Drive not picking up BluRay Discs
Vildar
Post by Vildar »
Hey all.
Ive been gifted an external slim Bluray Reader. Had never been used though is a few years old. Doesnt look to be of any worth, though it was aparently around £100 on amazon.
Its a MATSHITA BD-MLT UJ240AF. Make MKV Picks it up as such, Windows picks it up as a BluRay drive. But it just refuses to load any BluRay disc. No mater the age. Keeps spinning on "Disc is being Loaded" but never gets anywhere. Oldest BluRay i have is from 2005.
I know my discs work as i have another external that ive been using fine.
It will read and rip DVD's perfectly fine, just does nothing with a BluRay disc. It definatly has the 2 lasers. And all the markings on it as a BluRay drive.
Anything i can do here? Or is it a case of thats it, and ill just use it for DVD ripping.
MakeMKV Version 1.18.3 Windows x64. Thoughh has had the same problem on Linux
Drive info below from a DVD insterted and a BluRay inserted.
DVD
Current profile: DVD-ROM
Manufacturer: MATSHITA
Product: BD-MLT UJ240AF
Revision: 1.01
Serial number: WL08 005166
Disc Information
Label: BRUCE_ALMIGHTY_PAL_D1
Timestamp: 2003-10-08 17:27:56
Protection: CSS/CPPM
Data capacity: 7.9 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
LOG
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE MATSHITA BD-MLT UJ240AF 1.01 WL08 005166' at offset '1048576'
BluRay
OS device name: F:
Revision: 1.01
Re: Drive not picking up BluRay Discs
Do you have an USB3 connection for the drive?
If yes, most likely the blue laser is dead.
Vildar
Post by Vildar »
Coopervid wrote: Wed Feb 11, 2026 11:52 am Do you have an USB3 connection for the drive?
Defnatly connected by USB 3, and connected to an external power supply aswell.
Likely to have a dead Bluray laser from new? As i mentioned it had never been used, was still sealed in the packaging.
If the disc doesn't show up in Explorer - yes. It is not uncommon to receive a returned drive which is defective. Should have been tested right away after it arrived.
Vildar
Post by Vildar »
Ah well, thats a shame then. Least it was free.
kaysee
Post by kaysee »
Try cleaning the lens over the blue laser. To avoid missing it, you might clean both lenses. The blue laser is under a lens that looks red because it reflects red light outward.
Vildar
Post by Vildar »
Did try that, seems no amount of cleaning helps
Vildar wrote: Wed Feb 11, 2026 2:49 pm Did try that, seems no amount of cleaning helps
Out of the box unlikely that a lens is polluted. Like said - dead blue laser.
