I have the same drive and the flashing with the spf tool and version 1.03 worked flawlessly. Thanks for al the work and support!
wdhtx01
After doing this, I was still unable to rip newer UHD releases (4K James Cameron - Aliens, The Abyss, and True Lies all unreadable). I then cross-flashed to HL-DT-ST BD-RE BP60NB10 VERSION 1.0 - (libre-drive enabled). It is now reading the Cameron 4Ks, Aliens and Abyss have now ripped 4K Dolby-vision MKVs. True Lies is just about complete.
reinerzufall
where can i find the v1.0 FW I have the same problems with my drive.
flashed it to v1.03 an have problems with all my udhs.
can you send me a link with the fw?
thanks
thanks
zittrig
Marty's firmware pack is to find here. Check inside the first post.
reinerzufall
hi, I flashed the DE_LG_BU40N_1.03_MK.bin and i have the same issues, I can't read any 4kuhd, make mkv the other files but has problems with the streams.
Then i crossflashed to the DE_LG_BP60NB10_1.00_MK.bin, not better. Now makemkv had the most problems, can't read anything.
Then I flashed back to DE_LG_BU40N_1.03_MK.bin, the flashertool flashed, but the drive didn't accepted that.
The drive is alsways the BP60 with 1.00
How can i flashe it back to a BU40Drive?
Post your Makemkv info and don't panick.reinerzufall wrote: Sat Mar 21, 2026 9:04 pm hi, I flashed the DE_LG_BU40N_1.03_MK.bin and i have the same issues, I can't read any 4kuhd, make mkv the other files but has problems with the streams.
reinerzufall
Do you mean this?
Laufwerksinformation
OS-Gerätename: \Device\CdRom0
Aktuelles Profil: BD-ROM
Produzent: HL-DT-ST
Produkt: BD-RE BP60NB10
Revision: 1.00
Serienummer: MOxxxxxxxxx
Firmware-Datum: 2117-11-21 17:20
Markierungen der Bus-Verschlüsselung: 17
Highest AACS version: 76
Firmware version: 1.00
Disk-Informationen
Label: NO_TIME_TO_DIE
Zeitstempel: 2021-10-13 19:22:58
Schutz: AACS2.0/C v76
Datenkapazität: 92.16 Gb
Disk-Typ: BD-ROM UHD
Anzahl der Layer: 3
Markierungen der Bus-Verschlüsselung: 80
MakeMKV v1.18.3 win(x64-release) gestartet
Using LibreDrive mode (v06.3 id=4ACF8047C3AC)
Disk in Ordner kopieren "C:/Videos/backup/NO_TIME_TO_DIE"
Inhalte-Hashtabelle geladen, überprüfe Integrität der M2TS-Dateien.
File "/dummy_f.dat" was skipped
Hash-Check von Datei 00290.m2ts an Offset 190464 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei 00290.m2ts an Offset 387072 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei 00290.m2ts an Offset 583680 fehlgeschlagen, Datei ist korrupt.
Hash-Check von Datei 00290.m2ts an Offset 780288 fehlgeschlagen, Datei ist korrupt.
Produzent: HL-DT-ST
Revision: 1.00
Disk-Informationen
Anzahl der Layer: 3
zittrig
Try recovery mode.
In the first selection menu choose the BP60 1.00 and in the second the BU40N 1.03MK.
Or try to flash to BP60 1.02MK and after this to BU40N 1.03MK.
reinerzufall
Nothing really helps,
I can't reflash the drive anymore. At least it still reads regular Blu-rays, so it's not completely dead yet.
Is it possible that the drive is having problems because it's not getting enough power via USB?
Then regular Blu-rays would probably have the same problems, right?
I'm at a loss, I'll probably have to return it, it's only 3 days old.
Unfortunately, you can't tell from the outside which drive you're getting.
