Public KeyDB Disc Submissions
Post by SamuriHL »
BBonus wrote: Wed Feb 11, 2026 10:33 pm Hi - thanks I followed the KEYDB.cfg instructions - I have unzipped file keydb.cfg saved in:
C:\Users\[my user name]\.MakeMKV
However I still get this following error. Do I need to do something else?
MakeMKV v1.18.3 win(x64-release) started
Using LibreDrive mode (v02.1 id=E9BA8ECC61EF)
Saved AACS dump file as C:/Program Files (x86)/MakeMKV/MKB20_v82_EXCALIBUR_-_4K_UHD_0994.tgz
You put the keydb.cfg file in the wrong location. For whatever reason your data directory is set to C:/Program Files (x86)/MakeMKV/ and that's where it needs to go or change the data directory in your MakeMKV settings.
tterbg201
Post by tterbg201 »
I hope I do this correctly:
F1: The Movie
Disc type: UHD
Disc ID: 0x74D1A4FFE698D702ECBDF93BC389F2AF73D377C7
Disc dump filename: MKB20_v82_F1_FBFB.tgz
Drive: Pioneer BD-RW BDR-XD08U
Drive firmware: 1.04
LibreDrive status: Enabled
MKB_RO.inf link: https://drive.proton.me/urls/ME344FSEEC#H5Clcb1qrP1L
Disc dump link: https://drive.proton.me/urls/P7YP1BQNF4#d9pm3z82QKn8
organicguy
Post by organicguy »
Hello, submitting a dump file for disc 1 of the Ben-Hur 4K release that just came out:
Disc type: UHD
Disc ID: 0x298A235FDD0FE0EA8E450918B576187677C941F2
Disc dump filename: MKB20_v82_Ben-Hur_(1959)_Part_1_132A.tgz
Drive: LG BE16NU50
Drive firmware: 1.01
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://1drv.ms/u/c/25a4d3efdc044d61/IQ ... c?e=VPdrOL
Disc dump link: https://1drv.ms/u/c/25a4d3efdc044d61/IQ ... s?e=vhTAiA
Tihany
Post by Tihany »
Un drôle de flic - French UHD
Disc type: UHD
Disc ID: 0x1929d651350bdd951e4734d9db33bc334af9bec5
Disc dump filename: MKB20_v82_UnDroleDeFlic_393F.tgz
Drive: BD-RE WH16NS60
Drive firmware: 1.02
MKB_RO.inf link: https://limewire.com/d/RozaJ#2gjHNOqVv4
Disc dump link: https://limewire.com/d/XCTnJ#f0mTYODvKx
keydb_helper
Post by keydb_helper »
Thanks to everyone who followed the template and provided new disc dump files. I believe all submissions have been added to the public keydb.
The following discs corresponded to new media keys:
MKB20_v82_Fear_In_The_Night_40A6
MKB20_v82_Now_You_See_Me-_Now_You_Don't_9DF8
MKB20_v82_PREDATOR-_BADLANDS_990E
MKB20_v82_PREDATOR_BADLANDS_A230
Public KeyDB Disc Submissions KeyDB Download
DutchComputerKid
Post by DutchComputerKid »
Here the new Puss In Boots UHD release, haven't gotten The Last Wish in the mail yet but straight to getting the keys:
Disc type: UHD
Disc ID: c998c57b8fdb7bb4b2c29c8df1605c0c5a2759e0
Disc dump filename: MKB20_v77_Puss_in_Boots_7C67
Drive: BDR-UD04
Drive firmware:  Original (unpatched)
LibreDrive status: Enabled (2.1)
MKB_RO.inf & disc dump link: https://mega.nz/file/71pF3ACY#Nexlaf9g3 ... tDZ4kiK4wE
Both the tgz and the whole AACS folder just in case, also since the tgz has the smaller 56 byte file, not 5MiB.
organicguy
Thank you for the fast turnaround on Ben-Hur Disc 1.
