Hey all.
Ive been gifted an external slim Bluray Reader. Had never been used though is a few years old. Doesnt look to be of any worth, though it was aparently around £100 on amazon.
Its a MATSHITA BD-MLT UJ240AF. Make MKV Picks it up as such, Windows picks it up as a BluRay drive. But it just refuses to load any BluRay disc. No mater the age. Keeps spinning on "Disc is being Loaded" but never gets anywhere. Oldest BluRay i have is from 2005.
I know my discs work as i have another external that ive been using fine.
It will read and rip DVD's perfectly fine, just does nothing with a BluRay disc. It definatly has the 2 lasers. And all the markings on it as a BluRay drive.
Anything i can do here? Or is it a case of thats it, and ill just use it for DVD ripping.
MakeMKV Version 1.18.3 Windows x64. Thoughh has had the same problem on Linux
Drive info below from a DVD insterted and a BluRay inserted.
DVD
Current profile: DVD-ROM
Manufacturer: MATSHITA
Product: BD-MLT UJ240AF
Revision: 1.01
Serial number: WL08 005166
Disc Information
Label: BRUCE_ALMIGHTY_PAL_D1
Timestamp: 2003-10-08 17:27:56
Protection: CSS/CPPM
Data capacity: 7.9 Gb
Disc type: DVD-ROM
Disc size: 120mm
Maximum read rate: 10.08 Mbps [1x]
Number of layers: 2 (OTP)
LOG
Error 'Scsi error - ILLEGAL REQUEST:READ OF SCRAMBLED SECTOR WITHOUT AUTHENTICATION' occurred while reading 'BD-RE MATSHITA BD-MLT UJ240AF 1.01 WL08 005166' at offset '1048576'
BluRay
OS device name: F:
Revision: 1.01
Drive not picking up BluRay Discs
Re: Drive not picking up BluRay Discs
Do you have an USB3 connection for the drive?
If yes, most likely the blue laser is dead.
Vildar
Defnatly connected by USB 3, and connected to an external power supply aswell.Coopervid wrote: Wed Feb 11, 2026 11:52 am Do you have an USB3 connection for the drive?
Likely to have a dead Bluray laser from new? As i mentioned it had never been used, was still sealed in the packaging.
If the disc doesn't show up in Explorer - yes. It is not uncommon to receive a returned drive which is defective. Should have been tested right away after it arrived.
Vildar
Ah well, thats a shame then. Least it was free.
kaysee
Try cleaning the lens over the blue laser. To avoid missing it, you might clean both lenses. The blue laser is under a lens that looks red because it reflects red light outward.
Vildar
Did try that, seems no amount of cleaning helps
Out of the box unlikely that a lens is polluted. Like said - dead blue laser.
