LG BP60NB10 UHD Read Errors
Farsideman
Post by Farsideman »
I'm in need of a little help with this drive. It's currently patched with v1.02 and is consistently having read errors when backing up with MakeMKV. I've read that there is a v1.03 for this drive. Any info on the flashing process, updated version the "All You Need Firmware Pack"? Maybe I did it wrong the first time?
Drive Data Label Info
LG Slim Portable UHD Blu-ray / DVD Writer
Model BP60NB10
SVC Code NB12
Serial Number 405HSLV004200
ROM VER 1.02
Manufactured May 8, 2024
MakeMKV Drive Info
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK0DO58A5541
Firmware date: 2120-05-07 09:35
Highest AACS version: 77
Firmware version: 1.02
Thank you,
Farsideman
Re: LG BP60NB10 UHD Read Errors
Farsideman wrote: Mon Feb 09, 2026 10:51 pm Hello,
Model BP60NB10
SVC Code NB12
ROM VER 1.02
MakeMKV Drive Info
Revision: 1.02
Thank you,
Farsideman
No, your drive is flashed correctly and the firmware is not your issue.
It would have been much more helpful if you would copy and paste the MakeMKV log window text when you get a failed rip.
Anyway, you can start by cleaning the disc. Most UHD discs require cleaning before they can be ripped, especially when new as they often have an invisible layer of film on them from the manufacturing process.
