Pioneer BDR-UD03 UHD possibility
zittrig
Re: Pioneer BDR-UD03 UHD possibility
Post by zittrig »
yu-yevon wrote: Thu Feb 12, 2026 3:13 am Why is everyone paying for this firmware flasher? PM me and I can give it to you for free.
I don't know.
Perhaps the others are thinking about the effort of other people who worked on a very special and great tool?
Because the author of said tool asked that it not be shared.
because its not free or public
i paid to have access to it you should not being giveing something i paid for and contributed work to for free
heisenberg
Post by heisenberg »
I've got the following drive:
[b]Drive Information[/b]
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: xxx
Firmware date: 2020-06-15
Highest AACS version: 82
[b]LibreDrive Information [/b]
Drive platform: RS8511
Firmware version: 1.14
BD raw metadata read:
Yes Unrestricted read speed: Yes
Can anyone kindly send me the flasher so that the drives support UHD discs?
heisenberg wrote: Thu Feb 12, 2026 11:55 am I've got the following drive:
Revision: 1.14
Serial number: xxx
Yes email me that drive info section see below for email
hewhois
Post by hewhois »
I see below drive information yet makemkv only shows it as a blu ray disc.
Timestamp: 2017-11-15 13:36:48
Protection: AACS2.0/C v61
Data capacity: 74.34 Gb
Disc type: BD-ROM UHD
Number of layers: 3
Am I doing something wrong or makemkv only shows blu ray for a UHD+Bluray disc?
hewhois wrote: Thu Feb 12, 2026 4:50 pm I see below drive information yet makemkv only shows it as a blu ray disc.
Number of layers: 3
Try to rip the disc. Everything is fine.
Number of layers: 3
It's showing as a UHD disc with 3 layers.
BDLover
Post by BDLover »
Coopervid wrote: Mon Feb 09, 2026 10:42 am
BDLover wrote: Sun Feb 08, 2026 9:18 am I'd love the updater too please.
OS device name: F:
Revision: 1.14
Serial number:
PM sent.
Thank you ☺️
drummah
Post by drummah »
Bought ASUS SBW-06D2X-U, but it seems it is Pioneer drive inside. And on the box there is an info that it can write BDXL discs, but when I'm inserting blank BDXL - it is trying to read it for 3 seconds, then stops. It is possible to unlock BDXL burning?
Thanks.
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: 1.10
Serial number: ALDL242318WL
Firmware date: 2017-04-18
Firmware version: 1.10/ID22
Meikf
Post by Meikf »
Hallo im new her i already have a Asus BW-16D1HT
Now i have the Chance to get a verbatim Pioneer BDR-UD03
Or a verbatim lg bu40n
Can someone give me some advice which one I should take
Thank you in advance
drummah wrote: Sat Feb 14, 2026 5:45 am Bought ASUS SBW-06D2X-U, but it seems it is Pioneer drive inside. And on the box there is an info that it can write BDXL discs, but when I'm inserting blank BDXL - it is trying to read it for 3 seconds, then stops. It is possible to unlock BDXL burning?
Thanks.
Manufacturer: ASUS
Revision: 1.10
sure email me that drive info for the auto flasher see below for email
Meikf wrote: Sat Feb 14, 2026 1:03 pm Hallo im new her i already have a Asus BW-16D1HT
i would go for the ud03 when you get it email me the drive info section like the others above
rickky1989
ASUS BW-06D5H-U
Post by rickky1989 »
hi
i just got an asus external writer and want to do stuff with UHD discs, my makemkv info is below
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: E101
Serial number: ABDL205207WL
Firmware date: 2018-08-22
Firmware version: E101/ID26
any help pointing me in the right direction for the correct firmware for this would be a great help, ty
Re: ASUS BW-06D5H-U
rickky1989 wrote: Sun Feb 15, 2026 4:48 am hi
OS device name: E:
Manufacturer: ASUS
Revision: E101
PM sent.
