bbeny123
Post by bbeny123 »
RESET_9999 wrote:
Wed Jan 28, 2026 11:37 pm
Nice, thank you.
I get about the same speed in avisynth when I use:
SetFilterMTMode("DoViBaker",2)
Prefetch(8)
Good to know! The port is now officially public: https://github.com/bbeny123/felbaker
It offers two modes, but I highly recommend the mode utilizing VapourSynth's built-in resizers—it’s faster and more accurate than the internal Spline16 (DoViBaker-compatible, simplified) mode.
You can find example .vpy scripts in the README. Let me know how it performs on your end!
thank you, great work!
bbeny123
Post by bbeny123 »
bbeny123 wrote:
Fri Jan 30, 2026 1:43 pm
I don’t know whether L9 has any effect at playback, but I suspect it doesn’t. I’ve seen some Web-DLs (Amazon, I think) with dynamic L9, and Metafier flags it as invalid.
I don’t think the choice of MDP really matters here, but we could generate a test sample that alternates between P3 and BT.2020 to check whether there is any visible difference in practice.
I don't really understand the Dolby documentation on what L9 is actually supposed to do, so I’m not sure how to interpret it. Maybe @quietvoid has more insight on this.
I’ll try to test this over the weekend, though I’m not sure if varying L9 values within a single file is strictly allowed by the spec.
Finally managed to find the time to run the tests.
Setup: Ugoos AM6B+ (p3i T2a) + SONY A95L
I tested both scenarios:
  • A single file with dynamic L9 (P3 -> BT.2020 -> no L9).
  • Three separate files with fixed L9 values for each (P3, BT.2020, no L9).
Result: I couldn't spot any visible differences in color or brightness in any of the tests. It seems L9 has no effect on playback, at least on this specific hardware combination.
That's what I thought. Thank you for confirming.
deadchip12
Post by deadchip12 »
@RESET9999
Should I set "Force colour subsampling" to 4:2:2 on the Ugoos instead of Auto? If I do so and check the HDMI diagnostics screen on my tv (lg c9), then it says 422 8 bit instead of 12 bit. Even if I try to set "Force display colour depth" to 12 bit it still says 8 bit. Could you check what it shows on your lg g1 and g5?
on mine auto = 444 12bit
422 = 8bit
deadchip12
RESET_9999 wrote:
Sat Feb 14, 2026 6:03 am
422 = 8bit
Yeah so same as mine.
Does this mean the hdmi diagnostics of the tv is incorrect or the ugoos can only output 8 bit at 422?
Should I keep it on auto or 422 then?
you should use auto 444 12bit. There might be a bug with the 422 output and you should ask avdvplus about it since i know he made some changes about 422 in his build.
Post by SamuriHL »
This isn't true. 422 12 bit works just fine. I don't care what the LG claims.
SOURCE:
Amlogic MBox Meson Ref
IN TX0:
1080P23.976 74MHz 422 BT709 12b
This is why having a VRROOM is useful.
SamuriHL wrote:
Sat Feb 14, 2026 4:55 pm
SOURCE:
IN TX0:
Yeah, if the HDFury device reports 12-bit, I trust that more than LG’s reporting.
On my end, CEC no longer works when I put my Vertex in the signal chain, so I don’t use it in my main home theater. I only keep one in my capture and testing rig.
In any case, 422 doesn’t really matter to me since I only watch DV using RGB tunneling.
Post by SamuriHL »
RESET_9999 wrote:
Sat Feb 14, 2026 5:44 pm
I use it specifically to block CEC LOL I can't stand that nonsense as it doesn't work right half the time. As for 422, I agree as I use my HTPC for non-DV stuff most of the time, but it's been a discussion on multiple forums now so I figured I'd take a look.
deadchip12
RESET_9999 wrote:
Sat Feb 14, 2026 1:57 pm
How do I contact him?
Gatorman
Post by Gatorman »
deadchip12
Is there a way to send him a pm? The Issues tab on github seems kinda dead so not sure if posting there will get his attention.
daffie
Post by daffie »
deadchip12 wrote:
Sun Feb 15, 2026 4:26 am
The issues tab is not dead. He responds kindly to everything.
Try to raise an issue here : https://github.com/avdvplus/Builds/issues
LG OLED65G1RLA / Samsung HW-Q990D / Panasonic UB820 / Ugoos AM6B+ (CE with avdvplus Build)
