Yes, of course.
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
Hey, I would like the firmware too please.
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.03
Serial number:
Firmware date: 2015-05-14
Highest AACS version: 66
Drive platform: RS8510
Firmware version: 1.03/ID19
Sure just email me that drive info section see below for emailbifboy28 wrote: ↑Mon Feb 09, 2026 9:40 pmHey, I would like the firmware too please.Drive Information
Revision: 1.03
Serial number:
privacy_user_mkv
Hello there! I have the following very similar drives. I would like to get UHD support working. I have 3 drives that are identical except for the serial numbers.
Revision: 1.14
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
Can somebody help me cross flash them?
Revision: 1.14
iluvripping
Hi Coopervid, I just got this drive from Japan on ebay yesterday. It's dated October 2016? Could I get the flasher?
Revision: 1.03
Serial number: QKDL754551WL
PM sent.privacy_user_mkv wrote: ↑Wed Feb 11, 2026 4:48 amHello there! I have the following very similar drives. I would like to get UHD support working. I have 3 drives that are identical except for the serial numbers.
Revision: 1.14
PM sent.iluvripping wrote: ↑Wed Feb 11, 2026 11:36 amHi Coopervid, I just got this drive from Japan on ebay yesterday. It's dated October 2016? Could I get the flasher?
Revision: 1.03
Hi together,
I recently bought a Verbatim 43890 with the model code BIAA including the Pioneer BDR-UD03.
But when I look at the drive information in MakeMKV, I see no LibreDrive information listed.
Also if I run makemkvcon on the drive I do not get more information:
Does that mean the drive is broken, or can it still be flashed?
OS device name: /dev/sr0
Revision: 1.14
Serial number: xxx
Highest AACS version: 81
Loaded SDF.bin version 0xa5
Pioneer firmware module v1.20
Commands:
dump [auto|full] dumps firmware image
dump full - dumps full rom image (if not disabled in firmware)
dump auto - dumps full image if possible, info data otherwise
speed get - prints current speed mode setting
speed set MODE - writes new default speed mode to EEPROM
Command produced 0 file(s)
Please install Windows in a VM - best is VMWare - and post then the Makemkv info from Windows. You need to do this anyway if the drive is flashable. Or connect it to a Windows computer and report back then.kitty wrote: ↑Wed Feb 11, 2026 5:02 pmHi together,
Also if I run makemkvcon on the drive I do not get more information:Code: Select all
OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: xxx Bus encryption flags: 1B Highest AACS version: 81 No disc inserted
Does that mean the drive is broken, or can it still be flashed?Code: Select all
Loaded SDF.bin version 0xa5 Pioneer firmware module v1.20 Commands: dump [auto|full] dumps firmware image dump full - dumps full rom image (if not disabled in firmware) dump auto - dumps full image if possible, info data otherwise speed get - prints current speed mode setting speed set MODE - writes new default speed mode to EEPROM Command produced 0 file(s)
Hey Coopervid,
Not sure if I am doing something incorrect. After the process, instead of listing as BD-03, the drive shows up as BD-04.
But when I insert a Blu-ray+4K disc, the contents still show as only Blu ray in makemkv. Just like it was doing prior to any changes.
It also does not change the firmware date and version. Am I doing something wrong?
Current drive info.
Current drive info.
OS device name: E:
Current profile: BD-R SRM
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number:
Highest AACS version: 50
Drive platform: RS8A10
Put an UHD in it.hewhois wrote: ↑Wed Feb 11, 2026 5:58 pmHey Coopervid,
Current drive info.
OS device name: E:
Revision: 1.14
Serial number:
Thanks a lot for your help.Coopervid wrote: ↑Wed Feb 11, 2026 5:49 pmPlease install Windows in a VM - best is VMWare - and post then the Makemkv info from Windows. You need to do this anyway if the drive is flashable. Or connect it to a Windows computer and report back then.kitty wrote: ↑Wed Feb 11, 2026 5:02 pmHi together,
Indeed you are absolutely right, on a VM with Windows the LibreDrive information is showing up (the drive information is a bit miss-mapped from the VM I guess).
(Kind of new to me, all my LG drives show the LibreDrive information before and after flashing on Linux^^)
Here is the output:
OS device name: E:
Manufacturer: VBOX
Product: CD-ROM
Revision: 1.0
Serial number: BADLxxx
Fine. PM sent to flash it to UD04 for reading UHD discs.
Why is everyone paying for this firmware flasher? PM me and I can give it to you for free.
