NobleOccum
That got it for me, thanks! Ripping an UHD right now!
Gene80
Hello, I have the following gear and would like to confirm that it would be a candidate before I attempt:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 1.01
Serial number:
Firmware date: 2113-02-05 19:30
Bus encryption flags: 1F
Highest AACS version: 57
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
Mfg Date December 2023.
My enclosure is a Vantec NexStar DX2 NST-540S3-BK
I noticed your comment on the Drive platform needing to be "MT1959<" but I'm not following if you are saying it needs to be greater or less than 1959? Mine appears to be MT 1939.
Thank you.
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 1.01
Serial number:
Thank you.
This drive platform went obsolete when UHD became available. Cannot say why it claims to have been built in 2023.Drive platform: MT1939
It's a fake and drive is from 2013 when LGs weren't UHD capable.Gene80 wrote: Mon Feb 09, 2026 8:22 pm Hello, I have the following gear and would like to confirm that it would be a candidate before I attempt:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 1.01
Serial number:
Thank you.
Gene80
Thank you, I will return it today! Do you have any drives for sale, or have any recommendations on where I should look so I don't buy another fake.
nicholfd
Hello!Gene80 wrote: Mon Feb 09, 2026 9:42 pm Thank you, I will return it today! Do you have any drives for sale, or have any recommendations on where I should look so I don't buy another fake.
If you are in the US, I have three models of drives on-hand, pre-flashed for use with MakeMKV, available for purchase. Links to the "For sale" threads & my contact e-mail are in my signature.
Thanks,
Frank
For sale 4K UHD Flashed USB drives:
ASUS Slim, Buffalo Slim, LG Slim,
Buffalo 5 1/4", ASUS 5 1/4",
drives@nicholasfamilycentral.com
Gene80
Email sent. Thank you Frank!
tuxingtansuozhe
I found an online listing of one of the drives on the list manufactured in April 2016.
Are all drives that were manufactured in 2016 compatible? Is there a cutoff month?
mkvuser190
That is my info. I copied it from my own post in another thread. Sorry for the confusion!
PM sent for this drive.mkvuser190 wrote: Fri Feb 06, 2026 6:12 am Hi all
I'm new to this forum, and I am very confused by this thread. I don't see my drive or firmware listed, but people in another thread have helped others with the same drive. I have a Pioneer drive, and I am scared to brick it if I do something wrong. Could somebody tell me if my drive is flashable for UHD? Thank you.Also, I'm sorry for essentially re-posting this from another thread. I just think this one is more active than the other one.Code: Select all
Drive Information OS device name: Manufacturer: PIONEER Product: BD-RW BDR-XD07 Revision: 1.03 Serial number: Firmware date: 2020-08-20 Bus encryption flags: 13 Highest AACS version: 63 LibreDrive Information Status: Enabled Drive platform: RS8D30 Firmware name: PIONEER BDR-BDS7 Firmware type: Original (unpatched) Firmware version: 1.03 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
Mort-
I too am sort of confused with my drive, and do not wish to mess this up. I purchased a Verbatim 43888 and did all the research I could on here before starting and thought I was ready to flash until MakeMKV tells me I got a Pioneer UD04 drive, not the LG BU40N I was expecting and folks are saying come in these now. I searched again for info on flashing this but all I came up with was posts along the lines of "this drive will work", but not which firmware to use? Is what I need in the "All You Need Firmware Pack", or is there something else I'm looking for? Will the GUI work for this or am I to use the command line instructions?
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: -=-=-=-
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Unrestricted read speed: Yes-
You must have been extremely lucky and got an old unit from wherever you bought it. They stopped putting Pioneer drives in the 43888 early 2025!!Mort- wrote: Wed Feb 11, 2026 11:43 pm I too am sort of confused with my drive, and do not wish to mess this up. I purchased a Verbatim 43888 and did all the research I could on here before starting and thought I was ready to flash until MakeMKV tells me I got a Pioneer UD04 drive, not the LG BU40N I was expecting and folks are saying come in these now. I searched again for info on flashing this but all I came up with was posts along the lines of "this drive will work", but not which firmware to use? Is what I need in the "All You Need Firmware Pack", or is there something else I'm looking for? Will the GUI work for this or am I to use the command line instructions?
Drive Information OS device name: D: Manufacturer: PIONEER Product: BD-RW BDR-UD04 Revision: 1.14 Serial number: -=-=-=- Firmware date: 2020-06-15 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8A10 Firmware name: PIONEER BDR-US04 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
You do not need to do anything as it is already UHD compatible out of the box. Just insert a UHD disc and start ripping!!
nmcdeal
Hello there,
Yes newbie here.
I have read online in these forums that my BluRay drive is able to be flashed and read UHD Bruray discs.
I have provide details of my drive below from MakeMKV
My Drive is a BD-RE ASUS BW-16D1H-U drive manufactured Dec 2021.
However when I use SDFtol Flasher v1.3.6 it says that I don't have the MT1959 platform that allows flashing ?!?
Is someone able to assist me? I am stuck in what I need to do next.
Thank you in advance.
Also is there a link to the firmware
Details from MakeMKV
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number: XXXXXXXXXXXXXXXXXXX
Firmware date: 2019-03-07
Highest AACS version: 68
Drive platform: RS8F00
Firmware version: E115/ID71
Yes newbie here.
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
nicholfd
You got lucky & hit the drive lottery - your USB ASUS chassis has a Pioneer mechanism, not a LG mechanism. SDFtool is only for LG mechanisms/drives.nmcdeal wrote: Thu Feb 12, 2026 3:10 pm Drive platform: RS8F00
Coopervid, Billycar11 or someone can provide you with a flasher for your Pioneer drive - it's not publicly available.
PM sent.nmcdeal wrote: Thu Feb 12, 2026 3:10 pm Hello there,
Yes newbie here.
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