I just found out this morning that the blu-ray (with the extras) isn't in the DB yet either. Here is that disc info:
Disc type: Blu-ray
Disc ID: 0xA1BAF3EFBE0217E39CEC9CD311841EC9B7C10F84
Disc dump filename: MKB_v82_Ben-Hur_(1959)_Bonus_Disc_6AA6.tgz
Drive: LG BE16NU50
MKB_RO.inf link (Do not just extract the MKB_RO.inf file from the disc dump file - copy it from the disc): https://1drv.ms/u/c/25a4d3efdc044d61/IQ ... g?e=VW9tmE
Disc dump link: https://1drv.ms/u/c/25a4d3efdc044d61/IQ ... A?e=YazwDZ
Cineph
Post by Cineph »
Bugonia (German UHD Disc)
Disc type: UHD
Disc ID: 0x3DBF7179CCB84AFAF2875D26A93039C0E4A0B375
Disc dump filename: MKB20_v82_Bugonia_9EBA.tgz
Drive: BD-RE ASUS BW 16D 1HT
Drive firmware: 3.10
MKB_RO.inf link: https://we.tl/t-ao21DAkkgs
Disc dump link: https://we.tl/t-rl7vlDPV4B
Brollan
Post by Brollan »
keydb_helper wrote: Thu Feb 12, 2026 10:35 am Thanks to everyone who followed the template and provided new disc dump files. I believe all submissions have been added to the public keydb.
Perfect, works like a charm, thanks guys! :D
BBonus
Post by BBonus »
SamuriHL wrote: Thu Feb 12, 2026 1:32 am
Hi thanks I didn't notice the different path - not sure why I had two paths, may have tried to do this before. I have changed my data directory in MakeMKV settings (to the normal default location) and put all files including keydb.cfg in the data directory, and all is now fine, I am ripping Excalibur 4K. Also, next time I will follow the correct process/submission format, apologies. Many thanks!
t1ll1van1ll1
Post by t1ll1van1ll1 »
Disc type: UHD
Disc ID: 02C8D87FDCA831654EEE2E20C423C217BD560DBE
Disc dump filename: MKB20_v82_Wicked-_For_Good_6D8E
Drive firmware: Patched (microcode access re-enabled)
LibreDrive status: Enabled 1.02
Did you sync the public keydb within the last 15 minutes?: yes
Have you verified that all submission links are accessible in incognito/private browsing? yes
MKB_RO.inf link: https://drive.google.com/file/d/1-PunwJ ... sp=sharing
Disc dump link: https://drive.google.com/file/d/1wOJhcg ... sp=sharing
i am unsure about the disc id, as all the others have a very long number- would be kind of you to tell me where i can get this data
Mikeismad
Post by Mikeismad »
Pee-Wees Big Adventure Criterion 4k
Disc type: UHD
Disc ID: dee8ba763134399d2326ad111c9d3b33ae625db8
Disc dump filename: MKB20_v82_PEE-WEE'S_BIG_ADVENTURE_4301
Drive: ASUS_BW-16D1HT
Have you verified that all submission links are accessible in incognito/private browsing?Yes
MKB_RO.inf link:
Disc dump link:
Post by SamuriHL »
BBonus wrote: Thu Feb 12, 2026 6:31 pm Hi thanks I didn't notice the different path - not sure why I had two paths, may have tried to do this before. I have changed my data directory in MakeMKV settings (to the normal default location) and put all files including keydb.cfg in the data directory, and all is now fine, I am ripping Excalibur 4K. Also, next time I will follow the correct process/submission format, apologies. Many thanks!
Glad that worked for you. Enjoy!
keydb_helper
t1ll1van1ll1 wrote: Thu Feb 12, 2026 8:32 pm i am unsure about the disc id, as all the others have a very long number- would be kind of you to tell me where i can get this data
Hey t1ll1van1ll1, the long number is the SHA-1 hash of the Unit_Key_RO.inf file. You'll find this file inside the AACS directory on your disc. You can calculate this hash value with tools such as 7-zip on Windows or the shasum/sha1sum command-line utility on Linux/macOS.
MKB20_v77_Frontier_Crucible_1018
MKB20_v82_LE_ONDE_DEL_DESTINO_7CF0
MKB20_v82_SEAL_8724
MKB20_v82_The_Straight_Story_UHD
organicguy
If you're on Windows (which has PowerShell installed by default), you can open PowerShell and run this command (this assumes D is the letter associated with your UHD/blu-ray disc drive -- you'll need to change that if it's different on your computer):
Get-FileHash "D:\AACS\Unit_Key_RO.inf" -Algorithm SHA1 | Select-Object -ExpandProperty Hash
This should work on macOS or Linux as well if you have PowerShell installed.
Thanks again keydb_helper for the fast turnaround.
