EthanBB
#61 Post by EthanBB » Sat Jan 24, 2026 9:37 am
MartyMcNuts wrote: Fri Jan 23, 2026 8:37 pm
You mean encrypted firmware. Green tick means encrypted.
You can flash it to BU40N 1.03-MK.
Thank you very much!
BU40N 1.03-MK from "mk-firmware-pack-20200720.zip" worked like a dream.
minoskorva
#62 Post by minoskorva » Sun Feb 08, 2026 10:20 am
Is there a way to flash the ASUS SBW-06D5H-U?
this is my output
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D5H-U
Revision: A102
Serial number:
Firmware date: 2124-08-05 14:55
Bus encryption flags: 1F
THANKS!!!
#63 Post by MartyMcNuts » Mon Feb 09, 2026 2:58 am
minoskorva wrote: Sun Feb 08, 2026 10:20 am Is there a way to flash the ASUS SBW-06D5H-U?
this is my output
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number:
THANKS!!!
Yes, this is a LG drive. If it's a slim model, use BU40N 1.03-MK with SDFtool Flasher.
nicwilson
#64 Post by nicwilson » Wed Feb 11, 2026 2:22 am
Just wanted to thank everyone here for the information and flash information. I successfully flashed my Asus SBW-06D5H-U with the LG BU40N 1.03 firmware. At first, I got an error with SDFTool Flasher which gave no furher information, But when I ran the Flash with makemkvcon64.exe it gave a helpful error that the tray was not closed. Once the tray was closed then the flash worked perfectly. Thank you to all invloved.
cheers
Nic :D
BrunoGC13
#65 Post by BrunoGC13 » Fri Feb 20, 2026 9:46 am
Hello, I have the exact same drive but where can I find the needed files? Like the .bin and SDF.bin (I'm very new to makemkv and this topic)
#66 Post by dcoke22 » Fri Feb 20, 2026 11:59 am
BrunoGC13 wrote: Fri Feb 20, 2026 9:46 am Hello, I have the exact same drive but where can I find the needed files? Like the .bin and SDF.bin (I'm very new to makemkv and this topic)
If you're looking for BU40N firmware and the SDFtool flasher, links to that stuff can be found in the Ultimate UHD Drives Flashing Guide
boguslecina
#67 Post by boguslecina » Fri Feb 20, 2026 12:10 pm
Check what hardware platform you have. MT1959 is Hitachi-LG, and you have the SDFtool Flasher application there:
viewtopic.php?f=16&t=19634
If you have RS8511, you need to write to Coopervid or Billy11 about the flasher.
maccready
#68 Post by maccready » Sat Mar 21, 2026 6:47 am
Hi all
I just bought the same asus-drive, and I also wonder if my drive is flashable:
OS device name: /dev/sr1
Manufacturer: ASUS
Revision: A102
Serial number: MO6O92I5822
Many thanks!
maccready
#69 Post by maccready » Mon Mar 30, 2026 6:20 am
I noticed that my drive output was identical to minoskorva's(?) above, so I followed MartyMcNuts instructions and it worked flawless.
Thanks a lot for all your work Marty!!
fhades
#70 Post by fhades » Mon Apr 13, 2026 9:38 pm
Hi, I'm gonna add myself to the queue for a pm :)
OS device name: H:
Manufacturer: ASUS
Revision: E101
Serial number:
Firmware date: 2018-08-22
Drive platform: RS8511
Firmware version: E101/ID26
Looking forward to make some good use of it after mostly laying around for the last 5 years :)
#71 Post by Billycar11 » Mon Apr 13, 2026 10:07 pm
fhades wrote: Mon Apr 13, 2026 9:38 pm Hi, I'm gonna add myself to the queue for a pm :)
OS device name: H:
Manufacturer: ASUS
Revision: E101
Serial number:
sure email me that info and all others email me no need to post your info here just reach out to me directly
see below for email
erluan
#72 Post by erluan » Mon Jun 08, 2026 12:14 pm
Hello, Guys!
Hope you're doing pretty well;
Guys, I have ASUS SBW-06D5H-U since 2020 and it works flawlessly with my 1080 Bluray collection but, now, I bought some UHD Blurays and I got blocked by these limitations;
How can I flash the firmware to unlock the UHD blurays reading;
I'm gonna add myself to the queue for a pm;
Thank you in advance;
#73 Post by Billycar11 » Mon Jun 08, 2026 2:38 pm
erluan wrote: Mon Jun 08, 2026 12:14 pm Hello, Guys!
see below for email
