I was wondering whether it is possible to crossflash a Pioneer BDR-X12EBK that was manufactured in 2021.
In the main thread it says that lately Pioneers can't be crossflashed anymore, but since this is a used one from 2021 would I have a chance that it comes with an earlier firmware that can be crossflashed?
Would it be worth the risk to buy this used?
Thanks for your help!
Crossflashing BDR-X12EBK from 2021?
Re: Crossflashing BDR-X12EBK from 2021?
Please post your Makemkv info. Most likely I can help you.Hubldidubldi wrote: Mon Feb 09, 2026 8:15 pm Hello,
Hubldidubldi
Thanks you! I don't actually own it yet but I saw one posted locally so I will try to buy it if you say there is a good chance.Coopervid wrote: Mon Feb 09, 2026 9:48 pmPlease post your Makemkv info. Most likely I can help you.Hubldidubldi wrote: Mon Feb 09, 2026 8:15 pm Hello,
