NobleOccum
Post by NobleOccum » Mon Feb 09, 2026 6:24 pm
That got it for me, thanks! Ripping an UHD right now!
Gene80
Post by Gene80 » Mon Feb 09, 2026 8:22 pm
Hello, I have the following gear and would like to confirm that it would be a candidate before I attempt:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 1.01
Serial number:
Firmware date: 2113-02-05 19:30
Bus encryption flags: 1F
Highest AACS version: 57
Drive platform: MT1939
Firmware version: 1.01
BD raw metadata read: Partial
Mfg Date December 2023.
My enclosure is a Vantec NexStar DX2 NST-540S3-BK
I noticed your comment on the Drive platform needing to be "MT1959<" but I'm not following if you are saying it needs to be greater or less than 1959? Mine appears to be MT 1939.
Thank you.
Post by Woodstock » Mon Feb 09, 2026 9:26 pm
This drive platform went obsolete when UHD became available. Cannot say why it claims to have been built in 2023.
Post by Coopervid » Mon Feb 09, 2026 9:34 pm
Gene80 wrote: Mon Feb 09, 2026 8:22 pm Hello, I have the following gear and would like to confirm that it would be a candidate before I attempt:
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 1.01
Serial number:
Thank you.
It's a fake and drive is from 2013 when LGs weren't UHD capable.
Gene80
Post by Gene80 » Mon Feb 09, 2026 9:42 pm
Thank you, I will return it today! Do you have any drives for sale, or have any recommendations on where I should look so I don't buy another fake.
nicholfd
Post by nicholfd » Tue Feb 10, 2026 12:17 am
Gene80 wrote: Mon Feb 09, 2026 9:42 pm Thank you, I will return it today! Do you have any drives for sale, or have any recommendations on where I should look so I don't buy another fake.
Hello!
If you are in the US, I have three models of drives on-hand, pre-flashed for use with MakeMKV, available for purchase. Links to the "For sale" threads & my contact e-mail are in my signature.
Thanks,
Frank
Gene80
Post by Gene80 » Tue Feb 10, 2026 1:00 am
Email sent. Thank you Frank!
tuxingtansuozhe
Post by tuxingtansuozhe » Wed Feb 11, 2026 2:11 am
I found an online listing of one of the drives on the list manufactured in April 2016.
Are all drives that were manufactured in 2016 compatible? Is there a cutoff month?
mkvuser190
Post by mkvuser190 » Wed Feb 11, 2026 6:17 am
Coopervid wrote: Mon Feb 09, 2026 5:42 pm You need to post your own Makemkv info to be helped.
That is my info. I copied it from my own post in another thread. Sorry for the confusion!
Post by Coopervid » Wed Feb 11, 2026 12:39 pm
mkvuser190 wrote: Fri Feb 06, 2026 6:12 am Hi all
I'm new to this forum, and I am very confused by this thread. I don't see my drive or firmware listed, but people in another thread have helped others with the same drive. I have a Pioneer drive, and I am scared to brick it if I do something wrong. Could somebody tell me if my drive is flashable for UHD? Thank you.
OS device name:
Manufacturer: PIONEER
Product: BD-RW BDR-XD07
Revision: 1.03
Serial number:
Firmware date: 2020-08-20
Bus encryption flags: 13
Highest AACS version: 63
Drive platform: RS8D30
Firmware version: 1.03
Also, I'm sorry for essentially re-posting this from another thread. I just think this one is more active than the other one.
PM sent for this drive.
Mort-
Post by Mort- » Wed Feb 11, 2026 11:43 pm
I too am sort of confused with my drive, and do not wish to mess this up. I purchased a Verbatim 43888 and did all the research I could on here before starting and thought I was ready to flash until MakeMKV tells me I got a Pioneer UD04 drive, not the LG BU40N I was expecting and folks are saying come in these now. I searched again for info on flashing this but all I came up with was posts along the lines of "this drive will work", but not which firmware to use? Is what I need in the "All You Need Firmware Pack", or is there something else I'm looking for? Will the GUI work for this or am I to use the command line instructions?
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: -=-=-=-
Firmware date: 2020-06-15
Drive platform: RS8A10
Firmware version: 1.14
Post by MartyMcNuts » Thu Feb 12, 2026 6:30 am
Mort- wrote: Wed Feb 11, 2026 11:43 pm I too am sort of confused with my drive, and do not wish to mess this up. I purchased a Verbatim 43888 and did all the research I could on here before starting and thought I was ready to flash until MakeMKV tells me I got a Pioneer UD04 drive, not the LG BU40N I was expecting and folks are saying come in these now. I searched again for info on flashing this but all I came up with was posts along the lines of "this drive will work", but not which firmware to use? Is what I need in the "All You Need Firmware Pack", or is there something else I'm looking for? Will the GUI work for this or am I to use the command line instructions?
Revision: 1.14
You must have been extremely lucky and got an old unit from wherever you bought it. They stopped putting Pioneer drives in the 43888 early 2025!!
You do not need to do anything as it is already UHD compatible out of the box. Just insert a UHD disc and start ripping!!
nmcdeal
Post by nmcdeal » Thu Feb 12, 2026 3:10 pm
Hello there,
Yes newbie here.
I have read online in these forums that my BluRay drive is able to be flashed and read UHD Bruray discs.
I have provide details of my drive below from MakeMKV
My Drive is a BD-RE ASUS BW-16D1H-U drive manufactured Dec 2021.
However when I use SDFtol Flasher v1.3.6 it says that I don't have the MT1959 platform that allows flashing ?!?
Is someone able to assist me? I am stuck in what I need to do next.
Thank you in advance.
Also is there a link to the firmware
Details from MakeMKV
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
Serial number: XXXXXXXXXXXXXXXXXXX
Firmware date: 2019-03-07
Highest AACS version: 68
Drive platform: RS8F00
Firmware version: E115/ID71
nicholfd
Post by nicholfd » Thu Feb 12, 2026 3:56 pm
nmcdeal wrote: Thu Feb 12, 2026 3:10 pm Drive platform: RS8F00
You got lucky & hit the drive lottery - your USB ASUS chassis has a Pioneer mechanism, not a LG mechanism. SDFtool is only for LG mechanisms/drives.
Coopervid, Billycar11 or someone can provide you with a flasher for your Pioneer drive - it's not publicly available.
Post by Coopervid » Thu Feb 12, 2026 3:59 pm
nmcdeal wrote: Thu Feb 12, 2026 3:10 pm Hello there,
Yes newbie here.
OS device name: F:
Manufacturer: ASUS
Product: BW-16D1H-U
Revision: E115
PM sent.
